When will i pollute the ground with oil a and bits of con rod? |
On break in |
3% |
[ 2 ] |
3rd start up |
1% |
[ 1 ] |
50 miles down the road |
3% |
[ 2 ] |
3k miles down the road |
15% |
[ 9 ] |
15k miles down the road |
27% |
[ 16 ] |
50k miles down the road |
48% |
[ 28 ] |
Total Votes : 58 |
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Tue May 18, 2021 7:17 pm Post subject: Re: The 1600 "grenade", Placing bets |
Rome wrote: |
Quote: |
Swapped push rods. I think it was the forging on that one rocker. All is good now tho. |
Probably too late now that you mention that "all is good"", but in my experience when I installed solid rocker shaft kits and the shims that go between the rocker arms and the rocker blocks, there is a very small amount of play if you push the rocker shaft laterally. This is after setting the rockers and spacers to reduce the side clearance as close to 0.005". I mark the center spacer tube with a touch-up paint stick or paint pencil with either "R" or "L" and an arrow which indicates in which direction to push the shaft to create that freeplay. If you tighten the rocker assembly and find that any of the rockers are tight, then just loosen the 2 fastening nuts on the rocker blocks and push the shaft laterally to create that tiny free clearance. Once you have achieved that so the rocker arms rotate freely, tighten the 2 rocker block nuts. |
hi. i did somewhat notice what your talking about although i didnt think about the last part you mentioned. one of the testings i did was i removed the push rods and fastened the shaft assembly. none of the rockers were binding which meant the bolts and washers on the outer ends were too tight.
the only other idea i have relating to the issue is maybe the blocks that fasten the assembly down have been shaved or are shorter than stock. but i think the mix match rockers is more likely. idk for sure tho.
thanks _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'65 Tourist Delivery Build
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge" |
Posted: Tue May 18, 2021 7:26 pm Post subject: Re: The 1600 "grenade", Placing bets |
so today i made basically no progress aside from getting the exhaust bolted up and rigging a remove starter button. i was gonna run it today but ran into two issues.
1, it was raining.
2, my wiring isnt right.
so, heres my issue. the smaller positive lead that comes from the better terminal causes my engine not the spark when i have it wired to the B+ terminal on the regulator even tho the diagram tells me thats where it should be.
however, when i hook the positive lead to the positive side of the coil, the engine does produce spark. HOWever, this causes the idle valve and choke element to get nice and toasty. both of which are connected to the positive side of the coil.
so what am i missing? i have the green wire from the dizzy hooked up to the negative side of the coil. i have all 3 generator leads connected to the voltage regulator. i have ground. i have the main positive lead going to the starter.
help would be great. the electrical realm isnt something im profitiant in. i think i spelt that wrong. _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Teeroy Samba Member
Joined: April 20, 2003 Posts: 3685 Location: Eastern WA
Posted: Tue May 18, 2021 7:57 pm Post subject: Re: The 1600 "grenade", Placing bets |
Forget hooking up gen/reg. Just wire starter to battery and a hot lead to coil positive (still need jumper to idle jet and choke) _________________ Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org |
Posted: Wed May 19, 2021 12:14 pm Post subject: Re: The 1600 "grenade", Placing bets |
Teeroy wrote: |
Forget hooking up gen/reg. Just wire starter to battery and a hot lead to coil positive (still need jumper to idle jet and choke) |
Yeah that sounds like a better idea. Thanks
Today so far I've gotten the chassis out of the basement so I can tidy up a few last small things and start it up. You can see how dirty my chassis is from debri landing on it but oh well. I need to touch up a few scratches anyhow.
Also, does anyone happen to know what the thread size is for the oil filler neck?
Thanks _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Posted: Fri May 21, 2021 1:02 pm Post subject: Re: The 1600 "grenade", Placing bets |
I picked up the starter today. Works great! Thanks for the suggestion.
As expected, it started right up. But with 4 issues. 1 of which has been solved.
1. It was smoking, but the control ring seated after the second run. I remember one of them being kinda weird sitting in the groove. Engine doesnt smoke at all now thankfully.
2. I have a giant exhaust leak as expected.
So I will be on the look out for a new head. And I really hate the aftermarket muffler so I'm probably just gonna buy a good used merge header and j tubes.
