Found a Hannover made March 1956
Kopperhead
Kopperhead is offline
PostPosted: Mon Mar 29, 2021 8:40 am    Post subject: Found a Hannover made March 1956 Reply with quote
Rescued the saveable parts from this Single cab, according to the body number it’s made in March -56 and I has the new type of engine cradle so it must be an early Hannover build. Sadly it was crushed 15 years ago by a Forrest Skidder
1961 Ragtop Black
1956 Single Cab project
bobrk
bobrk is offline
PostPosted: Mon Mar 29, 2021 8:51 am    Post subject: Re: Found a Hannover made March 1956 Reply with quote
Sure, that will buff out...
1959 Single Cab “Otto”
1500 single port | 1963 small nut/big brake transaxle | CSP Disc Brakes | dual circuit m/c | Deutsch Polster seats
velvetgreen
velvetgreen is offline
PostPosted: Mon Mar 29, 2021 8:53 am    Post subject: Re: Found a Hannover made March 1956 Reply with quote
you should put it in this thread-
https://www.thesamba.com/vw/forum/viewtopic.php?t=164642&start=19020
what did you find that was still useful?
Clara Premium Member
Clara is online now
PostPosted: Mon Mar 29, 2021 10:33 am    Post subject: Re: Found a Hannover made March 1956 Reply with quote
I am under the impression that there was concurrent production of buses at Wolfsburg and at Hanover for about a month or so.
A couple different sources have slightly different VINs for the 1st Hanover bus.
Maybe post something in the Wolfsburg bus thread, with the VIN, as a March 1956 is a very early Hanover bus.
Can you find the VIN? or just the body number?
check this out:
https://www.thesamba.com/vw/forum/viewtopic.php?t=225586
Kopperhead
PostPosted: Mon Mar 29, 2021 12:45 pm    Post subject: Re: Found a Hannover made March 1956 Reply with quote
One rim, steeringbox, front end, left rear panel and corner, right side panel(dented but rust free), tailgate (rusted bad), engine lid, taillight parts, right door with door handles, front sheet metal (will be a wall decoration I think), cargo lid. Front bumper and perhaps the part I value most is the rear bumper
All these parts will be used on my 56 SC (made in dec -55 in Wolfsburg)
1961 Ragtop Black
Kopperhead
PostPosted: Mon Mar 29, 2021 12:50 pm    Post subject: Re: Found a Hannover made March 1956 Reply with quote
The vin tag is really corroded but I will try to read it.
I will compare some of the part to my dec -55 SC and post in the Wolfsburg bus thread
1961 Ragtop Black
1970PAKombi
1970PAKombi is offline
PostPosted: Mon Mar 29, 2021 2:21 pm    Post subject: Re: Found a Hannover made March 1956 Reply with quote
What a shame - what's the story? How did you learn about this thing in the woods and sadly losing its life that way?
velvetgreen
PostPosted: Mon Mar 29, 2021 8:00 pm    Post subject: Re: Found a Hannover made March 1956 Reply with quote
Cool glad to hear that you got so much off of it. You could try soaking the tag in CLR etc to see if it would make it legible
tasb
The Distributor Distributor
tasb is offline
PostPosted: Mon Mar 29, 2021 9:41 pm    Post subject: Re: Found a Hannover made March 1956 Reply with quote
He's in Sweden, might need an explanation as to what CLR is?
Roads Scholar &
velvetgreen
PostPosted: Tue Mar 30, 2021 6:18 am    Post subject: Re: Found a Hannover made March 1956 Reply with quote
CLR- Calcium Lime and Rust https://clrbrands.com/
hitest
hitest is offline
PostPosted: Tue Mar 30, 2021 8:42 am    Post subject: Re: Found a Hannover made March 1956 Reply with quote
I'm lichen the moss Cool
FU#5
Kopperhead
PostPosted: Tue Mar 30, 2021 2:41 pm    Post subject: Re: Found a Hannover made March 1956 Reply with quote
The rim dated February 56
1961 Ragtop Black
EmpiGT
EmpiGT is offline
PostPosted: Tue Mar 30, 2021 7:10 pm    Post subject: Re: Found a Hannover made March 1956 Reply with quote
When you say body number, how are you dating body # to march of 56? The body # on these busses are around 10,000 to 15,000 off from the actual vin number. Could be built later than you think
Kopperhead
PostPosted: Tue Mar 30, 2021 11:54 pm    Post subject: Re: Found a Hannover made March 1956 Reply with quote
This was my estimation according to the bodynumber 169xxx , but the number was hart to read, so I will examine more, i'm not 100% sure that the second number is a 6, but I will soak it in CLR and se if I can see it all.
I'm not convinced that it´s an early Hannover build but my investigation will go on Very Happy
1961 Ragtop Black
Who.Me? Premium Member
Who.Me? is offline
PostPosted: Wed Mar 31, 2021 12:49 am    Post subject: Re: Found a Hannover made March 1956 Reply with quote
In case it helps you narrow down the date, my 8th October 1956 single cab has a body number in the 192,7## range.
Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786
Trevor P
Trevor P is offline
PostPosted: Sat Apr 03, 2021 12:36 pm    Post subject: Re: Found a Hannover made March 1956 Reply with quote
My 56 PGSG was built the last day of Wolfsburg production on Mar 7 1956 and has a 171xxx VIN. IIRC is has the original 2/56 dated rims.
53 Canadian standard oval
56 Wolfsburg PG/SG
57 Oval, 2332 & Berg 5
70 911T
91 Westy
Kopperhead
PostPosted: Mon Apr 19, 2021 9:34 am    Post subject: Re: Found a Hannover made March 1956 Reply with quote
Found a number on the front bumper stop 184388, is that April 56’ ?
1961 Ragtop Black
easy e
easy e is offline
PostPosted: Mon Apr 19, 2021 2:01 pm    Post subject: Re: Found a Hannover made March 1956 Reply with quote
Around the third week of May '56.
aka: Evan
