djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32584 Location: Reading Pennsylvania
dobryan Samba Member
Joined: March 24, 2006 Posts: 16501 Location: Brookeville, MD
jimf909 Samba Member
Posted: Mon Apr 05, 2021 7:19 am Post subject: Re: Rostra Cruise Control in Automatic 2.1 ..... attempt # 2 |
I've installed the Rostra CC on a couple of cars. Always at the throttle body and they've always operated like I'd expect a factory CC to work (my Vanagon has a Bostig and manual so it's different from your setup but the concepts are the same). Setting the dip switches always takes some time. Also, installing on an OBDII car solves some problems like the speed sensor.
Better luck this time around. Something tells me it's gonna work this time. _________________ - Jim
Abscate wrote: |
DeLvxe Samba Member
Joined: January 08, 2019 Posts: 106 Location: Seattle
Posted: Mon Apr 05, 2021 9:31 am Post subject: Re: Rostra Cruise Control in Automatic 2.1 ..... attempt # 2 |
I have spent he past several days trying to get my GW kit to work (EJ25, manual, VW cruise control stalk). The unit does not seem to respond at all when I try to set it. I ran through the troubleshooting guide from Rostra and tracked it down to the VSS not sending a signal to the unit (still haven't figured it out). Good luck with yours!
If anyone has advice or ideas for me, I'm all ears. As far as I can tell, the GW VSS doesn't seem to be sending pulses to the rostra unit. GW troubleshooting says to connect the VSS to the speedo and check for voltage fluctuations as you manually turn the speedo. I did this with the VSS connected to the CC unit and the key in the "on position" and saw no fluctuation in voltage. _________________ 1991 manual camper with EJ25 |
Posted: Mon Apr 05, 2021 5:25 pm Post subject: Re: Rostra Cruise Control in Automatic 2.1 ..... attempt # 2 |
No real progress to report, just a lot of figuring and thinking.
I got the Rostra out and started thinking about how to mount it, where to mount it and how to attach to the throttle body.
I will mount the control unit under the back seat.
I read that it makes noise when operating but really? Who is going to notice a little bit more noise!
I'm largely deaf anyway..... no worries.
I will need to extend the electric harness to facilitate the unit being so far in the rear.
I will feed the pull cable over the trans axle and pass under the firewall.
I'd love to use the firewall to anchor the pull cable but with engine movement I doubt that would be effective.
It might be worth a try? How much does the engine really move at a steady speed?
I'll need to create a cable mounting bracket on the auto trans bell housing.
To hook up, I think I'll made a lever that mounts on the pivot above the shaft spring.
Remove that ball lever, replace it with a longer one, make the pull easier and longer.
Or should I go ahead and use that ball?
Ghia
Vanagon
Beetle
erste Samba Member
Joined: March 29, 2013 Posts: 1110 Location: San Francisco
Posted: Mon Apr 05, 2021 5:44 pm Post subject: Re: Rostra Cruise Control in Automatic 2.1 ..... attempt # 2 |
Good luck! I didn't know GW sold a pedal switch. That probably would have saved me some headaches trying to get the mk3 or mk4 and kia switches to work, or whatever the heck I used.
I couldn't locate a vanagon cruise stalk and used one from a mk1 rabbit. It's a little bit shorter but was a straight swap. |
oldskewlsk8ter Samba Member
Posted: Mon Apr 05, 2021 6:05 pm Post subject: Re: Rostra Cruise Control in Automatic 2.1 ..... attempt # 2 |
DeLvxe wrote: |
If anyone has advice or ideas for me, I'm all ears. As far as I can tell, the GW VSS doesn't seem to be sending pulses to the rostra unit. GW troubleshooting says to connect the VSS to the speedo and check for voltage fluctuations as you manually turn the speedo. I did this with the VSS connected to the CC unit and the key in the "on position" and saw no fluctuation in voltage. |
I went through 2 gowesty VSS’ and was about to order a third when I read somewhere that they don’t guarantee theirs to work with the Subaru. Checked the website and sure enough they have a disclaimer. I got about a year out of each unit. I went with the one from Fast Forward this time that is specifically built for the Subaru ecu needs. So far so good. _________________ 1986 Hightop w/EJ25 DOHC & 4EAT auto
1965 Kombi project |
dgbeatty Samba Member
Joined: October 26, 2006 Posts: 702 Location: Sacramento
Posted: Mon Apr 05, 2021 6:40 pm Post subject: Re: Rostra Cruise Control in Automatic 2.1 ..... attempt # 2 |
I have not been impressed with "engineered in house" GoWe$ty products for a variety of reasons.
