55 ragger Samba Member
Posted: Fri Mar 26, 2021 4:49 am Post subject: Quick fix ? |
Has anyone had this same problem?
It was only happens on windy days !
This is the he quick fix !
Jetfxr69 Samba Member
Joined: December 28, 2018 Posts: 1293 Location: White mtns nh
Posted: Fri Mar 26, 2021 5:12 am Post subject: Re: Quick fix ? |
Should we assume your complaint is about the noise this seal creates?
Had the same issue when I replaced mine with the standard aftermarket (Busdepot), seal.
Decided to put the other style that has the bulb on the bottom. That bulb closes up the gap and stops air/noise. You have to cut little v notches in the corners to let any water drain from underneath. Others will tell you not to use this one due to trapping moisture, but its nice and quiet, and If I need to, I will just pull the rack every 4-5 years to check and clean area.
Cant see the notch in the corner, but theyre there. Dont remember where I got this one. _________________ You can't be a real country unless you have a beer and an airline. It helps if you have some kind of a football team, or some nuclear weapons, but at the very least you need a beer. Zappa
‘77 westy Seamus
‘76 tintop Crusher
‘77 westy The Judge
‘72 tintop bastard westy Hudson |
Posted: Fri Mar 26, 2021 5:42 am Post subject: Re: Quick fix ? |
Interesting,
That seal was changed 1 yr ago that's why the change in noise .
So I'm in the process of painting to top .
I was thinking fiber glassing a stainless steal rod , giving it more strength.
The same thing granite counter top guys do.
around to sink area to give it more strength. |
richparker Samba Member
Joined: November 24, 2011 Posts: 6983 Location: Durango, CO
Posted: Fri Mar 26, 2021 6:00 am Post subject: Re: Quick fix ? |
Fixing that driver side windshield wiper is definitely a quick fix. The top is going to take a little more time. If you’re painting it you might want to look at gel coat. Should we assume you’re removing the top in order to paint it? If so, make sure you inspect all the hardware upon re-installation that might be part of the problem. I’m with the post above, you should get the seal with the bulb on the bottom, that seal does not look correct. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
Posted: Fri Mar 26, 2021 6:34 am Post subject: Re: Quick fix ? |
You should consider pulling the rack off. Its not hard at all. Dont need to remove headliner, just pull it down enough in the back to get a wrench on the four nuts that hold the rear edge of the rack on. While its off, you can clean the tin-top, get all the leaves and shit out of there that will cause it to rot, and rattlecan fresh paint on there.
The red circle is a nice little tip that someone else posted. Epoxy thise little garden hose screens over those drain holes. Keeps the hornets, wasps, bees, etc from nesting up under the rack.
Also, spend the few bucks and change the cleats to stainless ones with stainless or aluminum rivets. Couple cans of rustoleum gloss white enamel and this rustoleum school bus yellow is a close match. Just ordered 12 cans for $6/ ea, so its still available out there.
‘77 westy Seamus
‘76 tintop Crusher
‘77 westy The Judge
Posted: Fri Mar 26, 2021 8:50 am Post subject: Re: Quick fix ? |
Jetxv69 https
I like the fix for the rain holes ,
I can do that
Your bus is looking nice and clean nice match on the paint
We can’t get Rust-Olium here it’s called Tremclad
From home Depo
I plan to take it off and paint ! |
pioneer1 Samba Member
Joined: February 11, 2008 Posts: 2069 Location: Ontario Canada
Posted: Fri Mar 26, 2021 10:32 am Post subject: Re: Quick fix ? |
Quick fix? Foam weather striping squeezed into the space. _________________ "Always waiting for tomorrow ruined everything"
'85 Porsche 911 Targa
'76 Westfalia project |
Starbucket Samba Member
Posted: Fri Mar 26, 2021 2:47 pm Post subject: Re: Quick fix ? |
Check the front hinge screws to see if they are loose and that the wood mounting area isn't rotted. |
Posted: Fri Mar 26, 2021 3:13 pm Post subject: Re: Quick fix ? |
Front hinge screws? _________________ "Always waiting for tomorrow ruined everything"
Posted: Fri Mar 26, 2021 3:18 pm Post subject: Re: Quick fix ? |
pioneer1 wrote: |
Front hinge screws?
Open the top and look at where the hinges mount on the pop top in front (stand outside and look at the inside front of pop top) and they screw in from the side. |
Abscate Samba Member
Posted: Fri Mar 26, 2021 4:20 pm Post subject: Re: Quick fix ? |
If bees Nest up there just leave them alone. Hornets won’t nest up there. _________________ .ssS! |
busdaddy Samba Member
Posted: Fri Mar 26, 2021 4:29 pm Post subject: Re: Quick fix ? |
Starbucket wrote: |
pioneer1 wrote: |
Front hinge screws?
It's a late style top, it hinges at the back, the component in question (luggage rack) is bolted to the roof permanently.
As others have mentioned remove the rack for a look underneath, when you put it back on you can adjust it up or down to alter the gap (like those sticks you've stuck in there). Or get the trim with the bulb, but count on regular maintenance to look for trapped moisture and rust. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat Mar 27, 2021 6:45 am Post subject: Re: Quick fix ? |
busdaddy wrote: |
Starbucket wrote: |
pioneer1 wrote: |
Front hinge screws?
The original post shows the front of the bus not the carrier, when did it switch? |
Posted: Sat Mar 27, 2021 7:22 am Post subject: Re: Quick fix ? |
Starbucket...1973 _________________ "Always waiting for tomorrow ruined everything"
KentABQ Samba Member
Joined: September 11, 2016 Posts: 2406 Location: Albuquerque NM
Posted: Sun Mar 28, 2021 2:38 pm Post subject: Re: Quick fix ? |
Jetfxr69 wrote: |
Thanks for the tip, Jet!
I've been searching without luck for something close to Chrome Yellow. _________________ -Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!" ---WildIdea
Bus ownership via emoticons:
---williamM |
Posted: Mon Mar 29, 2021 5:18 am Post subject: Re: Quick fix ? |
KentABQ wrote: |
Jetfxr69 wrote: |
I've been searching without luck for something close to Chrome Yellow. |
Had trouble finding any. Its been out there a few years and as im sure you know, all the paint companies continually change the colors and codes. I ordered mine through my local Fastenal. They contacted there distributor and confirmed they could get some in. Taking a couple weeks, but at least its coming, and at a resonable price.
Rustoleum item number is
1643830 _________________ You can't be a real country unless you have a beer and an airline. It helps if you have some kind of a football team, or some nuclear weapons, but at the very least you need a beer. Zappa
‘77 westy Seamus
‘76 tintop Crusher
‘77 westy The Judge
Posted: Tue Mar 30, 2021 6:36 am Post subject: Re: Quick fix ? |
Jetfxr69 wrote: |
1643830 |
I was able to find it on eBay, but it was closer to $60 for six cans.
But that's okay. At least it will do the job well. _________________ -Kent-
---williamM |
Posted: Wed Mar 31, 2021 3:21 am Post subject: Re: Quick fix ? |
You silly fools. The rust will still be there , eating away at your Van like a cancerous sore.... _________________ .ssS! |
Posted: Wed May 26, 2021 1:52 pm Post subject: Re: Quick fix ? |
Thanks for the tip Jetfx69 that work out good,
lots of debris does get in the weepers.
Posted: Wed May 26, 2021 1:58 pm Post subject: Re: Quick fix ? |
Add some re-enforcing to stop the vibration,
Had my buddy Jack paint it up for me,
It turned out great
Over all I'm happy with it.
thanks to the Samba !!
