The 1600 "grenade", Placing bets
When will i pollute the ground with oil a and bits of con rod?
On break in
3%
 3%  [ 2 ]
3rd start up
1%
 1%  [ 1 ]
50 miles down the road
3%
 3%  [ 2 ]
3k miles down the road
15%
 15%  [ 9 ]
15k miles down the road
27%
 27%  [ 16 ]
50k miles down the road
48%
 48%  [ 28 ]
Total Votes : 58
txoval
txoval is offline
PostPosted: Sun Apr 25, 2021 5:38 am    Post subject: Re: The 1600 "grenade", Placing bets Reply with quote
I think I have set of bolted end/solid rocker shafts with stock VW rockers.
I can look later today if you want them, adjusters are in decent shape
*edit - found them if you want them
Chickensoup
Chickensoup is offline
PostPosted: Sun Apr 25, 2021 6:26 am    Post subject: Re: The 1600 "grenade", Placing bets Reply with quote
That should work well considering the current ones feel a bit stiff lol. Sending pm.
-'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'65 Tourist Delivery Build
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge"
Chickensoup
PostPosted: Sun Apr 25, 2021 1:36 pm    Post subject: Re: The 1600 "grenade", Placing bets Reply with quote
ok guy, ive got everything i need ordered however, the only place i can find a center ring clip for the pressure plate is on CB and ACN.
Does anyone happen to have any new or used ones for sale? thanks
this is what im referring to,
https://vwparts.aircooled.net/Pressure-Plate-Collar-Early-Style-X-Shaft-p/pressure-plate-collar.htm
'66 RIP
'69 RIP
Chickensoup
PostPosted: Sun Apr 25, 2021 5:53 pm    Post subject: Re: The 1600 "grenade", Placing bets Reply with quote
Alright we're going all on out on this one Laughing
we got...
clear dizzy cap
bright red china wire set
red intake boots
chrome bits
and empi mania
oh and btw, dont weld in sandles. me think me have 3 IQ
that should be all i need aside from that clutch piece.
'66 RIP
'69 RIP
madmike
madmike is offline
PostPosted: Mon Apr 26, 2021 4:33 am    Post subject: Re: The 1600 "grenade", Placing bets Reply with quote
u can weld in 'sandals' just leave the socks off Laughing Laughing
'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
"If I'm ever on Life Support,UNPLUG Me, Then Plug me back In see if that Works"
66brm
66brm is offline
PostPosted: Mon Apr 26, 2021 5:26 am    Post subject: Re: The 1600 "grenade", Placing bets Reply with quote
Now that you've put all that stuff on it'll probably do 1000000 miles
Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote:
I am an expert at fitting things in holes, been doing it a long time
Chickensoup
PostPosted: Mon Apr 26, 2021 5:36 am    Post subject: Re: The 1600 "grenade", Placing bets Reply with quote
Hey you cant that its 2021 you might offend someone Wink Smile Laughing
'66 RIP
'69 RIP
Brian_e
Brian_e is offline
PostPosted: Mon Apr 26, 2021 8:30 am    Post subject: Re: The 1600 "grenade", Placing bets Reply with quote
Yep! Socks are just spark magnets.
Built my first big Jeep in flip flops, no socks, and an old stick welder cranked way up. Just gotta learn how to shake out the hot ones while keeping a bead going.
Brian
www.type-emotorsports.com
mark tucker
mark tucker is offline
PostPosted: Mon Apr 26, 2021 8:37 am    Post subject: Re: The 1600 "grenade", Placing bets Reply with quote
Ive had them hot fuckers in my shews no mater what I was wearing...dont worry it may up your IQ..... Shocked keep on playing.
Chickensoup
PostPosted: Mon Apr 26, 2021 8:39 am    Post subject: Re: The 1600 "grenade", Placing bets Reply with quote
Nah. What's makes me stupid, is that what burnt me, was the filler rod I dropped on myself.
The nice thing about tig, is that the molten bits dont usually jump unless they have reason.
Also, I think I've found the toughest brocken exhaust stud in the universe. I'll post up on that later
'66 RIP
'69 RIP
Ceckert64
Ceckert64 is offline
PostPosted: Mon Apr 26, 2021 4:31 pm    Post subject: Re: The 1600 "grenade", Placing bets Reply with quote
It will last a long time before you have trouble. I always think when I first get on the highway, “is this the day?” I would just be sad to send a con rod through the original #s matching case on my VWs, but I know I have plenty of spare engines. As long as you listen to it, you will catch it before the con rod is out side the case. You know how many people have owned VWs and been clueless about them? And most didn’t get completely destroyed Laughing Worst case, you have a bonfire with the engine Anxious
Keep up the good work!
