dobryan Samba Member
Joined: March 24, 2006 Posts: 16504 Location: Brookeville, MD
markf1 Samba Member
Joined: September 21, 2019 Posts: 286 Location: Telluride, Colorado
Posted: Tue Jun 22, 2021 5:52 pm Post subject: Re: Leak at Rear CV -Transaxle connection |
MarkWard wrote: |
Weddle has the seal and O ring. If it’s the seal, you don’t need the O ring. To replace the O ring, you need to unscrew the side cover and that requires a tool and some attention to detail. It sets backlash and bearing preload. In general, the O ring shouldn’t leak. It should have been renewed when the trans was done. That said, I had a new O ring split. More of that good rubber. |
Mark Ward, you are a jedi van whisperer. It turned out to be the O ring you described above. I’m going to mention it to Mr,Gas and see if he feels any responsibility. _________________ 1986 Westfalia Syncro
2.1 L Waterboxer
Some Westy supported adventure photos:
https://www.openrangeimaging.com/adventure.html |
markf1 Samba Member
Posted: Tue Jun 22, 2021 6:13 pm Post subject: Re: Leak at Rear CV -Transaxle connection |
dobryan wrote: |
You can do this yourself. It is intimidating but not hard. Time to get dirty and take control. We are here to help. |
I recognize that. Biggest problem is time. I am focused on taking care of my clients and meeting the associated deadlines. maintaining house, keeping fit, practicing piano.
I was hoping I could pay an expert to do the work on the van. That said, we really like the guys who are our new mechanics and want to keep on best of terms with them. So, I'm blaming myself and chalking it up to lack of super detailed reinforced x 100 and repeated 9K times and then go there in person and follow up with a zoom meeting, CLEAR AND DETAILED COMMUNICATION. _________________ 1986 Westfalia Syncro
2.1 L Waterboxer
Posted: Wed Jun 23, 2021 6:08 am Post subject: Re: Leak at Rear CV -Transaxle connection |
markf1 wrote: |
dobryan wrote: |
I was hoping I could pay an expert to do the work on the van. That said, we really like the guys who are our new mechanics and want to keep on best of terms with them. So, I'm blaming myself and chalking it up to lack of super detailed reinforced x 100 and repeated 9K times and then go there in person and follow up with a zoom meeting, CLEAR AND DETAILED COMMUNICATION. |
Good attitude. I think it will work out in the end. _________________ Dave O
The Western Syncro build
Love My Westy Samba Member
Posted: Thu Jun 24, 2021 7:49 pm Post subject: Re: Leak at Rear CV -Transaxle connection |
I found this thread just a little too late seeing that I had just replaced the torn boots on the passenger side axle of my '86 Weekender about trhee weeks ago.
I ordered my boots from Van Cafe and got the GKN Lobro boots which were the same boots I had replaced in 2014 (driver's side) and 2015 (pass. side). The boots on the drivers side have held up well, but the boots on the pass side were both torn like they had been torn by something on the groove closest to the outside flanges. Since I don't drive my van a lot, they only had about 15K miles on them. I guess, from this discussion that I was lucky to get the miles I did out of them.
Having just replaced them I will see how long they last.
After driving 100 miles or so, I noticed that a leak in my transaxle seal had gotten worse, and, not having the stomach to attempt fixing it myself, I made and appointment and took it to a well thought of shop in Salt Lake City to have it professionally replaced.
I picked it up this afternoon and it sould be good to go. They replaced the drive axle seal and the drive flange cap as well as a qt of gear oil.
Total price was $527 including $350 in labor, $70 to diagnose and $60 to test drive and inspect for leaks.
I was ok with the price, but have no reference as to what the job should cost, I'm just writing this to help me determine if I want to do more business with this shop. My normal mechanic is a 1 man shop and he was too busy to fit me in.
I'm not writing this to bash the shop in any way.
I am planning on driving to Tacoma, WA and back and would like to take the van if I can get my confidence in it back up. It is running great, and until I made these discoveries I was feeling pretty good about it. I will first take it on a shorter trip to get a good feel for it, and when I return I will check the torque on the axle bolts again and watch for new leaks. |
Posted: Fri Jun 25, 2021 6:52 am Post subject: Re: Leak at Rear CV -Transaxle connection |
Love My Westy wrote: |
Sounds like a good plan to me. You'll likely be fine. And if it leaks again you'll be able to fix it yourself with our help. _________________ Dave O
Posted: Fri Jun 25, 2021 8:14 pm Post subject: Re: Leak at Rear CV -Transaxle connection |
dobryan wrote: |
Sounds like a good plan to me. You'll likely be fine. And if it leaks again you'll be able to fix it yourself with our help. |
Next time I'll try to do it myself, it doesn't sound all that hard, and, after discussing this with my normal mechanic it looks like I did in fact overpay. Lesson learned. |
Posted: Fri Jun 25, 2021 8:33 pm Post subject: Re: Leak at Rear CV -Transaxle connection |
dobryan wrote: |
