storm Samba Member
Joined: April 28, 2008 Posts: 299 Location: Juneau, Wisconsin
Posted: Sun Apr 11, 2021 3:36 pm Post subject: Re: Head temp on #2 says I am hotter than the rest. |
Storm here. More ideals what to do, Bugsy61 says to test all 4sensors in boiling water. Swap the cooling reading with the hot one and see if there is a difference. Also I guess I am not alone Tattooed pariah says he has the same problem. As he solved his problem and what did he do to fix it. _________________ always ready to learn and give advice |
tattooed_pariah Samba Member
Joined: April 24, 2006 Posts: 2047 Location: El Cajon, CA
Posted: Sun Apr 11, 2021 6:02 pm Post subject: Re: Head temp on #2 says I am hotter than the rest. |
storm wrote: |
Storm here. More ideals what to do, Bugsy61 says to test all 4sensors in boiling water. Swap the cooling reading with the hot one and see if there is a difference. Also I guess I am not alone Tattooed pariah says he has the same problem. As he solved his problem and what did he do to fix it. |
no i didn't solve it at all.. I made it a little better, but it's not solved.
My carbs were out of sync and my jetting was too rich, I would regularly see #2 almost 100F hotter than #3..
I spent some time syncing my carbs and threw in some smaller jets and it's running a little happier, but #2 is still like 40-60F hotter than #3..
I just took it out today though and maintained about 80mph on a reasonably steep hill on the freeway and #2 peaked at around 330F (#3 was around 290), and then when I crested the hill temps dropped pretty fast.. by the time I hit the light at the bottom (freeway ends), #2 was around 260 and #3 was around 210..
So I still have some work to do, but it's happier than it was.. _________________ -pariah (just a novice from "that other VW site")
'72 Volksrod "Effigy"
"Never worry about stepping on people's toes. People who get their toes stepped on are either sitting down, or standing still on the job."
-Admiral Arleigh Burke, USN(ret.) |
storm Samba Member
Posted: Mon Apr 12, 2021 6:39 am Post subject: Re: Head temp on #2 says I am hotter than the rest. |
Storm here, Ray Greenwood, the engine is type 1 configuration. Tattooed pariah, your temps are normal I can’t see any problem with high temps, Wreck, the Omega thermocouple looks interesting. Thanks _________________ always ready to learn and give advice |
Posted: Mon Apr 12, 2021 12:15 pm Post subject: Re: Head temp on #2 says I am hotter than the rest. |
storm wrote: |
Storm here, Ray Greenwood, the engine is type 1 configuration. Tattooed pariah, your temps are normal I can’t see any problem with high temps, Wreck, the Omega thermocouple looks interesting. Thanks |
I don't think they look high, but I was always told that #3 should be your hottest, with #4 being slightly hotter than 1 and 2 due to proximity to 3. and 1 and 2 would be about the same as each other..
Mine seems to be spun 180 degrees.. 3 and 4 are close to each other, and lower than 1, with 2 being my hottest cylinder.. _________________ -pariah (just a novice from "that other VW site")
bsairhead Samba Member
Joined: October 08, 2008 Posts: 3579 Location: viroqua wi.
Posted: Mon Apr 12, 2021 2:24 pm Post subject: Re: Head temp on #2 says I am hotter than the rest. |
Just for the heck of it try checking your timing at every plug. Of course you will need a degreed pulley or 12-3-6-9 marks on pulley or degreed template. Maybe you have an off lobe or off magnet on your distributor. |
storm Samba Member
Posted: Mon Apr 12, 2021 3:09 pm Post subject: Re: Head temp on #2 says I am hotter than the rest. |
Storm here, bsairhead, thanks for that tip. I did change the distributor to CB Magaspark 2. I normally run a vacuum distributor, but my Spanish IDF Weber’s don’t have enough vacuum. I will try with my timing light on #3 spark plug and see if it matches #1 spark plug. _________________ always ready to learn and give advice |
storm Samba Member
Posted: Mon Apr 12, 2021 3:13 pm Post subject: Re: Head temp on #2 says I am hotter than the rest. |
Storm back, correction will try on #2 spark plug instead #3. _________________ always ready to learn and give advice |
storm Samba Member
Posted: Thu Jun 10, 2021 1:40 pm Post subject: Re: Head temp on #2 says I am hotter than the rest. |
Storm here, problem solved. #2 side of head was hitting temps of 350-410 degrees on a 90plus day. Went on You Tube and watched a video about the idle circuit. I was only thinking that the idle jet itself was clogged. Not so, The video name from is Vic Ferrari’s Weber idle circuit plugged and cleaning. There is a lot info about this circuit. That was my problem. My circuit was on the rich side also and did not do that lean mixture pop pop sound. So I cleaned the whole system and the temps went down. Today it’s 95 degrees, out with my micro bus going 55 mph head temp of #2 was 275-290 degrees, oil pressure 42, oil temp 190. I did go down on the main jet by 5 and better running engine. Thanks everyone for their input. _________________ always ready to learn and give advice |
orwell84 Samba Member
Joined: May 14, 2007 Posts: 2539 Location: Plattsburgh, New York
Posted: Thu Jun 10, 2021 7:34 pm Post subject: Re: Head temp on #2 says I am hotter than the rest. |
Sounds like a nice cool running engine especially pushing a bus on a hot day. Nice tidy tuning. |
brightcourse Samba Member
Joined: June 19, 2014 Posts: 41 Location: Rochester, NY
Posted: Wed May 17, 2023 2:48 pm Post subject: Re: Head temp on #2 says I am hotter than the rest. |
Here is what we have tried:
Removed the crush washer on the #3 Spark Plug, and reinstalled the TC.
Capped the vacuum port that runs to break the servo on the #3/4 side. (still getting vacuum from the #1/2 side carb)
Richened the mixture a quarter turn on #3 and #4
Sad to report no changes in the CHT for #3 and #4.
Randy |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21519 Location: Oklahoma City
Posted: Wed May 17, 2023 4:20 pm Post subject: Re: Head temp on #2 says I am hotter than the rest. |
brightcourse wrote: |
Randy |
Good!
Did you verify no leaks around the threads with a cranking test and soapy water?
Ray |