Some/many of the VSS sensors available today are poorly designed with poorly selected component characteristics. Add the fact that many are not robust ie not resistant to overvoltage, undervoltage, spikes, reverse polarity etc. As always the stingy man spends the most. _________________ Schau in das Buch |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4772 Location: Bemidji, MN
Posted: Mon Apr 05, 2021 6:54 pm Post subject: Re: Rostra Cruise Control in Automatic 2.1 ..... attempt # 2 |
Dave- you probably know this but your cruise arm with the ball mount is tweaked downward. level it out, it's maleable, BTDT. i would absolutely look for a way to secure to the engine. the OEM vac actuator mount is a stud on the intake runner but just hose clamp a bar or something to the runner to give you the right angle of approach. _________________ -dan
www.thefixitworkshop.com |
Posted: Tue Apr 06, 2021 1:14 am Post subject: Re: Rostra Cruise Control in Automatic 2.1 ..... attempt # 2 |
DanHoug wrote: |
Dave- you probably know this but your cruise arm with the ball mount is tweaked downward. level it out, it's maleable, BTDT. i would absolutely look for a way to secure to the engine. the OEM vac actuator mount is a stud on the intake runner but just hose clamp a bar or something to the runner to give you the right angle of approach. |
Thanks!
Right now I'm unsure how to hook up.
I like the idea of finding a socket for that ball.
If I pull from the intake tubes I need to locate the actuator in the engine compartment exposed to the elements.
Pulling from the transaxle side I can have the unit secure and dry.
I'm using this Rostra because I already have it.
It is all but new. I think my previous failure was due to too much linkage and friction to overcome.
Ghia
Vanagon
Beetle
Posted: Tue Apr 06, 2021 11:43 am Post subject: Re: Rostra Cruise Control in Automatic 2.1 ..... attempt # 2 |
My Rostra is installed where the idle speed ECU used to live. It has been there well over 10 years and remains trouble free. _________________ Schau in das Buch |
Posted: Tue Apr 06, 2021 1:47 pm Post subject: Re: Rostra Cruise Control in Automatic 2.1 ..... attempt # 2 |
DanHoug wrote: |
i'll quote and correct myself... i forgot the Rostra/AudiVox actuators are a cable affair, correct? no need what-so-ever to mount to the engine. that guy quoted above doesn't know what he's talking about!! he was thinking the vac actuator. _________________ -dan
Posted: Mon Apr 12, 2021 5:47 pm Post subject: Re: Rostra Cruise Control in Automatic 2.1 ..... attempt # 2 |
Today we were pulling out of our driveway, lined with large mature Pine trees, and my Wife said "Stop! Is there a box behind that tree?!"
I backed up and sure enough there was a drenched cardboard box sitting on the house side of the tree!
This tree is eight feet off of my driveway!
It has been raining for two days! Package hide and Go Seek!
Inside the box delivered by UPS (what the heck UPS?) was my new stalk mount Rostra switch!
At least the porch Pirates didn't take it!
Heck? I almost didn't get it either!
Inside the soaked box was a smaller soaked box. Inside of that box was my switch wrapped in a plastic bag..... Whew!
All is well!
Today USPS brought my GoWesty speedo VSS pickup coil and brake switch.
If I had time...... I could install this now.
Stay tuned!
Ghia
Vanagon
Beetle
a2wolfsburggli Samba Member
Posted: Tue Apr 13, 2021 8:51 am Post subject: Re: Rostra Cruise Control in Automatic 2.1 ..... attempt # 2 |
Having successfully installed the Rostra on my 87 manual 2.1 last spring...My thoughts:
I thought about mounting in the engine compartment. After some deliberation I went with the way that GW did their "kit." Instructions are easy to follow and it greatly simplifies the wiring. It works just peachy.
I have the stubby stalk switch mounted on the steering column cover. It's mounted up above the signal stalk and closer to the dash. It's easily visible and accessible from the side or though the steering wheel (Cuz you're going to be driving in a straight line when you activate it.) The wireless one just looked like it would be a PITA at some point in the future and the flat mount ones looked odd for a car cruise. The one that clamps to the turn signal stalk looks chincy to me.
I connected the Rostra brake deactivate circuit to the + side of the brake light switch on the master cyl. No need for a secondary switch.
Mine is a manual, I don't have a clutch switch...I'm a rebel risk taker...I know.
My settings for the dip switch thread is here: https://www.thesamba.com/vw/forum/viewtopic.php?t=736663
Reference it and ask any questions you have. This really isn't that complicated of an install. GW did all the hard work on it. Getting that GW VSS is a HUGE help. _________________ Current: '87 Westfalia | '16 Audi Q5 3.0T S-Line w/sport package.
