dr8track Samba Member
Joined: July 18, 2005 Posts: 496 Location: Seattle area
Posted: Thu Apr 08, 2021 4:14 pm Post subject: 74 Campmobile Propane Tank Parts |
I'm wanting to get my propane system operational on my 74 Deluxe Campmobile. I've had the bus about 15 years and have never attempted to see if it was operational. I wasn't even certain if it was functional if modern regulations would allow it to be filled. Yesterday I called a place and they said, Sure! Bring it by! I wanted to put some propane in the tank and check for leaks.
The first problem showed up when he started to fill it up. The bleeder valve was missing. He had one that fit anf put abput a gallom of propane in the tank.
No obvious leaks so I drove it home for further testing. As soon as I turned the propane faucet to turn on the propane... major leak. Doesn't leak when its off, but leaks a lot with it turned on.
In retrospect I should have replaced all the parts and THEN tested it. But I didn't so I'm stuck with a couple problems.
1. Any recommendations where I can purchase a shut off valve and a single stage regulator? I've checked a few local and online sources and have had no luck.
I'll replace the hose too, but I figure I should be able t find that locally. The next question is how do I get rid of the propane in the tank without blowing up the neighborhood? Could I drive to a remote open area and just open the valve and let it all leak out? _________________ 1974 Westfalia Deluxe Campmobiles - Lake Stevens, WA |
cml039 Samba Member
Joined: September 22, 2010 Posts: 50 Location: Denver
Posted: Fri Apr 09, 2021 10:48 am Post subject: Re: 74 Campmobile Propane Tank Parts |
Anyplace that deals in gas, like welding suppliers, can pressure test, clean, and certify your tank for refilling. They'll also have new valves, etc. They do this kind of stuff all the time. |
Posted: Fri Apr 09, 2021 6:43 pm Post subject: Re: 74 Campmobile Propane Tank Parts |
Found a place. Unforetunately the earliest appt is May 18> Scheduled and will continue to look for somewhere I can get in earlier. _________________ 1974 Westfalia Deluxe Campmobiles - Lake Stevens, WA |
Slip356 Samba Member
Posted: Sun Apr 11, 2021 5:15 am Post subject: Re: 74 Campmobile Propane Tank Parts |
There’s a guy in IL that has all the parts you need, he advertises here on the Samba. I bought a new valve and some other stuff from him to rebuild my tank. Do a search, you’ll find him.
Best way to get rid of the propane is as you suggest, park in a field and let it escape. Suggest disconnecting battery first, don’t smoke! |
Posted: Sun Apr 11, 2021 5:34 pm Post subject: Re: 74 Campmobile Propane Tank Parts |
Hmmm. Searched the classifieds for "propane parts, propane Regulator" in Illinois and also in "all" and nothing comes up _________________ 1974 Westfalia Deluxe Campmobiles - Lake Stevens, WA |
The Volkswagen Ranch Samba Member
Joined: November 24, 2002 Posts: 699 Location: Arizona
Posted: Mon Apr 12, 2021 6:11 am Post subject: Re: 74 Campmobile Propane Tank Parts |
Google PPL RV parts in Florida. I found them in old posts, under “propane tank”.
Bob _________________ 1963 Convertible (Lizzie) and 1964 Convertible (Patience) 1976 Westfalia (Winnie) |
obieoberstar Samba Member
Posted: Tue Apr 13, 2021 8:13 pm Post subject: Re: 74 Campmobile Propane Tank Parts |
I finally redid all the fittings on my '79 tank last month. The hardest part was removing the old bits from the tank. Works great now and no problems filling. I think it took 2 gallons from completely vented.
bought this kit. made in USA.
https://www.ebay.com/itm/Propane-Cylinder-Tank-Val...Sw4Lle9NHP |
EZ Gruv King of Plaid
Joined: December 10, 2002 Posts: 8544 Location: Las Vegas
Posted: Tue Apr 13, 2021 10:22 pm Post subject: Re: 74 Campmobile Propane Tank Parts |
obieoberstar wrote: |
Thanks for the link. I'm going to give Nash Fuel a call tomorrow. I don't think a 2 stage Regulator will fit with my bracket. Do you have a photo with the new kit installed? Can you tell me what fitting connects the hose from the Regulator to the propane stove? _________________ 1974 Westfalia Deluxe Campmobiles - Lake Stevens, WA |
raydog Samba Member
Joined: February 09, 2006 Posts: 1157 Location: Cape Cod
Posted: Wed Apr 14, 2021 5:43 am Post subject: Re: 74 Campmobile Propane Tank Parts |
Don't troubleshoot with propane. Get a proper air pressure test. LP can be a nasty fuel if you have a leak in an enclosed area. _________________ Come on, It's not rocket science. KISS |
Posted: Wed Apr 14, 2021 12:54 pm Post subject: Re: 74 Campmobile Propane Tank Parts |
Yes, I hear what you're saying. I think I will just be patient and have it tested and repaired by a professional. My appointment is in a month and that's still plenty early to be ready before camping season in the NW. _________________ 1974 Westfalia Deluxe Campmobiles - Lake Stevens, WA |
Posted: Wed Apr 14, 2021 6:43 pm Post subject: Re: 74 Campmobile Propane Tank Parts |
beautiful new fittings on my tank. no problem with clearance. that protective panel is attached with nuts and bolts and can adjusted accordingly.
I had the hose for the stove remade using the original as a template years ago. It attaches to the end of the regulator with a 90 degree fitting. something like this.
Posted: Mon May 17, 2021 10:16 pm Post subject: Re: 74 Campmobile Propane Tank Parts |
I decided to take my bus to an RV repair shop to get my propane system working. After weeks of waiting my appointment is finally tomorrow. While I want to get the original Westy tank functional, I was curious about there was a way of having the option to hook up an external BBQ style propane tank too? It would be great to have the option. I'll ask the guy tomorrow but was just curious if anyone had there's set up that way? _________________ 1974 Westfalia Deluxe Campmobiles - Lake Stevens, WA |
Posted: Mon May 17, 2021 10:17 pm Post subject: Re: 74 Campmobile Propane Tank Parts |
jlrftype7 Samba Member
Posted: Wed May 19, 2021 12:23 pm Post subject: Re: 74 Campmobile Propane Tank Parts |
dr8track wrote: |
I decided to take my bus to an RV repair shop to get my propane system working. After weeks of waiting my appointment is finally tomorrow. While I want to get the original Westy tank functional, I was curious about there was a way of having the option to hook up an external BBQ style propane tank too? It would be great to have the option. I'll ask the guy tomorrow but was just curious if anyone had there's set up that way? |
I know there's a term or phrase for it, I've heard it here on Samba, along with the fitting kit that's needed to do that. It's like you thought, longer stays at a campground, with aux propane tank hooked into your system to be able to keep cooking, heating, etc, longer than what a stock tank can provide.
Found 1 example, Extend a Stay Kit- it IS for the Vanagons and not a Bay Bus, but maybe there's something out there for a Bay Tank System.
https://www.gowesty.com/product/-/23927/extend-a-stay-kit-for-gowesty-larger-capacity-lp-tank-?v= _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
Posted: Wed May 19, 2021 10:16 pm Post subject: Re: 74 Campmobile Propane Tank Parts |
I did end up having the extra fittings added to accommodate both the small Coleman bottles as well as the big BBQ propane tank. Of course the original tank can be used also.
