a57oval Samba Member
Joined: September 28, 2003 Posts: 202 Location: West Seattle, WA
Posted: Wed Jun 01, 2022 7:05 am Post subject: Re: Anyone tried KGRP / Airhead Parts Front door seals ? |
I bought Airhead door seals and am very happy with them. The first set I received must have been the "factory seconds" as the were too stiff.
The second set, which is now installed on my 72, are excellent. The doors still require a good push to close but they are way better than the German seals I bought from Wolfsburg West. with those installed the doors would actually bend before completely closing. To thumbs up.
Peter |
grantspensley Samba Member
Joined: February 04, 2019 Posts: 20 Location: Chicago
Posted: Tue May 31, 2022 8:44 pm Post subject: Re: Anyone tried KGRP / Airhead Parts Front door seals ? |
I bought the factory seconds and tried to install them on the passenger door. It’s binding and not fitting right in the lower front corner. I’m hoping I can fix it. Definitely harder foam in the corners than the rest of the seal. |
Turbod16v Samba Member
Joined: October 11, 2016 Posts: 156 Location: beaver twp, PA
Posted: Mon May 16, 2022 3:18 am Post subject: Re: Anyone tried KGRP / Airhead Parts Front door seals ? |
I have factory seconds from airhead on my 71. I called to ask what was the deal with the seconds and was told the seals came out to stiff for Airheads specs but still usable.
They are THE best fitting seals I have used. Almost 2 years later I still gotta pull hard on door to close but they seal right and tight. _________________ 1971 westy tin top that got a 74 up pop top bolted on |
dodger tom Samba Member
Joined: March 25, 2013 Posts: 1272 Location: Central Coast, CA, but we're all still Ukrainian
Posted: Sun May 15, 2022 10:14 pm Post subject: Re: Anyone tried KGRP / Airhead Parts Front door seals ? |
Have you called them and asked them when the seals will be available? Might be waiting on materials in a ship lying offshore of long beach. _________________ 1978 Champaign Edition 2 Westfalia
Would never find the time to keep up another classic air-cooled. |
otiswesty Samba Member
Joined: November 21, 2006 Posts: 1731 Location: Portland
Posted: Sun May 15, 2022 9:41 pm Post subject: Re: Anyone tried KGRP / Airhead Parts Front door seals ? |
Listed as out of stock but factory seconds available.
Any suggestions for a nice fitting seal that is not too stiff? If not, I'll try the "factory seconds." _________________ 1978 Sage Green P22 Westfalia
1989 T3 Syncro Single cab
Just a regular guy |
bastardbus Samba Member
Joined: July 13, 2000 Posts: 1768 Location: Toledo, Ohio
Posted: Wed Apr 07, 2021 1:16 pm Post subject: Re: Anyone tried KGRP / Airhead Parts Front door seals ? |
Awesome replies guys, it is appreciated. Will be ordering the KGRP ones for sure tonight _________________ Samba Member #95 |
westyman71 Samba Member
Posted: Tue Apr 06, 2021 5:55 am Post subject: Re: Anyone tried KGRP / Airhead Parts Front door seals ? |
Similar experience here.
My 73 Westy had a Brazilian right front door seal on it when I got it.
Did not fit well.
Got a German seal. Better fit than the Brazilian, but very stiff. Took a lot of effort to get door closed. Spent a lot of time adjusting door, but still not right.
Then I purchased and Airhead Parts seal. Fit perfect. Adapted very well in a short time. If I ever have to do another, without a doubt, it will be this seal.
