bomberbob Samba Member
Posted: Sat Apr 03, 2021 5:28 am Post subject: hundreds of pinholes in paint |
I sanded all the orange peel out, went to buff, there are hundreds of tiny pinholes in the paint. Not sure if you can see them in the photo.
Go back to wet sanding and see if I can take them out without going through clear?
Or scuff it, and mask off the rest of the car and reshoot the panel??
_________________ 1968 Beetle (storage)
1990 Jetta GLI megasquirted, burning E85 (currently in heavy maintenance)
2004 Jetta turbo GLI
Marion, Iowa |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17963 Location: Eugene, OR
Posted: Sat Apr 03, 2021 11:59 am Post subject: Re: hundreds of pinholes in paint |
I’m thinking you’re going to have to sand them out and clear the whole panel again. Strange it’s just the 1 panel. Maybe it was contaminated with something? _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
raydog Samba Member
Joined: February 09, 2006 Posts: 1157 Location: Cape Cod
Posted: Sun Apr 04, 2021 10:34 am Post subject: Re: hundreds of pinholes in paint |
I think pinholes are caused from the previous coat(s) of paint outgassing. In other words, applying your next coat too soon. _________________ Come on, It's not rocket science. KISS |
67ctbug Samba Member
Posted: Sun Apr 04, 2021 3:37 pm Post subject: Re: hundreds of pinholes in paint |
Yeah that's solvent pop. Could be caused by the paint being applied too thick so the previous layers were off-gassing still when you re-coated. _________________ '67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'73 Dodge W200
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote: |
mukluk wrote: |
jspbtown Samba Member
Posted: Mon Apr 05, 2021 6:25 am Post subject: Re: hundreds of pinholes in paint |
I agree with solvent pop. Thats why I always extend the flash times well beyond the time suggested.
There is a BIG difference in time between the flash time and the recoat window so I always at least double up the flash times to make sure things are settled down. |
Posted: Tue Apr 06, 2021 4:45 am Post subject: Re: hundreds of pinholes in paint |
OK, I don't understand why I would only have it on one panel. I bought some Meguir's buffing compound, the stuff rated at 105 to try and remove the holes. My son said its going to take sanding as the buffing compound,, even the 105 ultra cut is going to take forever. I have not done anything yet, weighing my options. If I scuff it up to put another coat of clear on it, what do I need to scuff to, 1000 grit? Is the clear going to go down into the holes, or is it going to just sit on top and I have voids instead of holes? _________________ 1968 Beetle (storage)
Marion, Iowa |
Posted: Tue Apr 06, 2021 6:38 am Post subject: Re: hundreds of pinholes in paint |
Quote: |
OK, I don't understand why I would only have it on one panel. |
Well it could be that it was a flat panel that got more paint. Or it might have been the last panel you painted that was not quite off gassed yet? Or a combination of the two?
Its very frustrating for sure.
You can't just "fill" the pinholes with clear. You have to sand the panel flat and remove them. Then you can determine if you need to shoot more base. |
Posted: Tue Apr 06, 2021 10:13 am Post subject: Re: hundreds of pinholes in paint |
OK I will put 1000 grit on the DA and slowly work it down. Hopefully I don't burn through. Base coat is water based paint, which was a dream to spray, but I had not counted on any rework on it. If I succeed in getting rid of the holes without burning into base, then I will spray probably two more coats of clear so I have enough thickness to sand off the new orange peel. _________________ 1968 Beetle (storage)
Marion, Iowa |
Posted: Wed Apr 07, 2021 4:55 am Post subject: Re: hundreds of pinholes in paint |
Update: scuffed the panel with the pinholes last night. Moved around to the other side to buff that. After a little buffing I noticed that panel also has the pin holes, so its not limited to one panel. Prior to the buff, I could not see those holes. Its almost like I have to buff it a little, then they appear. So the rework is a larger task than I thought. _________________ 1968 Beetle (storage)
Marion, Iowa |
Braukuche Samba Member
Posted: Sat Apr 10, 2021 8:30 am Post subject: Re: hundreds of pinholes in paint |
bomberbob wrote: |
Update: scuffed the panel with the pinholes last night. Moved around to the other side to buff that. After a little buffing I noticed that panel also has the pin holes, so its not limited to one panel. Prior to the buff, I could not see those holes. Its almost like I have to buff it a little, then they appear. So the rework is a larger task than I thought. |
It’s cause compound is getting in the holes and when it dries it turns white and shows up.
Been there before. It sucks ass. You likely will have to sand them out and reshoot. Try using thinner coats and allowing at least a half hour between coats.
Good luck. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Teeroy Samba Member
Joined: April 20, 2003 Posts: 3682 Location: Eastern WA
Posted: Sat Apr 10, 2021 8:44 pm Post subject: Re: hundreds of pinholes in paint |
Did you spray the car in a real spray booth? You need the constant air flow to get water born basecoat to dry, unlike solvent base paints that will flash off by solvent evaporation. _________________ Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org |
Posted: Mon Apr 12, 2021 4:41 am Post subject: Re: hundreds of pinholes in paint |
Base coat isn't the problem. I sprayed that and then had a delay, had to lightly scuff it to put down the clear. It was good and dry when the clear went over it. If I remember right it was a 2 day delay. I do like the water based paint, thats all I will use in the future. _________________ 1968 Beetle (storage)
Marion, Iowa |
