FNCuban Samba Member
Joined: December 05, 2020 Posts: 2 Location: New Freedom, Pennsylvania
Posted: Wed Apr 07, 2021 3:07 pm Post subject: Can't open drivers door on 1959 ragtop beetle. |
OK, looks like the door lock mechanism failed. How do I get the door open so I can remove and replace it? Have the door panel off and the interior lever is still connected and operates the door lock mechanism. The outside door handle operates the door lock mechanism and I even slipped a screwdriver between the post and door handle lever to get more post travel .... nothing. |
mukluk Samba Member
Posted: Wed Apr 07, 2021 3:51 pm Post subject: Re: Can't open drivers door on 1959 ragtop beetle. |
There's a chance the door latch may be jammed part way between open and latched. I'd try bumping the door shut somewhat forcefully then pushing it inward while operating the handle to see if that frees it up. _________________ 1960 Ragtop w/Semaphores "Inga" |
my59 Samba Member
Joined: August 13, 2003 Posts: 3793 Location: connecting the dots
Posted: Wed Apr 07, 2021 4:09 pm Post subject: Re: Can't open drivers door on 1959 ragtop beetle. |
Pm me an email address, I can send copy of door lock info from '59 shop manual.
I'd start by looking into the other side door handle setup and compare. The difference is the lock on driver side _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget. |
Posted: Thu Apr 08, 2021 4:49 pm Post subject: Re: Can't open drivers door on 1959 ragtop beetle. |
Got the door open!!!!
I has able to get a small (reading glasses) screwdriver between the door and the striker plate to push up on the latch. The latch was actually broken and pushed up into the door lock mechanism. The strike plate had a bit of wear indicating that the latch may not have been moving freely for a while.
My next step was probably a sawzaw as I could get a blade through the door gap. Don't know if I could have taken the door hinge pins out as well. Anyone else have to resort to these last two options?
Attached pics of broken latch.
