red-ragtop Samba Member
Posted: Mon Apr 05, 2021 6:41 pm Post subject: Does someone reproduce this 6V Flasher? |
Trying to find a replacement 6 volt tun signal flasher. I can't find any that have this threaded prong on the top to screw into my bracket. I don't really want to buy a used one from eBay. Any ideas? 1965 Bug
Stockholm VW Samba Member
Posted: Mon Apr 05, 2021 8:29 pm Post subject: Re: Does someone reproduce this 6V Flasher? |
Following 👍 _________________ 1966 Volkswagen Sedan 1300 (now 1641), 6 volt, L456 Ruby Red, Platinum leatherette. |
shano63 Samba Member
Joined: October 06, 2006 Posts: 3596 Location: Stormville NY
Posted: Tue Apr 06, 2021 9:17 am Post subject: Re: Does someone reproduce this 6V Flasher? |
Try these guys https://www.bugcity.com/shop/shop.lasso?pquery=swf _________________ 63 T1 Ragtop Gulf Blue
08 Civic 5spd
22 Wrangler 6spd
78 F250 4x4 4spd
Chris
Take it as it comes-- Morrison |
rcroane Samba Member
Joined: January 03, 2013 Posts: 2000 Location: Springfield, Virginia
Posted: Tue Apr 06, 2021 11:07 am Post subject: Re: Does someone reproduce this 6V Flasher? |
As an alternative, you might consider one of these. I replaced the OG flasher on my '65....much more reliable with instant on and quicker flash. I bent the tab at the top and used a small machine bolt and nut to install onto the original bracket. And it's hidden by the wiring cover so the purists will never know!
https://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111953185BWW _________________ '65 Sunroof Bug |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Tue Apr 06, 2021 3:00 pm Post subject: Re: Does someone reproduce this 6V Flasher? |
red-ragtop wrote: |
Trying to find a replacement 6 volt tun signal flasher. I can't find any that have this threaded prong on the top to screw into my bracket. I don't really want to buy a used one from eBay. Any ideas? 1965 Bug |
If you are going to toss your old relay. I might be able to fix it, so would be happy to pay for shipping to here.
Have been able to find those in NOS condition in the classifieds. _________________ In Stereo, Where Available! |
Dangermouse Samba Member
Joined: November 23, 2005 Posts: 1266 Location: Beautiful New Zealand
Posted: Tue Apr 06, 2021 4:05 pm Post subject: Re: Does someone reproduce this 6V Flasher? |
Eric&Barb wrote: |
If you are going to toss your old relay. I might be able to fix it, so would be happy to pay for shipping to here. |
I for one would welcome a tutorial on that... Can these thermal relays be RnR’d? _________________ Do not follow me, for I may not lead. Do not lead me, for I may not follow. Do not walk beside me either; actually just bugger off and stand over there will you. |
Posted: Tue Apr 06, 2021 4:41 pm Post subject: Re: Does someone reproduce this 6V Flasher? |
Dangermouse wrote: |
Eric&Barb wrote: |
I for one would welcome a tutorial on that... Can these thermal relays be RnR’d? |
I second that! |
Posted: Tue Apr 06, 2021 8:58 pm Post subject: Re: Does someone reproduce this 6V Flasher? |
Eric&Barb wrote: |
Will see... Need one to repair. _________________ In Stereo, Where Available! |
Posted: Tue Apr 06, 2021 9:53 pm Post subject: Re: Does someone reproduce this 6V Flasher? |
Let me be the first to offer mine.... _________________ Do not follow me, for I may not lead. Do not lead me, for I may not follow. Do not walk beside me either; actually just bugger off and stand over there will you. |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34013 Location: Conejo Valley, CA
Posted: Wed Apr 07, 2021 10:43 am Post subject: Re: Does someone reproduce this 6V Flasher? |
Or you embed a new electronic flasher into that can, having the OG look and dependable flashing. Combined with LED lamps, this really makes them stand out for safety. |
Posted: Fri Apr 09, 2021 11:31 am Post subject: Re: Does someone reproduce this 6V Flasher? |
Well, I guess I don't need a new one. Wiggled some wires and got it to work. Cleaned the connections and applied some dielectric grease, and it's working fine now! |
Posted: Fri Apr 09, 2021 12:33 pm Post subject: Re: Does someone reproduce this 6V Flasher? |
red-ragtop wrote: |
Good to hear it was an easy fix!
Might be a good time to keep cleaning and greasing up connections... _________________ In Stereo, Where Available! |
Posted: Fri Apr 09, 2021 12:44 pm Post subject: Re: Does someone reproduce this 6V Flasher? |
KTPhil wrote: |
I tried this with the WW electronic flasher....wouldn't fit in the can. I think we're going to need a bigger can...... _________________ '65 Sunroof Bug |
Mervo Samba Member
Joined: January 04, 2016 Posts: 75 Location: Australia
Posted: Mon Apr 12, 2021 9:17 am Post subject: Re: Does someone reproduce this 6V Flasher? |
There are several small 6V electronic cylindrical units available in some of the motor cycle shops. I have used them in the past when I fitted LED bulbs. One would fit in the original 'can'. |
