andybla Samba Member
Posted: Mon May 17, 2021 6:00 am Post subject: undercoating peeling off |
Hello, Last weekend i sprayed on some freshly undercoating to the sides from the wheel wells, i dit this first because i still need to weld on something that when it is weld on, i cannot reach those area's anymore that i have sprayed undercoating on now.
So what i did was leave a taped stroke open where the piece needs to be welded so i can put welding primer in between etc..
What i notice is, while the undercoating is nicely layed on, it stays gummy/rubberized (which i think is ok?)
And you can peel it off easily, is this normal with undercoating? I did scuff it up and degreased the surface, it's like plasti dip peel off type ...
