davlance01 Samba Member
Posted: Sun Apr 04, 2021 7:05 am Post subject: Re: Fuel pump cavitation, which is my fault |
dgbeatty, I thought about a fuel cooler as well. Old school truckers used to run them before the injection pump to get better fuel mileage and remove issues with saddle tanks that were low on fuel and the fuel wasn't getting cool enough.
I moved a truck from Pennsylvania down to Miami in the fall after the winter fuel blend change and the van running on that pa fuel in still hot miami would vapor lock about every 10 miles. I now deliver trucks with a half tank of fuel in the van so I can mix with local climate fuels to try to help with the different fuel blends across the country.
Truck driveaway using this van presents issues that normal van owners wouldn't experience. Fuel blends being a big issue during season changes and towing the van in the rain with a cold engine presents big issues as well.
I'm actually leaning towards a in-tank fuel pump and leaving the external pump on the frame as a backup to get me home if the internal pump fails. I may also put a cooler inline to help reduce in tank temperatures as well. _________________ Life is short and the road is long so if you want to see it all you have to drive fast! |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Sun Apr 04, 2021 9:45 am Post subject: Re: Fuel pump cavitation, which is my fault |
The most common source of water, dirt, and leaves is from the fuel expansion tanks in the front fenders. Where they fail is the large grommet on top that you can not easily see. When I replace a tank, I drop both expansion tanks and replace the grommet. The tires bombard those tanks with water and dirt. I suppose if you live where leaves fall, parts of them could also work their way into the tank. _________________ ☮️ |
Posted: Sun Apr 04, 2021 10:47 am Post subject: Re: Fuel pump cavitation, which is my fault |
If you see large pieces of anything in your tank I'm thinking the seals and overflow tanks would indeed need inspected.
In my case that stuff has all been gone over.
I would like somehow include the fuel system into the inspection/maintenance schedule. The only thing I do now is look for leaks and do pressure/flow/amp waveforms with the scope once a month while I have the van in the shop for maintenance.
I'm thinking about installing the in-tank fuel pump and using the old pump to drain and refill the tank for inspection of the fuel itself and put that into the schedule. Maybe overkill but that's how I roll!
I just turned in my 2020 taxes and I just found out that I put 10k miles a month on my van. Of coarse that is not always under its own power but the transmission, cv joints, brakes, steering and bearings are all getting wear. Under its own power its always 1000 miles from the shop when I drive it so maintenance is huge huge huge for me and a noisy fuel pump doesn't make me feel any better. _________________ Life is short and the road is long so if you want to see it all you have to drive fast! |
Posted: Fri Jun 18, 2021 12:29 pm Post subject: Re: Fuel pump cavitation, which is my fault |
I got sick of dealing with this 1984 designed fuel system.
So.......
Tanks inc pa-2 paired with a AEM adjustable fuel pressure regulator with 1:1 vacuum port and new russell -6 AN ptfe stainless braided
fuel lines and stainless fittings.
Runs great, can barely hear that fuel pump.
Next new fuel rails that will allow me to attach an ptfe fittings in the engine compartment and a couple of check valves so I don't loose pressure at shut off the I'll be done with it.
Fuel pump is 100 psi and I can barely hear it run, the new fpr has no issues bringing the pressure down to specs.
Car runs great.
FYI: this job is not for the faint of heart, you'll need to cut hack and beat things with hammers to make it all work.
I left the old pump on for road emergencies, just blocked off the fuel lines.
Back to delivering semi trucks next week with it and moving on with my life. _________________ Life is short and the road is long so if you want to see it all you have to drive fast! |
Posted: Wed Aug 04, 2021 8:12 am Post subject: Re: Fuel pump cavitation, which is my fault |
100 hours on fuel pump with no issues so far _________________ Life is short and the road is long so if you want to see it all you have to drive fast! |
dgbeatty Samba Member
Joined: October 26, 2006 Posts: 702 Location: Sacramento
Posted: Wed Aug 04, 2021 4:07 pm Post subject: Re: Fuel pump cavitation, which is my fault |
Just a note on the NAPA 3248 ie WIX 33248. The micron rating is 149. It is a purpose built wire mesh pre-filter and unless it is heavily clogged it will not cause cavitation in a Vanagon fuel system. If you discount partially clogged intake screens the biggest single cause of cavitation is fuel pumps that delivery too much volume and overwhelm the intake system. Fuel pumps are not one sizes all. A 2.x litre Vanagon engine does not need and cannot use a "high volume" pump unless you modify the tank internally. _________________ Schau in das Buch |
chompy Samba Member
Joined: August 12, 2014 Posts: 400 Location: Cascade Locks
Posted: Wed Aug 04, 2021 4:14 pm Post subject: Re: Fuel pump cavitation, which is my fault |
davlance01 wrote: |
So.......
Car runs great.
Back to delivering semi trucks next week with it and moving on with my life. |
Oh man I missed this whole thread. As much as I hate changing in-tank pumps, this is the best solution available. Cools the pump better as well! Good job! _________________ '81 Westfalia Subaru EJ22
Manual Transmission |
Posted: Fri Aug 06, 2021 6:46 pm Post subject: Re: Fuel pump cavitation, which is my fault |
Honestly it has been the best upgrade I have done to date. My car was starving for fuel. The van feels way smoother and more responsive than it did before the upgrade. I have the smaller outlet on my tank maybe the larger one wouldn't have gave me as much issues. _________________ Life is short and the road is long so if you want to see it all you have to drive fast! |
