RBEmerson Samba Member
Joined: November 05, 2011 Posts: 2108 Location: SE PA
Posted: Wed Apr 07, 2021 12:27 pm Post subject: Rear main seal and what else? |
'90 Westy w/ GW 2.2L motor w/ GW EMS injection
The rear main seal is a slow leaker, losing just enough oil to be annoying.
We're planning a long trip in the fall, and I've decided now is the time to sort out the darn seal.
I'm going to have to job done by a shop I trust, not a shade tree job.
First, what has to get out of the way to get to the seal? Pull the motor or trans axle?
I strikes me that some other items can be cleaned at the same time. I'm thinking of the various known vulnerable pieces. IIRC the fuel delivery plumbing is in that category. What other items are on that list? _________________ Lord, give me coffee to change the things I can change, and wine to accept the things I can't change. |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17116 Location: Retired South Florida
Posted: Wed Apr 07, 2021 12:29 pm Post subject: Re: Rear main seal and what else? |
I would plan on leaving the engine installed and pulling the transmission. _________________ ☮️ |
Posted: Wed Apr 07, 2021 12:39 pm Post subject: Re: Rear main seal and what else? |
Works for me. Probably a good time to check the CV's.
FWIW, we were stuck with a learning experience with swapping the transaxle. The PO replaced it with a GW unit. Aside from forgetting the grounding strap, most of the job went well. The big gotcha was not getting the rear part of the shifter shaft out of the way.
The problem is it's too easy to bend the shaft, which makes a mess of where the shifter sits in the cabin, and its overall action. Point learned: keep the shaft out of the way, and don't bend it.
We were stuck with the job of diagnosing, and replacing the shaft. Grrr... _________________ Lord, give me coffee to change the things I can change, and wine to accept the things I can't change. |
Posted: Wed Apr 07, 2021 12:45 pm Post subject: Re: Rear main seal and what else? |
You can remove the transaxle by disconnecting only the inner CV's, but it is handy to have them completely out of the way and yes, nothing wrong with cleaning, inspecting and repacking with new grease at the same time. Having a way to support the flywheel end of the engine to save strain on the mounts etc is helpful.
It's so easy to remove the shifter, but so often is forgotten. Used to see the same problem when folks were pulling their bus engines. _________________ ☮️ |
Posted: Wed Apr 07, 2021 1:51 pm Post subject: Re: Rear main seal and what else? |
You're making me feel better and better. :)
Scott and his crew are pretty good about "little details" like supporting the motor.
Barring surprises (brave statement), this looks like a one day project. Yes? No? _________________ Lord, give me coffee to change the things I can change, and wine to accept the things I can't change. |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4772 Location: Bemidji, MN
Posted: Wed Apr 07, 2021 2:06 pm Post subject: Re: Rear main seal and what else? |
aaaand remember that "front is front" and we're talking the FRONT seal! _________________ -dan
www.thefixitworkshop.com
Posted: Wed Apr 07, 2021 2:12 pm Post subject: Re: Rear main seal and what else? |
Thanks for the recommendations.
Yep, manual, four speed (there are some five speeds, no?).
SpeedSleeve?
Yeah, my inclination was to call the seal the front seal, too, but the guy that diagnosed the problem went for "real". Thom's also a Westy owner, as well as wizard mechanic. _________________ Lord, give me coffee to change the things I can change, and wine to accept the things I can't change. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32586 Location: Reading Pennsylvania
Posted: Wed Apr 07, 2021 2:35 pm Post subject: Re: Rear main seal and what else? |
hardway Samba Member
Joined: January 03, 2012 Posts: 416 Location: Fidalgo Island
Posted: Wed Apr 07, 2021 2:50 pm Post subject: Re: Rear main seal and what else? |
The Reinz and Elring main seals have a Viton sealing surface. They are what I use. Make sure that whoever replaces the seal knows about the endfloat shims under the seal. |
Posted: Wed Apr 07, 2021 3:16 pm Post subject: Re: Rear main seal and what else? |
About the shims, I don't have my Bentley here, are they listed or described there? _________________ Lord, give me coffee to change the things I can change, and wine to accept the things I can't change. |
Posted: Wed Apr 07, 2021 3:18 pm Post subject: Re: Rear main seal and what else? |
Also, isn't there some plastic (well, not metal) fuel plumbing that needs to be replaced. I'm guessing it runs around the front top of the engine compartment. _________________ Lord, give me coffee to change the things I can change, and wine to accept the things I can't change. |
Posted: Sun May 09, 2021 4:41 pm Post subject: Re: Rear main seal and what else? |
Job complete. No leaks. Yet. :) _________________ Lord, give me coffee to change the things I can change, and wine to accept the things I can't change. |
4Gears4Tires Samba Member
Posted: Mon May 10, 2021 6:54 am Post subject: Re: Rear main seal and what else? |
djkeev wrote: |
These are the brands that come in the rebuild kits.......
Step 1 - rip open the gasket package
Step 2 - toss the seals into trash.
Dave |
I did not know this. I used whatever was in the rebuild kit when I did all the exterior seals when I put the 1.9 back in the Syncro. Only 4k miles (which is also surprising it's made it 4k miles) and I can see oil mist forming next to the crank pulley seal. Irritating. _________________ '87 Syncro
tuanis Samba Member
Posted: Mon May 10, 2021 11:15 am Post subject: Re: Rear main seal and what else? |
RBEmerson wrote: |
Job complete. No leaks. Yet. |
How long did it end up taking you? Single day? Any big surprises? _________________ 1989 Westfalia - 2.5L Subie
1988 VW Westfalia - Stolen |
Posted: Mon May 10, 2021 7:40 pm Post subject: Re: Rear main seal and what else? |
Surprised? You bet!
First, I let Motorcar Makeovers, my bespoke repair guys, do the job. Doing the seal is easy, pulling the transaxle is past my resources.
The surprise was the flywheel was a disaster. It was dished, not flat. The area of best clutch contact was a band, the edge, 3/4 to 1 inch wide!!! There were signs of contact further in. A band, about 2 inches wide, at the inner part of the flywheel was untouched. WTF!?!
I bought a replacement from Van Cafe, and had it sent overnight. I'd planned to replace the clutch "just 'cause now's as good a time as any". Replacing the clutch became "got no choice about this".I
Doing the job of pull the TS, pulling the flywheel, replace the seal was 4-6 hours (guessing). Replacing the flywheel was the same as re-installing the old flywheel. The clutch probably added an hour. Call it a "day and bit" ignoring waiting for UPS. _________________ Lord, give me coffee to change the things I can change, and wine to accept the things I can't change. |