Take care all, best wishes and happy trails!! |
brando90gl Samba Member
Posted: Tue Apr 06, 2021 4:20 am Post subject: Re: Anyone tried KGRP / Airhead Parts Front door seals ? |
I’ve installed two sets of Airhead Parts bay front door seals in the last few months. They’re pretty good, no complaints. They will be a tad tight at first, but they break in perfectly. _________________ 67 Type 1
68 Campmobile
70 Single Cab |
pantone149 Samba Member
Joined: August 19, 2004 Posts: 1018 Location: Mt. Shasta
Posted: Mon Apr 05, 2021 2:36 pm Post subject: Re: Anyone tried KGRP / Airhead Parts Front door seals ? |
Best ones I have tried, and I tried two others but can't remember which vendors exactly. |
NoBudgetVWGarage Samba Member
Joined: November 27, 2008 Posts: 755 Location: Quartz Hill,CA
Posted: Mon Apr 05, 2021 10:30 am Post subject: Re: Anyone tried KGRP / Airhead Parts Front door seals ? |
I had purchased them for my 72 recently. They seemed to fit good. I have never tried any other seal so I have no comparison.
Recently sold the 72 but gonna buy them again for my 69. _________________ 1969 Transporter
1968 Ghia
1959 Ghia Hot VW Drag Car |
Mberglo Samba Member
Joined: January 13, 2020 Posts: 383 Location: Huntsville, AL
Posted: Mon Apr 05, 2021 8:42 am Post subject: Re: Anyone tried KGRP / Airhead Parts Front door seals ? |
I bought one door seal from BusDepot and another from JBUGS. I threw them both in the trash and bought Airheads seals. They are shaped properly and fit perfectly. I very highly recommend them. |
EDragnDean Samba Member
Joined: July 13, 2005 Posts: 1148 Location: Vancouver, WA
JaimeH Samba Member
Joined: April 24, 2012 Posts: 265 Location: Canterbury, NH
Posted: Sun Apr 04, 2021 4:46 pm Post subject: Re: Anyone tried KGRP / Airhead Parts Front door seals ? |
I put the Airhead cab door seals on my bus. They fit great. For the first few months they held themselves in place. After they were broken in I applied a small amount of cement in the corners and below the door checks. I couldn't be happier with the way they fit and work. After a year installed the doors still require a strong pull to close tightly, but the fit and seal are way better than other "German" seals I tried. _________________ 1978 Transporter 2.0 FI, BA6
Special Thanks to Razor's Customs, Boscawen, NH |
richparker Samba Member
Joined: November 24, 2011 Posts: 6986 Location: Durango, CO
Posted: Sun Apr 04, 2021 3:18 pm Post subject: Re: Anyone tried KGRP / Airhead Parts Front door seals ? |
I just installed the Airhead front door seals on my ‘71. They are super nice! Although the doors are a little tight, I did not have to adjust the door strikes. I used German seals on my last bus and I like these ones better. They are nice and soft and I don’t think it’ll be long before the pack down. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51156 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Apr 04, 2021 3:02 pm Post subject: Re: Anyone tried KGRP / Airhead Parts Front door seals ? |
Sounds like the best thing since sliced bread, the rest of their stuff is usually pretty good, I'd take a gamble on them.
Please report back with your findings if you do get them, my German ones are still not quite right 4-5 years on, great fit, but too dense and stiff. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun Apr 04, 2021 2:20 pm Post subject: Anyone tried KGRP / Airhead Parts Front door seals ? |
My son is fixing up a `70 dlx bus and we have bought all the rubber we need from West Coast Metric but we held off on the front door seals. From our reading on the forums we see there are 4 various door seals available.
-Brazil non VW (which are said to be garbage)
-Brazil VW OEM (which have so-so reviews)
-German (have the best reviews of the 3 but have read a LOT of people who still have severe issues with them and at the high price has kept us from buying)
-The last style, I recently read on KGRP Airhead Parts web site they are making their own bus front door seals in the USA. Says they did this because all the others have issues. So has anyone tried these seals and do you have a critique of them? How are they compared to the German seals? They are both comparable in price but want to choose the best out of the two. Any info, comments, pictures on the KGRP seals is appreciated.
Here is link to their ad and description.
https://airheadparts.com/vw-part/bay-window-bus-door-seal-front-door-type-2-211-831-722-d/ _________________ Samba Member #95 |
