Igeo Samba Member
Joined: September 25, 2018 Posts: 888 Location: Oakland, CA
Posted: Sun Apr 04, 2021 10:52 am Post subject: Noisy Relay (?) Behind the Dash |
My '87 2.1 has what sounds like a relay behind the dash somewhere that makes a clicking noise from time to time. There does not seem to be any pattern to when this happens. It can be quiet for a few days, then out of the blue it will rattle. No noticeable effect, just a random clicking for a few moments then quiet again. I don't think its around the fuse panel, as it sounds more central behind the dash. Anybody had this happen? _________________ 1987 Westfalia 2.1 WBX Manual |
AceTaylor Samba Member
Joined: July 15, 2009 Posts: 139 Location: PERKASIE, PA
Posted: Sun Apr 04, 2021 2:23 pm Post subject: Re: Noisy Relay (?) Behind the Dash |
If you have power windows, one of the switched may be stuck in position. |
Squidfish Samba Member
Posted: Sun Apr 04, 2021 5:32 pm Post subject: Re: Noisy Relay (?) Behind the Dash |
All seems well with your cooling system? I was having some issues recently which I attributed to it. _________________ 1985.5 - Vanagon Westfalia Weekender Wolfsburg Edition - LH8U - "Penny"
- 2.6i 5-Cylinder 10v (2004) |
brickster Samba Member
Joined: January 05, 2004 Posts: 512 Location: CO, USA
Posted: Sun Apr 04, 2021 7:30 pm Post subject: Re: Noisy Relay (?) Behind the Dash |
Could it be speedometer unit or the cable? |
Igeo Samba Member
Posted: Sun Apr 04, 2021 9:19 pm Post subject: Re: Noisy Relay (?) Behind the Dash |
Manual windows. Cooling system fine although lately, occasionally I do hear the radiator fan come on for a short time on a cold start. Speedo is smooth. _________________ 1987 Westfalia 2.1 WBX Manual |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
4Gears4Tires Samba Member
Posted: Mon Apr 05, 2021 8:11 am Post subject: Re: Noisy Relay (?) Behind the Dash |
jgh3rd wrote: |
That was my first thought as well. _________________ '87 Syncro
Posted: Mon Apr 05, 2021 8:19 am Post subject: Re: Noisy Relay (?) Behind the Dash |
Igeo wrote: |
Manual windows. Cooling system fine although lately, occasionally I do hear the radiator fan come on for a short time on a cold start. Speedo is smooth. |
Sounds like it's time to take things apart and see what's loose. If you have a borescope you could do a partial disassembly. |
fxr Samba Member
Joined: December 07, 2014 Posts: 2325 Location: Bay area CA
Posted: Mon Apr 05, 2021 8:50 am Post subject: Re: Noisy Relay (?) Behind the Dash |
4Gears4Tires wrote: |
jgh3rd wrote: |
That was my first thought as well. |
And mine. Easy to test, just remove the DS front bearing cap that drives the speedo cable. If the noise now disappears, the speedo cable may need a slight tweak to its path - and squirting some grease down it wouldn't hurt. _________________ Jim Crowther
Vespa GTS 300 |
eeebee Samba Member
Posted: Mon Apr 05, 2021 11:36 am Post subject: Re: Noisy Relay (?) Behind the Dash |
My new flasher relay will do that sometimes since it was replaced. The new one will be quite until i use the blinkers the first time then it will continue to click until the car ignition is turned off. _________________ Eric
1987 Vanagon Wolfsburg Special Edition
GoWesty 2.3
Democracy is the recurrent suspicion that more than half of the people are right more than half of the time. |
DuncanS Samba Member
Posted: Mon Apr 05, 2021 2:04 pm Post subject: Re: Noisy Relay (?) Behind the Dash |
X3 with Eric. |
Igeo Samba Member
Posted: Mon Apr 05, 2021 2:17 pm Post subject: Re: Noisy Relay (?) Behind the Dash |
It's definitely not a speedo cable noise. It's a random clicking that happens while driving...I'll look at that flasher relay. _________________ 1987 Westfalia 2.1 WBX Manual |
Posted: Mon Apr 05, 2021 8:00 pm Post subject: Re: Noisy Relay (?) Behind the Dash |
While it's doing it, turn on the flasher switch and see if the indicator light is steady or blinks or it it stops the clicking. |
beach_creature Samba Member
Posted: Mon Apr 05, 2021 9:49 pm Post subject: Re: Noisy Relay (?) Behind the Dash |
I had a similar issue at one point. I feel like it may have been attributed to grounds or corrosion of the connects of the relays. But that was a while back and I can’t fully remember. Might be worth looking at. _________________ 84 Westy
1.9TD AAZ
5spd manual with Locking Peloquin TBD |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6832 Location: Fort Lauderdale, Fl.
Posted: Tue Apr 06, 2021 5:41 am Post subject: Re: Noisy Relay (?) Behind the Dash |
One thing to do if you have not tried it and if you do not have the cover over the relay panel is to reach down there while driving - palm up with the back of your fingers to feel the relays to see if you can feel any vibration.
Don't look at them - keep your eyes on the road!
Another thing you can do is when you hear it clicking is to turn something on that uses a relay to energize the relay fully. It might help to id it if the clicking stops immediately.
A relay is not going to activate unless it is getting power so that means a bad switch or a short in the wiring.
Or the negative ground for that relay is corroded and -12v power is having a hard time getting to it. _________________ This free advice is worth exactly what you paid for it.
fleetwood41 Samba Member
Posted: Tue Apr 06, 2021 11:17 am Post subject: Re: Noisy Relay (?) Behind the Dash |
I have an intermittent and inconsistent clicking near the fuse panel in my 1987. It seems to be related to the brake lights because the clicking mostly happens just as I apply the brakes. If I recall correctly, a search on here (years ago) led me to believe that the brake lights and flashers may share a relay or something like that. I bought a new relay to replace it but lost the entire Vanagon tool/parts bag before I could get around to it.
Anyhoo, since everything seems to work fine, I never replaced it and it still clicks occasionally.
Happy Hunting! _________________ 1987 2WD w/ 2.5 Subi & Poptop Conversion |
