ssquires68 Samba Member
Posted: Wed Apr 07, 2021 6:06 am Post subject: Cleaning Headliner |
Has anyone ever tried cleaning the headliner in their bug? I have some yellowing, not a lot so I'd just like to clean. What's the best thing you've found to clean up yellowing?
Do those Mr.Clean magic erasers work on this?
TIA |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34003 Location: Conejo Valley, CA
Posted: Wed Apr 07, 2021 10:39 am Post subject: Re: Cleaning Headliner |
I was able to remove smoke stains (and much of smell) from my old Square's headliner with windex on a cloth and repeated wiping. That was the cause of much of the yellowing, obvious because it was strongest near the driver's window... he smoked with the window cracked.
For yellowing, you might try hydrogen peroxide, though I've never done this on a headliner, and it may take off the printed dots. Hard to keep it wet long enough to work, too.
How are your windows and rubber? Definitely coordinate window seal replacement with headliner replacement; they are best done together. These small improvements may hold you until you replace it. |
toxicavenger70 Samba Member
Posted: Wed Apr 07, 2021 1:05 pm Post subject: Re: Cleaning Headliner |
I used Magic Erasure and it took some of it off. But not all. |
67 Florida Deluxe Samba Purist
Joined: June 21, 2005 Posts: 7987 Location: Gainesville and Tampa, Florida
Posted: Wed Apr 07, 2021 8:09 pm Post subject: Re: Cleaning Headliner |
Yellowing may be aging of the material or the old glue coming through as a stain and it won't come out. But if it's dirt, on my perforated vinyl materials, I used Dow Bathroom Cleaner (the "scrubbing bubbles" stuff). Just a light coat, leave it for a minute, watch the dirt pull into the foam and then remove with a large damp (not wet) sponge. Wiped immediately with dry terry towel. Worked like a charm! _________________ -Kent (BaT "daleallen")
OG member of the '67 Posse
A few of my toys, past and present
'56 Oval, '66 KG Conv't, '67 21-Window, '67 Bug, '79 SuperVert, '55 Pre-A Continental |
finster Samba Member
Joined: May 26, 2012 Posts: 7935 Location: north o' the border
Posted: Thu Apr 08, 2021 6:15 am Post subject: Re: Cleaning Headliner |
magic eraser takes a bit of pressure rubbing to work so might stretch the material. the foam cleaner souns good... _________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
cricketseed Samba Member
Joined: August 10, 2015 Posts: 115 Location: North Carolina
pwmcguire Samba Member
Joined: January 30, 2011 Posts: 1108 Location: Kennesaw GA
Posted: Fri Apr 09, 2021 12:22 pm Post subject: Re: Cleaning Headliner |
Consider vinyl paint, some of that stain is from moisture staining the backside of
the headliner. I've had success on two of my beetles with vinyl paint, some of the holes get covered because they are not complete perforations. I works nice
NavyGeneral Samba Member
Joined: August 01, 2004 Posts: 584 Location: Tennessee
Posted: Mon Jan 29, 2024 1:19 pm Post subject: Re: Cleaning Headliner |
Volkswagen had a system or procedures to enhance and recondition used cars taken in on trade, both Volkswagen and Domestic models. They did an in depth rehab, up to and including either painting or dying the headliners, carpets, seats etc. This procedure carried over to painting the inside of the bumpers as well as rusted headlight apparatus. Vehicles on the Volkswagen used car lots were aesthetically and cosmetically very nice. Several images here from the Volkswagens Reconditioning manual.
jinx758 Samba Member
Posted: Mon Jan 29, 2024 10:02 pm Post subject: Re: Cleaning Headliner |
Howdy ...
Years ago I used tons of elbow grease & that cheap cleaner called Totally Awesome on my off white seats.
After wiping with a cloth, I stood up to take a call but had to steady myself - skateboard knees & getting older.
I stood there with the rag in my hand on the door opening.
Anywho - that area of the headliner was very clean. So clean I did the whole thing the next weekend with very good results.
It was diluted & I rinsed with damp cloth afterward cuz it WILL take tire marks off cement.
Maybe some help ... stay safe
jinx _________________ " It's not valuable unless you learn something from an experience. " Henry Ford
It's not unlike the same difference
You can't push a rope
VALVES (cold)
POINTS
TIMING
CARB (fully warmed engine)
SCRAPE ALL GROUNDS
My Craigslist rescued 100 footer :
1971 Standard Bug
1776cc dual port
034 distributor
38mm EGAS Carburetor |
Posted: Tue Jan 30, 2024 5:35 am Post subject: Re: Cleaning Headliner |
...but the handbook said to "explode the car" boss!
2type2 Samba Member
Joined: June 02, 2002 Posts: 975 Location: SW Colorado
Posted: Tue Jan 30, 2024 7:41 am Post subject: Re: Cleaning Headliner |
FWIW, I once saw a trashy stained headliner which was made quite presentable by a spray can application of " Kilz" primer. Won't fix tears and holes, but makes for a nice clean fresh cover. _________________ "A life of peace and happiness depends on your own gratefulness" |
lboos Samba Member
Joined: November 20, 2015 Posts: 410 Location: Marietta GA.
Posted: Tue Jan 30, 2024 1:37 pm Post subject: Re: Cleaning Headliner |
Do what pwmcguire said, it's the only thing that works, I've tried them all. |
