nextgen Samba Member
Joined: August 19, 2004 Posts: 6030 Location: CONGERS, N.Y.
Posted: Fri Apr 02, 2021 8:51 am Post subject: do only bugs with vents behind each side window have this |
My bug looks good considering the age of its paint job. Like 25 years old.
It is a 73 and has the side vents behind each side window and last year I noticed paint bubbles just behind and below the vents on each side and down to the top of each rear fender.
If it is only on later model vents then I can assume I better seal them up.
Is this a problem with bugs without the side vents.
I took it to a body shop and the guy said it is not as simple as it looks. He is an up scale shop and checked out the inside of bug, I do not have any head liner and the rear seat is out so he could see that area is double walled and could not get to see the area.
He said to do it right he would have to do a lot of cutting.
I went to another shop shop that was massive and he give me 3 choices,
1 He does it like the other guy said --- Big bucks.
2 he cuts just the area were the bubbles are out.
3 I do #2 ( not that #2 ) and have him match the paint.
He said no matter how old a car is he can match the paint, you can't just buy can of Porsche Guards Red and expect it will match a 25 year old paint job.
So is this common?? _________________ email: [email protected]
The TYPE IV UPRIGHT CONVERSION MANUAL
BEETLE MAGNETIC DEFLECTOR SHIELDS
LETS TALK DUBS https://www.youtube.com/results?search_query=joe+cali+ghia https://letstalkdubs.libsyn.com/ep-200-joe-cali-ty...qI3xJTCzjs |
b-man Samba Member
Posted: Fri Apr 02, 2021 9:06 am Post subject: Re: do only bugs with vents behind each side window have this |
From what I understand there’s spray foam inside there applied by the factory on bugs with the vents behind the rear side windows.
Rusting is a very common issue in that area and repairing it isn’t easy or cheap. _________________ 1956 Dove Blue Panel
1966 Velvet Green Single Cab
1957 L41 Black Oval Window Beetle |
Posted: Fri Apr 02, 2021 10:29 am Post subject: Re: do only bugs with vents behind each side window have this |
B-Man you totally jarred my memory, I remember that !!!!
Some I think I saw when I took off the vent grille years back and sealed the vent with body filler.
After all these years, that is a perfect storm for rust.
OK so what do you think about paint matching. These photos were taken at least 2 years ago except the front on photo I took last year when I replaced my front apron.
infiniteLoop Samba Member
Joined: October 09, 2020 Posts: 265 Location: Empire State
Posted: Fri Apr 02, 2021 10:40 am Post subject: Re: do only bugs with vents behind each side window have this |
Yes. Just years with the vents rust there. Salt-water/water gets in the vents. The 'Dealth Foam" absorbs it and you get a rust issue there.
If the foam is removed and just regular water gets in there occasionally, it is not a problem. |
beetlenut Samba Member
Posted: Fri Apr 02, 2021 12:20 pm Post subject: Re: do only bugs with vents behind each side window have this |
It can get pretty ugly back in there! If you're seeing paint bubbles, it's rotted through from the inside out.
_________________ scrapyards are for quitters
Wetstuff wrote: |
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again. |
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104 |
