Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24670 Location: Olympia Wash Rinse & Repeat
Posted: Thu Apr 08, 2021 5:02 pm Post subject: Re: Oil Dripping from Main Seal |
VW Brazil had a second oil drain from the VW factory. With engine together it is easy to just drill a drain hole and it will not get blocked up with engine case sealant when assembling. Does help to have another engine case apart to visualize at what angle to drill the hole and miss hitting the large case half stud bore which would cause a bigger oil leak.
https://www.thesamba.com/vw/forum/viewtopic.php?t=649204&highlight=fly+wheel+oil+drain
Also helps to polish the bore for the seal in the case with 300 or 400 grit wet/dry sand paper. Any corrosion or scratch will cause oil to leak around the FW seal outer edge. Personally have never used a sealant (just oil the outer edge of the seal so it slides into place) and once I took up polishing the seal bore, have not had any oil leakage problem. _________________ In Stereo, Where Available! |
txasylum Samba Member
Joined: December 15, 2004 Posts: 389 Location: Boyers, PA
Posted: Sat Apr 10, 2021 1:29 pm Post subject: Re: Oil Dripping from Main Seal |
So I ordered the speedi sleeve based on this youtube video https://www.youtube.com/watch?v=GjIbYMDDwMA and it is not the right size. The part on the video fits on the flywheel. I got the same part, but it is too small.
txasylum wrote: |
I just ordered a crank shaft repair seal and new crank seal. The repair seal is also known as a speadi sleeve.
Pruneman99 wrote: |
.006 is a bit loose, but I'd call it ok still. Mine is much worse.
Polish the snout on the flywheel. You can drill an extra drain hole in the case at the 6 o'clock position to help drain back. I've not tried to his mod, but others have and reported success. |
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Sun Apr 11, 2021 3:37 pm Post subject: Re: Oil Dripping from Main Seal |
What's the flywheel surface where the wheel slips into the seal look like? Is there surface rust? Is it rough? The issue isnt the seal.
Are you lubing the ID if the seal when you install it?
Is it even comming from the seal? _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'65 Tourist Delivery Build
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge" |