1972 Sierra Yellow Tin Top Westfalia Camper
“Fitz” 1971 Westfalia Poptop
Chickensoup
PostPosted: Mon Apr 26, 2021 5:02 pm    Post subject: Re: The 1600 "grenade", Placing bets Reply with quote
nah. whats scary is flooring a 300,000+ mile 55 dodge poly up a hill.
If you do that enough times, you drop a valve Wink
clueless is half the people on this site. not thats theres anything wrong with that... i think Shocked Smile
Today we gather around and mourn for those we lost.
4 1/8th drill bits, 3 left hand drill bits of various sizes, 2 EZ outs, and 8 original 13mm VW bolts lost their lives trying to save a cylinder head...
no but this exhaust stud is stupid stuck. ive tried welding them to the stud, putting the stud in a vice and rotating the head, vice grips, etc.
Oh and drills dont really "drill" into this material. especially when your trying to drill through stud and the end of an EZ out lol.
so i just decided to grind and then drill the hole out(ok that sounds funny) oversize and re tap it. I think it will work.
nice and sharp so the ark doesnt burn the nut in the process.
'66 RIP
'69 RIP
cptcrusty1
cptcrusty1 is offline
PostPosted: Mon Apr 26, 2021 7:29 pm    Post subject: Re: The 1600 "grenade", Placing bets Reply with quote
I would have tossed that head through the back window of the car by now. Makes my minor carb issues seem.... well... minor.
oprn
oprn is offline
PostPosted: Tue Apr 27, 2021 8:08 pm    Post subject: Re: The 1600 "grenade", Placing bets Reply with quote
You know the saying... "When the going gets tough, the tough get going!"
We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age)
evanfrucht
evanfrucht is offline
PostPosted: Wed Apr 28, 2021 10:36 am    Post subject: Re: The 1600 "grenade", Placing bets Reply with quote
Basic question, but that bolt you welded was to extract the stud right?
How'd that go?
Do you plan to stick a case saver in there?
I've heard you can sometimes stick a very small peice of copper tubing, build up a bead inside the hole with a MIG, then weld a nut to top. Then, if your lucky, you can unscrew the broken off bolt or stud that is inset deep, even broken off as much as 1" below the surface AND without messing up the threads.
1967 Bug ( the daily rod )
1964 Fury Wagon ( the pavement shredder )
Chickensoup
PostPosted: Wed Apr 28, 2021 10:42 am    Post subject: Re: The 1600 "grenade", Placing bets Reply with quote
Nope, after drilling it oversize and oblong, I said eff it.
So I used a self tapping screw until I can find another head Laughing
The exhaust ports are rotted anyhow Laughing
I just need it to last break in.
Exhaust leaks never hurt no one. Sort of
'66 RIP
'69 RIP
Chickensoup
PostPosted: Wed Apr 28, 2021 5:19 pm    Post subject: Re: The 1600 "grenade", Placing bets Reply with quote
Pistons and cylinders came in. I think I like AA better. They didnt oil them so theres a tiny bit of scuffing but I'm no worried about it
And the rockers from txoval came in. Rockers rotate nice!
'66 RIP
'69 RIP
mark tucker
PostPosted: Thu Apr 29, 2021 10:54 am    Post subject: Re: The 1600 "grenade", Placing bets Reply with quote
be sure to flush out the rocker oil gally passages and make sure they are all clear and not coked up.
Chickensoup
PostPosted: Thu Apr 29, 2021 1:42 pm    Post subject: Re: The 1600 "grenade", Placing bets Reply with quote
Will do! I have to take them apart to reshim them anyhow so I may as well.
I got the rings gapped( they were real close from factory but I went by the bently manual specs).
I had time to assemble one piston, lube it, and seal the cylinder.
Also, somehow the cylinders are AA brand. Idk about the pistons.
They must all come from the same factory.
Oh and those oil control retainer rings... are really flexible. I've never installed ones this flexible.
'66 RIP
'69 RIP
txoval
txoval is offline
PostPosted: Thu Apr 29, 2021 3:25 pm    Post subject: Re: The 1600 "grenade", Placing bets Reply with quote
Glad you got the rocker set. Definitely clean out and re-shim. They are fairly clean, but have been sitting for awhile.
Page 2 of 8
