ChrisBarr77 Samba Member
Posted: Fri Apr 09, 2021 1:30 am Post subject: Remote Start? |
I just bought a 84 Westy automatic with a crimestopper 202 alarm / door lock system. New to reading & comprehending the Bentley.
I’m interested in upgrading to the crimestopper SP-404 which also includes remote start.
I’d like to wire in the remote start.
Trying to make sure I know exactly which wires to hook up... still need to test light the wires to know, but looking at the instructions I need the starter wire, ignition wire & accessory wires along with two 12v hots. 12v hots is easy... but the Starter & ignition aren’t clear.
I think the Black wire is the ACC... that took seems right...?
I see the Red/Black shows it’s going to the starter, but it also looks like that goes to the fuel control unit when afterwards goes to a power supply relay then through to the fuel pump relay via a Black/White wire then on to the ignition coil.
I’m confused on what goes where & really what can I use from the ignition switch wires or what needs to be ran new.
Am I supposed to run a new wire directly to the starter solenoid... or can I?
Where do I tie into for IGN... is this done directly at the coil pack?
Looks like the large 10 gauge RED is the 12v hot.
Any help would be appreciated |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Fri Apr 09, 2021 4:40 am Post subject: Re: Remote Start? |
I’m not familiar with the product and to be honest, don’t see how it can work. But all the wires you need are in the ignition plug. Heavy red is bat power. Heavy red with black tracer engages the starter. Black wire is key on power not accessory. The black and yellow wire is power in run position, but looses power during cranking with the key.
Word of caution. Don’t forget to install the key and turn it. You need to be sure you don’t drive off and have the steering lock. Also, I don’t see how it can work unless the power is continually routed through it, so I’d wire it so it can be easily bypassed if it screws up or one day when the engine won’t start. _________________ ☮️ |
Love My Westy Samba Member
Posted: Fri Apr 09, 2021 8:21 am Post subject: Re: Remote Start? |
Just a note about remote starters. I have a Dodge truck with the factory remote starter that works by pressing a button (twice) on my key fob. While it is nice when warming up the truck on a snowy day without it being stolen by some walker-by (the doors remain locked), there have been numerous instances of me walking out the door and finding my truck running when I hadn't activated the remote start. I'd have no idea how long the truck had been running. Just like the panic button, it is possible to accidently start the engine by movement in my pocket. It's a strange feeling to walk out and find your vehicle running when you didn't know you had started it, or when you had started it. |
Posted: Fri Apr 09, 2021 11:16 pm Post subject: Re: Remote Start? |
Thank you for the details on the wiring. I found a link by a different manufacturer showing the correct hookup of the remote start to the vanagon ignition. As you mentioned... heavy Red is 12v hot all time with the Red with black stripe going to STARTER. Then the black is for the IGN & Black with Yellow stripe going to ACC.
In regards to the auto start of your Dodge Truck... that’s REALLY weird. I’d be at the dealership if it happened to me. I’ve owned a 2017 Jeep Grand Cherokee since new and never once found my Jeep running on its own... that’s not a worry for me at all. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32632 Location: Reading Pennsylvania
Posted: Sat Apr 10, 2021 4:53 am Post subject: Re: Remote Start? |
Black and yellow is for the load reduction during starting. Heavy consumers are temporarily shut for max cranking voltage and reduced load. Headlights, blower, ac, rear defogger etc. _________________ ☮️ |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Sat Apr 10, 2021 8:13 am Post subject: Re: Remote Start? |
djkeev wrote: |
My problem with a remote start on a Vanagon is this.......
They aren't a vehicle you leave idling unattended. |
Well said. The first 30 seconds after a cold start up I spend confirming all is well... good oil pressure, not on fire, no white clouds of smoke, etc. |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9618 Location: Western WA
Posted: Sat Apr 10, 2021 8:20 am Post subject: Re: Remote Start? |
Ahwahnee wrote: |
djkeev wrote: |
those are examples of the self-activated engine-kill feature.
Is there a goal / reason for remote start?
Is it a desired luxury of sorts?
Remote start of an interior heater could be a useful feature for a Vanagon. _________________
....KTMs, GasGas, SPOT mtb |
fxr Samba Member
Joined: December 07, 2014 Posts: 2325 Location: Bay area CA
Posted: Sat Apr 10, 2021 8:50 am Post subject: Re: Remote Start? |
Sodo wrote: |
Remote start of an interior heater could be a useful feature for a Vanagon. |
That's why we have a CDH with an Afterburner. _________________ Jim Crowther
Vespa GTS 300 |
Posted: Sat Apr 10, 2021 9:25 am Post subject: Re: Remote Start? |
Vanagons have no ACC function, so no wire. As mentioned they do have a Load Reduction Relay and the accompanying "X" function on the ignition switch. |
jimf909 Samba Member
Posted: Sat Apr 10, 2021 11:37 am Post subject: Re: Remote Start? |
Sodo wrote: |
Ahwahnee wrote: |
djkeev wrote: |
I hate to say it, but last summer I left my reasonably well maintained Vanagon running to warm up and a coolant leak happened. Not catastrophic but it could have been.
My guess is that modern cars with remote start have a number of control modules ready to step-in if something goes wrong.
Modern cars also are remarkably easy to exit and leave running. According to a baseball announcer, so many tourists arrive at spring training games in unfamiliar rental cars that it's not unusual to hear announcements during the game saying that such and such car is in the parking lot with the engine running. _________________ - Jim
Abscate wrote: |
fxr Samba Member
Posted: Sat Apr 10, 2021 11:46 am Post subject: Re: Remote Start? |
A couple of years ago I used my son's car (some sort of Audi) in the UK - I couldn't work out how to turn it off! Still mystified. _________________ Jim Crowther
Vespa GTS 300 |