3. Out of all the places it could be leaking oil... its leaking out of the oil filter lip. Wtf? Its tight so maybe I got a faulty seal? Idk.
4. I need to re adjust the rockers. I specs i found for side play are obviously way too large.
Other than that now i just need to fix the above problems, get it tuned properly, not just by feel lol, and make it not look like an incomplete turd
The first video is me starting it for the very first time, the second video is the second ir third time starting it. Sounds way out of tune but at least it runs. Idk even knowing it has oil preassure yet. A sender unit is in the list.
Right now I have a "german" 009, and a h31/30. I've heard it's an ok set up.
Question- which vacume nipples should be plugged? Where can I find a diagram?
Thanks
https://youtube.com/shorts/uLqYb7mbJk4?feature=share _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Posted: Thu May 27, 2021 4:05 pm Post subject: Re: The 1600 "grenade", Placing bets |
So I got the engine tuned, timed, and idling. I'm kinda surprised at how quick the throttle response is.
So now that I know it's a good runner, I'm taking it back down to a long block so I can replace the one head, adjust the rocker assemblies and valves, change the oil, paint the tins, and figure out the correct length oil lines. I figured out where I want the filter to go. I'm putting it in the coil location and then relocating the coil to the other side
I also have a set of elephant adjusters I was gonna use for the 1385 but figured I'd just buy another set. These ones are cb adjusters to replace the current ones.
Whoever gets this engine is gonna be set lol. _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Teeroy Samba Member
Posted: Thu May 27, 2021 6:39 pm Post subject: Re: The 1600 "grenade", Placing bets |
All the nipples should be plugged if you are running the 009. Why not step stud or thread insert the head? Way easier than changing the head. On that stud there is sometimes room to put a nut behind the flange and a longer stud _________________ Pres. Rivercity VW Club www.rcvwclub.org
ARR #3
Posted: Thu May 27, 2021 7:05 pm Post subject: Re: The 1600 "grenade", Placing bets |
Teeroy wrote: |
All the nipples should be plugged if you are running the 009. Why not step stud or thread insert the head? Way easier than changing the head. On that stud there is sometimes room to put a nut behind the flange and a longer stud |
thats wht i figured i ended up plugging all the vacume ports.
i drilled the hole oversize but the nut idea may work. thanks! _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Posted: Fri May 28, 2021 4:04 pm Post subject: Re: The 1600 "grenade", Placing bets |
Well what do you know. I was actually able to grind a bolt down and stuff it behind the exhaust flange. Thanks for the idea Teeroy!
Today, I found a stud, modified the nut, and made the exhaust purdy.
I straightened the lip out. Heres what I'd looked like before.
Removed the exchangers because I dont need or want them.
I thought it was an aftermarket muffler but it turns out it's actually german.
Btw, who makes stock size j tubes that aren't trash?
'66 RIP
'69 RIP
Posted: Sat May 29, 2021 4:05 pm Post subject: Re: The 1600 "grenade", Placing bets |
Got some more tons prepped and painted. Bolted down the exhaust. Started assembly.
'66 RIP
'69 RIP
mark tucker Samba Member
Posted: Sat May 29, 2021 4:14 pm Post subject: Re: The 1600 "grenade", Placing bets |
just because it says germany dont mean it's og....just that it might of come from germany...befor or after manufacture...or not. lotsa sneeky places that have things stamped or claim 1 thing but in reality it may be another....but your probably good to go with that one. |
Posted: Sat May 29, 2021 4:34 pm Post subject: Re: The 1600 "grenade", Placing bets |
Original or not. It fits and fits well. Which is the good part _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Rome Samba Member
Joined: June 02, 2004 Posts: 9638 Location: Pearl River, NY
Posted: Sat May 29, 2021 5:55 pm Post subject: Re: The 1600 "grenade", Placing bets |
You DO have a wavy lockwasher under each of the muffler flange nuts, don't you?
