carguytroy Samba Member
Posted: Mon Mar 29, 2021 6:17 am Post subject: Oil Pressure Spring Torment |
The case I have didn’t have the pistons, springs, or the screws for the oil relief passages so I bought a new set from one of the online vendors. The small one went in easy but I cannot get the damn longer one in there. The kit is suppposed to be just the standard stock springs. It seems to me that the way the spring is wound when I twist the screw plug it is expanding the spring slightly covering the threads just enough that it won’t catch. Is there some magic tricky thing to get this in or what? Smaller piston maybe? Spring too long? I’ve spent a few hours on this and getting pretty irritated with it. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Mon Mar 29, 2021 7:16 am Post subject: Re: Oil Pressure Spring Torment |
I'd MAKE SURE that there isn't an old spring or old piston STUCK up in there. You may need a tap to get in there to try to "grab" any spring or stuck piston.
So if that's not the case, remember what Scarlett said: "Tomorrow is another day !!!" These can be tricky, with metal sealing ring, pushing up/in straight, all while trying to turn it.
For the record, even though I have them, I hate the big slot plugs for these, what was VW thinkin' ???? There are aftermarket hex head plugs for these available. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
evanfrucht Samba Member
Joined: July 24, 2016 Posts: 2180 Location: Laurel Canyon, CA
Posted: Mon Mar 29, 2021 7:50 am Post subject: Re: Oil Pressure Spring Torment |
Most replacement springs are longer which is probably your issue.
Get this kit, it's better than the cheap sets around and has everything you need. https://www.cbperformance.com/product-p/1230.htm _________________ 1967 Bug ( the daily rod )
1964 Fury Wagon ( the pavement shredder ) |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3899 Location: Seattle, WA
Posted: Mon Mar 29, 2021 9:06 am Post subject: Re: Oil Pressure Spring Torment |
Also, most of the "stock" kits contain the wrong, slotted, piston for
the rear relief, which is longer than the correct piston, and makes
starting the plug threads much more difficult. _________________ '67 bug: seized by the authorities
Posted: Mon Mar 29, 2021 11:41 am Post subject: Re: Oil Pressure Spring Torment |
I did just buy that CB kit the other day. Figured I’d compare the two. There’s no old piston or anything in there. Hopefully that’s the cure. I went to my local VW shop and grabbed an Allen head plug the other day and still having a rough time. Kinda ridiculous you get beat by a little spring. Sheesh. |
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Mon Mar 29, 2021 12:57 pm Post subject: Re: Oil Pressure Spring Torment |
By the design, the spring shouldn’t be able to get hung up and un-wind or wind.
Have you tried threading in the bolt without the spring? Threads ok?
Posted: Mon Mar 29, 2021 1:21 pm Post subject: Re: Oil Pressure Spring Torment |
Threads are good. Goes right in without the spring in there. Open part of the piston facing the spring. |
txoval Samba Member
Posted: Mon Mar 29, 2021 1:25 pm Post subject: Re: Oil Pressure Spring Torment |
Can you post a picture? |
Posted: Tue Apr 13, 2021 2:02 pm Post subject: Re: Oil Pressure Spring Torment |
I still can’t get the damn the thing in. Even purchased another set of springs etc from CB Performance. Still no luck. Anyone try this before?
http://www.headflowmasters.com/vw-oil-pressure-valve-body.html#.YHYEiS1OKhB
The kit Looks like a decent idea anyway but I’m having a hell of a time with the stock replacements I’ve bought. Any tricks?! |
Posted: Tue Apr 13, 2021 2:07 pm Post subject: Re: Oil Pressure Spring Torment |
You have to push down hard while also getting it started carefully as to not cross thread the case. It's not exactly easy to do...
I think you just need to try harder _________________ 1967 Bug ( the daily rod )
mark tucker Samba Member
Posted: Tue Apr 13, 2021 2:37 pm Post subject: Re: Oil Pressure Spring Torment |
are you sure you have the riight springs in the right holes??correct pistons in the correct holes?? |
Posted: Tue Apr 13, 2021 3:03 pm Post subject: Re: Oil Pressure Spring Torment |
Pistons in both kits are the same. Same size for both pistons. No difference. The long spring toward the pulley side and the short spring towards the flywheel side. |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3445 Location: San Diego
Posted: Tue Apr 13, 2021 3:50 pm Post subject: Re: Oil Pressure Spring Torment |
Maybe try pushing the spring in without turning the screw. When you are up against the first thread, rotate the screw a half turn or so, backwards, then go forward. |
Posted: Tue Apr 13, 2021 4:26 pm Post subject: Re: Oil Pressure Spring Torment |
Pictures might help, but as long as you have the right springs, and the pistons fit properly and are fully seated then you just aren't pushing hard enough or are not turning the screw at the right time, or both.
Also make sure the top threads aren't already stripped
Try to screw it in without the spring to verify the threads are good _________________ 1967 Bug ( the daily rod )
modok Samba Member
Joined: October 30, 2009 Posts: 26789 Location: Colorado Springs
Posted: Tue Apr 13, 2021 4:58 pm Post subject: Re: Oil Pressure Spring Torment |
Maybe there is something already in the hole.
Check the hole |
Posted: Tue Apr 13, 2021 6:05 pm Post subject: Re: Oil Pressure Spring Torment |
modok wrote: |
Check the hole |
Yes that also crossed my mind. Its not uncommon for the old pistons to seize in the bore. Your used case my already have one stuck inside on hole that the previous owner never bothered to fish out. _________________ 1967 Bug ( the daily rod )
Posted: Fri Apr 16, 2021 5:32 pm Post subject: Re: Oil Pressure Spring Torment |
Finally got the SOB in there. Not sure how but it finally just went. Serious exercise in patience. |
Posted: Fri Apr 16, 2021 6:14 pm Post subject: Re: Oil Pressure Spring Torment |
they can be a booger to do. especialy with the std vw screws.I love the allen head screws.I hope you didnt ferget the sealing washers |
Posted: Fri Apr 16, 2021 6:20 pm Post subject: Re: Oil Pressure Spring Torment |
mark tucker wrote: |
Apparently I did. What are sealing washers? For the caps? Shouldn’t mess with the feeble minded like that. You’re kidding. |
mukluk Samba Member
Posted: Fri Apr 16, 2021 6:43 pm Post subject: Re: Oil Pressure Spring Torment |
carguytroy wrote: |
The plug(s) should have a metal crush seal/washer similar to what's used for your oil drain plug, see number 20 in the diagram below.
_________________ 1960 Ragtop w/Semaphores "Inga"
