Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Mon Apr 05, 2021 4:54 pm Post subject: Ouch! That was bad |
Well... This is humiliating.
My last welds were 20x better than these!
Was it the rusted metal?
the amps seemed ok.
or was it the dull/ bent tungstun? _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'65 Tourist Delivery Build
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge" |
66brm Samba Member
Joined: January 25, 2010 Posts: 3676 Location: Perth Western Australia
Posted: Tue Apr 06, 2021 6:51 am Post subject: Re: Ouch! That was bad |
Rust will do that to a weld all day long, 90% of a good weld is material surface prep _________________ Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote: |
I am an expert at fitting things in holes, been doing it a long time |
infiniteLoop Samba Member
Joined: October 09, 2020 Posts: 265 Location: Empire State
Posted: Tue Apr 06, 2021 9:26 am Post subject: Re: Ouch! That was bad |
Do you wire/mig weld? |
Posted: Tue Apr 06, 2021 9:27 am Post subject: Re: Ouch! That was bad |
Tig. The metal was pitted and rusty however I wire brushed. Even then I couldnt get the rust to completely go away _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
bomberbob Samba Member
Posted: Tue Apr 06, 2021 10:08 am Post subject: Re: Ouch! That was bad |
Probably should have tickled it with a grinder. _________________ 1968 Beetle (storage)
1990 Jetta GLI megasquirted, burning E85 (currently in heavy maintenance)
2004 Jetta turbo GLI
Marion, Iowa |
Posted: Tue Apr 06, 2021 11:18 am Post subject: Re: Ouch! That was bad |
If you can't remove all of the rust I would push the nozzle with flux-core or MIG. It's hard enough to keep the electrode from getting contaminated with perfectly clean metal. |
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2922 Location: Memphis
Posted: Tue Apr 06, 2021 6:50 pm Post subject: Re: Ouch! That was bad |
I see lots of buildup and some porosity, with average penetration. Not horrible. Looks like you couldn't see well under the hood judging by the wandering path-?
The porosity is from a lack of gas... either you moved the torch away from that area too soon or your gas flow needs to be higher.
And yes you're fighting yourself if you weld over unprepped metal. A mig might have been a better choice for the dirty base metal you have _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
modok Samba Member
Joined: October 30, 2009 Posts: 26787 Location: Colorado Springs
Posted: Tue Apr 06, 2021 8:51 pm Post subject: Re: Ouch! That was bad |
That is a rust sandwich. You did not clean in between the two layers.
TIG especially needs to be clean to get good results.
it's fine tho. you don't really even need to weld it. The wheel cylinder pushes left and right equally so there is almost no force on it. |
raydog Samba Member
Joined: February 09, 2006 Posts: 1163 Location: Cape Cod
Posted: Wed Apr 07, 2021 7:15 am Post subject: Re: Ouch! That was bad |
modok wrote: |
Exactly, That area is only supposed to be tacked in a couple of spots from the factory. No need to perma-weld. _________________ Come on, It's not rocket science. KISS |
Posted: Wed Apr 07, 2021 9:41 am Post subject: Re: Ouch! That was bad |
Ok so it seems like rust was the culprit. How should I of removed it? I used a wire brush and nothing happened.
I put that bead on there because the two layers had split and the cylinder was dangling. Let me see if I can find a pic.
Thanks
Eh, you cant really see it but here it is,
'66 RIP
'69 RIP
Posted: Wed Apr 07, 2021 10:16 am Post subject: Re: Ouch! That was bad |
With flux-core on thicker metal you really only have to clean up a spot where you arc from first. I guy I work with doesn't even clean up metal he mig welds so I did some experiments with it. A lot of wire does end up on the floor though.
For rust like that I use a knotted brush on a 4.5" grinder. Then maybe clean it up with vinegar or acid. Vinegar is about as good as muriatic acid. Phosphoric acid is nicer to use and worth the extra money in my opinion.
Sand Blasting would give the best single process method to clean it up. |
orwell84 Samba Member
Joined: May 14, 2007 Posts: 2537 Location: Plattsburgh, New York
Posted: Fri Apr 09, 2021 6:35 pm Post subject: Re: Ouch! That was bad |
I love crappy Harbor Freight blast cabinet. Makes the most unpromising part look worth salvaging again. I started welding up some punky backing plates and people were like...just get new ones, which I did but guess what? The old ones actually fit and welding them in just not all that hard compared to finding different spacers or having shims made or whatever.
And oh yeah. The old ones actually fit. And the aftermarket parts do not. They are all off in some small way no matter what it is. So if it is going to require arts and crafts and endless diddling, I would rather spend the time on something that will FIT and not give my money to the People’s Machine Works in Wong Dong Province.
And the same with rusty heater tubes...the steel just comes out of the tetanus bucket of scrap and sparky spark, it turns back into a serviceable German part.
