Igeo Samba Member
Joined: September 25, 2018 Posts: 888 Location: Oakland, CA
Posted: Fri Apr 09, 2021 9:22 am Post subject: Another Mystery Wire |
I'm messing with my alternator, and once it was out, I see a cut off wire laying down there beneath it. Any ideas on what that is?
_________________ 1987 Westfalia 2.1 WBX Manual |
0to60in6min Samba Member
Joined: November 27, 2006 Posts: 3417 Location: OR & CA (Oregon/California)
Posted: Fri Apr 09, 2021 9:31 am Post subject: Re: Another Mystery Wire |
High oil pressure sender wire? The sender is behind the crank pulley. |
Igeo Samba Member
Posted: Fri Apr 09, 2021 9:39 am Post subject: Re: Another Mystery Wire |
0to60in6min wrote: |
All systems function on this van, so I don't think that's it. _________________ 1987 Westfalia 2.1 WBX Manual |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32634 Location: Reading Pennsylvania
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Fri Apr 09, 2021 9:49 am Post subject: Re: Another Mystery Wire |
Follow it forward. In general, brown wires are grounds. It looks brown in the picture. _________________ ☮️ |
brickster Samba Member
Joined: January 05, 2004 Posts: 512 Location: CO, USA
Posted: Fri Apr 09, 2021 10:06 am Post subject: Re: Another Mystery Wire |
Agree that it's a ground.
I had an 85 that generally ran well, but would digifart on the highway in certain conditions. After chasing it for months, I finally saw that this ground was not connected. Cleaned it up and reconnected and my problem vanished. |
Igeo Samba Member
Posted: Fri Apr 09, 2021 10:24 am Post subject: Re: Another Mystery Wire |
My thought was a ground also. Do you recognize this location for routing a ground wire? It's fairly heavy guage, and runs under the throttle body.
I guess I could see if it has continuity to the fuse panel. _________________ 1987 Westfalia 2.1 WBX Manual |
Posted: Fri Apr 09, 2021 10:37 am Post subject: Re: Another Mystery Wire |
I don't recall any wire routing in that location. Grounds don't run to the fusebox. They either go to the chassis or act as a ground path for a component. I'd try to fish it out from under the intake while you have that room and follow it to the other side of the engine bay. _________________ ☮️ |
Igeo Samba Member
Posted: Fri Apr 09, 2021 10:54 am Post subject: Re: Another Mystery Wire |
MarkWard wrote: |
I don't recall any wire routing in that location. Grounds don't run to the fusebox. They either go to the chassis or act as a ground path for a component. I'd try to fish it out from under the intake while you have that room and follow it to the other side of the engine bay. |
It seems to run to the bellhousing, but is hard to see under there. I thought maybe if it was connected to a component, that it should have continuity at the panel. _________________ 1987 Westfalia 2.1 WBX Manual |
Posted: Fri Apr 09, 2021 11:05 am Post subject: Re: Another Mystery Wire |
The picture is poor, but there was a vw dealer diagnostic sensor that was pressed into the engine case just in front of the throttle body. It was more of a shielded wire with a molded plug that was attached to the alternator for access. So, if that is the wire with the molded end off, you can just ignore it. _________________ ☮️ |
Igeo Samba Member
Posted: Fri Apr 09, 2021 11:36 am Post subject: Re: Another Mystery Wire |
After going through the links, I'm convinced that it's for that VW diagnostic plug that is not used and someone cut off. It does stick out of the bellhousing too- seemingly intended as a crank position sensor? Weird.
Thanks all. _________________ 1987 Westfalia 2.1 WBX Manual |
