jimdubs Samba Member
Joined: August 31, 2016 Posts: 152 Location: Buffalo, NY
Posted: Tue Apr 06, 2021 3:59 pm Post subject: Pop out seals |
I put pop outs in my bug, got seals from WCM. The drivers side window has never sealed at the upper front corner. The rubber doesn't touch the body, you can see in through the top.
The window has an even gap around the inside, so I feel that the window is sitting properly in the opening. The problem, as I see it, is that the seal is not designed with corners, so that when forced to bend around a corner, the outer edge pulls away from the body to even the radius (make sense??).
Is this one of those "something you have to deal with" issues or does someone make a better seal? |
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Sun Jan 16, 2022 11:28 am Post subject: Re: Pop out seals |
Help! My fingers are in great pain!
It took me an hour to get this far on installing the outer seal. I've been using a screwdriver and soapy water carefully. I tried a plastic scraper however mine is too flimsy.
_________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'65 Tourist Delivery Build
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge" |
j.goodspeed Samba Member