Past: '09 CC 3.6L 4motion "R36 wannabe" | '02 Audi TT "ALMS Edition" | '84 Jetta GLI with Autotech Supercharger | '89 Helios Jetta GLI 16v's (x2) | '95.5 URS6 | and the list goes on.
Never underestimate the entertainment value of OCD overruling Common Sense
Last edited by a2wolfsburggli on Tue Apr 13, 2021 1:02 pm; edited 2 times in total |
Posted: Tue Apr 13, 2021 1:08 pm Post subject: Re: Rostra Cruise Control in Automatic 2.1 ..... attempt # 2 |
DeLvxe wrote: |
The first VSS I got was off a junker Mk2 VW. I had the same problem. The VSS for what ever reason was shot.
This looks like it's a warranty with GoWe$ty or buy a new one. They're only $30. One of the few GW products that isn't overpriced IMHO. _________________ Current: '87 Westfalia | '16 Audi Q5 3.0T S-Line w/sport package.
Never underestimate the entertainment value of OCD overruling Common Sense |
Posted: Tue Apr 13, 2021 1:13 pm Post subject: Re: Rostra Cruise Control in Automatic 2.1 ..... attempt # 2 |
djkeev wrote: |
Dave |
You'll never hear it under the rear bench. I can't hardly hear mine under the dash. Only slightly when it's setting up and when it releases.
If I was to mount mine in the rear it would be under the bench or in the tail light cubby.
No matter where, make sure the dip switch window is easily accessible for adjustments.
They're very weather resistant. I've been running one on my Yamaha FJR motorcycle for 6+ years. It's fully exposed to direct engine heat and in and area that takes direct rain / road moisture. (Ok.. technically I just sold the FJR, and I'm installing another Rostra on my R1200GSA this coming weekend / week.) _________________ Current: '87 Westfalia | '16 Audi Q5 3.0T S-Line w/sport package.
eeebee Samba Member
Posted: Wed Apr 14, 2021 11:11 am Post subject: Re: Rostra Cruise Control in Automatic 2.1 ..... attempt # 2 |
I mostly followed the Rosta manual. I did look at GoWesty's recommendations for the switch adjustments which were helpful.
I have the control unit installed in the left side of the engine. It is difficult to adjust the switches in this position.
I was fortunate enough to have some existing pieces to use for this installation. This shows the cable routed from the lower left hand corner to the throttle body. The cable is fixed at a bent plate mounted to the engine-transmission bolt. I also used the existing attachment at the throttle body which had a bolt hole.
Getting the slack adjusted was most critical since full throttle is required. I have never had the transmission kick-down but my driving is mostly freeway so I would rarely be going slow enough. _________________ Eric
1987 Vanagon Wolfsburg Special Edition
GoWesty 2.3
Democracy is the recurrent suspicion that more than half of the people are right more than half of the time. |
SyncroHead Samba Member
Joined: May 23, 2005 Posts: 1141 Location: Northern Nevada
Posted: Wed Apr 14, 2021 9:31 pm Post subject: Re: Rostra Cruise Control in Automatic 2.1 ..... attempt # 2 |
I've installed several cruise controls over the years. The Zemco cruise control I installed in my '87 Syncro in about 1992 failed years ago after maybe 10-12 good years. I'd been longing for cruise control again since.
I put this Rostra (like djkeev) in my '87 Syncro a couple years ago. I saw what GoWesty offered and thinking it was too expensive, decided to "roll my own". Used partly Rostra instructions and partly GoWesty's.
I felt the real beauty of the electric control and GoWesty's plan was that nothing goes in the engine compartment and you don't need to run any wires from the engine to the dash.
So, I removed the last remnants of the old Zemco and replaced with the Rostra system. I made my own switch brackets for the clutch and the brake, a few other bits and adapted wiring and made a bracket to mount the switch atop the steering column, but up in a nice handy and visible place. Used the GoWesty VSS on the back of the speedometer.
In the end it all worked fine, but if I were to do it again, I'd spend the extra $$ for the GW kit since I spent WAY more time coming up with my own solutions than I expected I would. I probably made about $4.50 an hour trading my time for money saved.
Jim Davis _________________ "A Vanagon? It's not a car or a van. It's a hobby!"
Check out:
www.VANAVATION.com
www.SyncroSafari.org and
www.Vanagons.org
sphet wrote: |
I have *no* idea what the previous owner carried in his Westy... angry donkeys? |
