74 Thing Samba Member
Posted: Wed Apr 07, 2021 12:00 am Post subject: Putting larger brake wheel cylinders in the rear |
I know there has been common practice or putting larger brake wheel cylinders in the back (eg, replace the stock rear 17mm brake rear brake cylinders with 22mm brake cylinders) to help with braking when running Cal-Look with larger rear tires (talking about 4 wheel drums).
By doing this will it effect brake pedal throw before a solid pedal is felt?
With the stock set up I got a firm brake pedal some 1" in, but with larger brake wheel cylinders in the back the pedal throw is like half way to the floor before I feel anything.
I have done the pressure bleeding as well.
Thanks |
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4278 Location: deepest, darkest Switzerland
Posted: Wed Apr 07, 2021 1:50 am Post subject: Re: Putting larger brake wheel cylinders in the rear |
This is serious stuff not to be approached haphazardly. I have ever improved rear braking without at least some improvement in front, like disks or twin leading shoe. It is more interesting to increase breaking surface area rather than cylinder size alone. Remember:
Front brakes break loose: no biggie
Rear brakes break loose: spin city |
modok Samba Member
Joined: October 30, 2009 Posts: 26785 Location: Colorado Springs
Posted: Wed Apr 07, 2021 2:23 am Post subject: Re: Putting larger brake wheel cylinders in the rear |
The pedal travel should be 34% more than it was before. |
UK Luke 72 Samba Member
Joined: September 07, 2011 Posts: 2867 Location: Little Britain
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5410 Location: Holland, MI
Posted: Wed Apr 07, 2021 9:54 am Post subject: Re: Putting larger brake wheel cylinders in the rear |
It’s a good idea to change up the wheel cylinders when changing sizes of tires, or disrupting the weight bias of the car.
Example, on rail buggies. I put the small 17mm rear wheel cylinders up front because with no body work or gas tank, the front is so light that I can pick it up myself. My buggy has 33” tires in the rear, and a heavy Vanagon transmission, gas tank, and Type 4 engine in the back. I actually modified the backing plates so I could use Super Beetle 23.6mm front cylinders in the rear, even larger than the standard bug 22mm front cylinders. It was a pretty easy swap. The bolt hole for the cylinder has to be slotted due to the different mounting boss to bolt hole spacing, and it needed a shim between the cylinder and backing plate. By doing these mods, it brakes beautifully, just like a stock car. Having the standard wheel cylinder arrangement like a full bodied car is just downright dangerous in a buggy. Way to much braking up front if you don’t swap things around.
So, in a cal-look, if you got bigger meatier tiers at the back, it may be work beefing up the rear cylinders a bit to keep brake balance the same. _________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
Posted: Wed Apr 07, 2021 11:35 am Post subject: Re: Putting larger brake wheel cylinders in the rear |
I jacked up the rear of the car since I replace the rear wheel cylinders to take a crack at bleeding again. Sure enough there was still some air in the lines.
The pedal is much much better now. I am going to run it for a while and see how the larger rear wheel brake cylinders feel.
Thanks |
BFB Samba Member
Posted: Wed Apr 07, 2021 4:52 pm Post subject: Re: Putting larger brake wheel cylinders in the rear |
i looked into wheel cylinders a while back with my local guy that sells empi and most of there's used the same wheel cylinders. he knew they were different from factory but looked like aftermarket just used a one size fits all approach.
so even if u go to the local parts store , and you buy a front wheel cylinder thinking its a larger wheel cylinder is it really? obviously if you have to modify your backing plate its some how different. but otherwise maybe its just the same part? something to think about is all _________________ Forced induction can overcome a lot of obsticles that gets in it's way
"You are the Engineer and the Mechanic.
Build it your way not the way someone else does it. Their way might not work for you." - clonebug
“ The monkey see monkey do mentality seems to run deep in VW people. "Gene Berg said it was so 30 years ago so thats the way it is" “ - bdkw1 |
j-dub Samba Member
Joined: November 09, 2003 Posts: 865 Location: Phoenix, AZ
Posted: Wed Apr 07, 2021 7:39 pm Post subject: Re: Putting larger brake wheel cylinders in the rear |
74 Thing wrote: |
Thanks |
Every time I can't get a good pedal this is what I end up finding even though I went through the sequence several times at that point. Sometimes letting the car site or drive it around small streets and then trying again helps. _________________ 1957 Oval rag
"POLICE STATION TOILET STOLEN ... Cops have nothing to go on." |
modok Samba Member
Posted: Wed Apr 07, 2021 8:52 pm Post subject: Re: Putting larger brake wheel cylinders in the rear |
richardcraineum wrote: |
The size of the hole cam be determined, by measuring the size of the hole.
But besides the hole there are also other parts.
There is the groove that the shoe fits in.
Early cars the shoe should be a snug fit in the groove, but not tight. May need to chamfer the edges of old shoes as they mushroom out. In later years they made the groove extra wide and the shoe floats in there.
the wide groove needs to be used with backing plates that guide the shoe on three pads.
to use these with early backing plates you can weld up and widen the part of the shoe that goes in the groove so it fits snug, but the newer style design is better so best to get newer backing plates.
Backing plates can be bent.
i have seen wheel cylinders wrongly sold for older cars. There is no ledge or stop on the pistons, you can push the pistons clear through the cylinder. That is only for self adjusting brakes, or brakes where the adjuster is in the e-brake thingy.