Posted: Sat May 29, 2021 7:33 pm Post subject: Re: The 1600 "grenade", Placing bets |
Rome wrote: |
You DO have a wavy lockwasher under each of the muffler flange nuts, don't you? |
. Nope. everyother car ive removed headers from never had lock or wavy washers. or lock nuts. So i just assumed. I will fx it tho. thanks
Also, the cip1 hardware kit for the exhaust is GARbage. 3/4 of the nuts no joke self detonated their own threads at low torque. It was pitiful. really
so i popped some german higher grade m8 x 1.25 nuts and they are strong as can be. just thought id share.
but i do have me some wavy washers on the intake studs ov course _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Posted: Sun May 30, 2021 1:16 pm Post subject: Re: The 1600 "grenade", Placing bets |
Wow. This makes 0 cents. Engine only wants to back fire out of the carb. I got it to run once on some dumb ass combination 180 degrees out. And it ran like crap that way.
Firing order is correct.
Timing is currently back to how I had it.
I've replaced the coil, condenser, rotor, cap. And still no change. Sa.e thing.
I even static timed the thing like 5 times making sure I wasnt crazy
I also checked valve lash and that hasnt changed.
Fuel delivery is still good.
This thing started up on a dime last time I had it running which was like 4 days ago.
All I've done mechanically sense then was fix my vacume leaks and my exhaust leak.
This is just embarrassing
'66 RIP
'69 RIP
Posted: Sun May 30, 2021 1:34 pm Post subject: Re: The 1600 "grenade", Placing bets |
Yup. It was something stupid. Firing order was off. I went by ild pictures. Which makes no sense because I set the order per how vw wants it. And my dizzy isnt backwards. Runs better than before now. _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Rome Samba Member
Posted: Sun May 30, 2021 1:57 pm Post subject: Re: The 1600 "grenade", Placing bets |
I checked a few photos of the 009 I have on my Ghia's 1600. The distributor body is clocked so that the condenser is pointing to the left; if viewed from above it'd be at the "9:00" position. Your condenser is now at the "6:00" position... but you had it at the "9:00" position several photos up, seen here:
Have you checked where your distrib. drive gear lateral slot is positioned when cylinder #1 is at its TDC position? If you lift up the distrib and view the drive gear, the center slot is milled off-center. The smaller crescent portion needs to be pointing rearward like here (Danwvw gallery). Install the distrib so that the tang at the driveshaft fully engages into the slot. Rotate the distrib. body so the rotor points to the small notch on the edge of the distrib. body. Fully push the distrib. down. Snap on the cap so that the #1 plug cable is in the terminal above that notch. But you probably know all this.
Posted: Sun May 30, 2021 4:37 pm Post subject: Re: The 1600 "grenade", Placing bets |
it dont matter where the condensor is aimed at as long as its timed right with the right firing order...the dist dont know witch is #1 nor does the cap. thats up 2u to get right. it's when you have the vac canaster on there that you really need to get the gears right or somethen may not fit... even when rotating the wires... on some...but normaly you can. as for the ex wavy washers...I like them and use the brass nuts .Ive never had any issue with them I also use the copper gadgets. |
Rome Samba Member
Posted: Sun May 30, 2021 9:54 pm Post subject: Re: The 1600 "grenade", Placing bets |
I agree, Mark. I should've mentioned with my observation of the distrib. body that the body itself appeared to be 1/4 turn CCW from previously but the cap and wire orientation remained unchanged. What soup can do easily is to simply reindex his plug wires 1/4 CCW in the cap: Pull up the wire going to #1 and put in the #4 wire. Go around the cap CCW similarly per the firing order. |
Posted: Mon May 31, 2021 11:49 am Post subject: Re: The 1600 "grenade", Placing bets |
Thanks for refreshing my memory Rome. When I installed the dizzy I didnt really mind which way it was facing so I stuck it in so that the numbers were facing the front of the engine. I think the confusion here was that the old photo you posted, i think I hadent timed it yet. Thanks for the help tho.
So I've got another "issue". I re shimmed the rockers which went well, but these epehant feet are needing ALOT of shimming. I've got 3 shims per side on there and I think each are 40 thousands or 1mm. Or 3mm in my case. And I still can get any lash.
I've got a stock cam, lifters, push rods, rockers. Should it take this much shimming? Yes, the adjusters are loosened all the way.
On the positive side, it looks like CB pre soaked the adjusters which is nice.
Is it normal to have to be forced to clearance the rocker ends even in a stock application for the elephant feet?
Thanks
'66 RIP
'69 RIP
