nbvolks Samba Member
Posted: Fri Apr 09, 2021 1:25 pm Post subject: Appearance of strut mount |
It's been 1,000 miles since the full restoration and I was going over the car inspecting how the suspension has settled in. Looking at the strut mounts they both look like what's pictured below. Is that normal for this setup?
AutoMechanic Samba Member
Joined: December 28, 2019 Posts: 483 Location: Roanoke Virginia
Posted: Fri Apr 09, 2021 7:21 pm Post subject: Re: Appearance of strut mount |
It should have a nut on the top. . I don’t believe it should be raised up like that. |
Jimbug57 Samba Member
Joined: October 08, 2002 Posts: 817 Location: Mid Michigan
Posted: Sat Apr 10, 2021 1:53 am Post subject: Re: Appearance of strut mount |
Something isn't right. I'm sure you have the nut on there - just can't see it in the photo. Did you get the spacer and all the washers in there? Strut bearing may need to be replaced.
_________________ Repeat after me "I am smarter than metal!" |
Posted: Sat Apr 10, 2021 6:27 am Post subject: Re: Appearance of strut mount |
AutoMechanic wrote: |
It's there, you just can't see it. |
Posted: Sat Apr 10, 2021 6:35 am Post subject: Re: Appearance of strut mount |
Jimbug57 wrote: |
That diagram is for the 3-bolt design. I have the later setup, shown on the right in the image below, and all of those pieces are in place.
joey1320 Samba Member
Joined: September 12, 2006 Posts: 2325 Location: Cleveland, OH
Maddel Samba Member
Posted: Sat Apr 10, 2021 11:32 am Post subject: Re: Appearance of strut mount |
Not my car but...
Posted: Sat Apr 10, 2021 3:48 pm Post subject: Re: Appearance of strut mount |
Maddel wrote: |
Not my car but...
That makes me feel better.
Or both mine and that one have something off! Hahaha... |
infiniteLoop Samba Member
Joined: October 09, 2020 Posts: 265 Location: Empire State
Posted: Sat Apr 10, 2021 4:41 pm Post subject: Re: Appearance of strut mount |
Food for thought. The newer 2 bolt style strut looks like it has a nut that holds the spring seat on ,is under preload ,and has another nut that holds just the strut mount on. While the 3 bolt strut ;early super, just has one nut that holds the mount on and is under preload tension.
I assume that having the wrong hardware there has bent the big retaining washer on the top. |
Posted: Sat Apr 10, 2021 6:20 pm Post subject: Re: Appearance of strut mount |
infiniteLoop wrote: |
34a is a washer (171412369). I used that same diagram when rebuilding/restoring mine. Of course, missing from the shot is the washer, but it went on. In the diagram, everything visually from 37 up to 42, is built into/included with the strut mount itself.