So....yeah parts sellers sometimes get it wrong, but you should have no problem educating them about it if you know how it works. Always compare old part to new. unless the last guy didn't. then, seek help. |
Wreck Samba Member
Posted: Wed Apr 07, 2021 9:33 pm Post subject: Re: Putting larger brake wheel cylinders in the rear |
j-dub wrote: |
74 Thing wrote: |
Thanks |
Every time I can't get a good pedal this is what I end up finding even though I went through the sequence several times at that point. Sometimes letting the car site or drive it around small streets and then trying again helps. |
I had similar issues with an S bug , putting on type3 rear brakes ,everything new , had 1/2 pedal , bleed and bleed . Was thinking the old master cylinder was toast , left it over night , bleed up straight away , I had the car on stands with the rear in the air , I think I had air in the back section of the cylinders , once level ,it could escape through the bleeder .
A tip for new players , when bleeding brakes on older cars with old mastercylinders and or boosters /servo , only depress the pedal 1/2 way , never go all the way to the floor , unless the booster and master is new or newish .
Old rubber diaphragms in boosters split and pushing master cylinder cups over areas in the cylinder that they don’t normally run on can cause issues . |
oprn Samba Member
Joined: November 13, 2016 Posts: 12714 Location: Western Canada
Posted: Thu Apr 08, 2021 6:39 am Post subject: Re: Putting larger brake wheel cylinders in the rear |
Vanapplebomb wrote: |
Example, on rail buggies. I put the small 17mm rear wheel cylinders up front because with no body work or gas tank, the front is so light that I can pick it up myself. My buggy has 33” tires in the rear, and a heavy Vanagon transmission, gas tank, and Type 4 engine in the back. I actually modified the backing plates so I could use Super Beetle 23.6mm front cylinders in the rear, even larger than the standard bug 22mm front cylinders. It was a pretty easy swap. The bolt hole for the cylinder has to be slotted due to the different mounting boss to bolt hole spacing, and it needed a shim between the cylinder and backing plate. By doing these mods, it brakes beautifully, just like a stock car. Having the standard wheel cylinder arrangement like a full bodied car is just downright dangerous in a buggy. Way to much braking up front if you don’t swap things around. |
My rail buggy came with no front brakes (filled my drawers a couple of times! ). I swapped in early Bay rear brakes, I'm not sure what the cylinder diameter is. I have now added the stock link pin front brakes so it will be interesting to see what the brake balance will be like. Tires are 24" rear and 26" front. The idea of short rears is to sacrifice a bit of clearance to get lower gearing for a 1600 SP. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
Posted: Thu Apr 08, 2021 12:41 pm Post subject: Re: Putting larger brake wheel cylinders in the rear |
I have to say the braking is much better with the larger front brake cylinders in the back as well. I have 22mm ATE brake cylinders on the front and the rear, with steel braided flex lines, and semi metallic shoes all around. I used syli glide brake grease on the friction points on all of the backing plates and shoes.
I will probably try to bleed one more time to make sure I got all the air out. The pedal travel is just a little more than it was before with the 17mm cylinders in the back.
Mine are all late model backing plates with the 3 contact spots and the larger groove in the cylinders.
A question is how often should wheel cylinders be replaced? I bleed/flush every two years since I know brake fluid attracts water, and use Castrol LMA fluid, but to be honest I have never paid close attention to the cylinders. They are very simple with boots on the ends then pistons and seals and a spring, but they live in a harsh environment and crap can get under the boot and start to pit the pistons and cylinder walls and effect performance.
I hate bleeding brakes! |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5995 Location: Brooklyn
Posted: Thu Apr 08, 2021 1:53 pm Post subject: Re: Putting larger brake wheel cylinders in the rear |
74 Thing wrote: |
A question is how often should wheel cylinders be replaced? |
When they go bad!
If you pull up the boot and find dampness/brake fluid there, that means the seals inside the cylinder are leaking. Time to rebuild or replace. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
modok Samba Member
Posted: Thu Apr 08, 2021 6:42 pm Post subject: Re: Putting larger brake wheel cylinders in the rear |
A larger master would get the pedal back up, but so would using
using the 17mm cylinders front and rear. Or maybe you would prefer all 19mm then it would be near same as stock?
It's just leverage, you can't have it both ways. |
Posted: Thu Apr 08, 2021 10:10 pm Post subject: Re: Putting larger brake wheel cylinders in the rear |
I like it the way it is with 22mm cylinders all the way around.
Mostly the pedal was due to more air in the system that came out the next morning when I jacked up the rear in the air so that the cylinders were as high as the reservoir. |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7214 Location: Videbaek Denmark
Posted: Fri Apr 09, 2021 2:57 am Post subject: Re: Putting larger brake wheel cylinders in the rear |
Beware that if you swop to a larger master cylinder the pedal pressure needed increases too.
I wrote a novel about the subject on another forum some years back. If it still exists I will paste to here.
Although I must admit that I have never done the 22/22 mm set up on drum brakes. We would have swopped to front discs way before that point. But I see the idea if the car does some off roading. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
Posted: Fri Apr 09, 2021 10:53 am Post subject: Re: Putting larger brake wheel cylinders in the rear |
Hi Torben,
Please post the link to the post you made if you can find it.
I read a post by you using 944 wheel cylinders in the back at cal-look.no.
I had a new set of front ATE 22mm wheel cylinders so I tried them in the back of the Thing to see the outcome. So far so good-the Thing has larger/heavier tires on the back and the 181 rear brake drums are so much heavier than the front too so the larger wheel cylinders seem to be helping a lot.
I am keeping my master as is-its a volume and pressure compromise. |
