rrcade Samba Member
Joined: May 29, 2010 Posts: 735 Location: WI 1962 Bug 2276
Posted: Fri Apr 09, 2021 1:56 pm Post subject: Elec fuel pump/regulator woes |
Ok my buddy has a drag car he acquired with Berg 42 specials. Didn’t come with a pump etc.
he has the red Holley now which puts out 7 psi max
Flows 71 GPH at 4 psi. It says doesn’t require a regulator in instructions, does it ?
Engine is 2110 w FK89 and it ran mid 7s in the 8th if that helps _________________ CHEAP - FAST - RELIABLE
You can only pick two of the above. |
rrcade Samba Member
Posted: Fri Apr 09, 2021 2:01 pm Post subject: Re: Elec fuel pump/regulator woes |
What psi should this set up be running? _________________ CHEAP - FAST - RELIABLE
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Fri Apr 09, 2021 3:40 pm Post subject: Re: Elec fuel pump/regulator woes |
Never messed with them carbs but idf's only need 3 lbs. _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
Joined: May 17, 2003 Posts: 4863 Location: Harmony, PA
Posted: Fri Apr 09, 2021 6:05 pm Post subject: Re: Elec fuel pump/regulator woes |
rrcade wrote: |
Engine is 2110 w FK89 and it ran mid 7s in the 8th if that helps |
I would say it doesn’t require a regulator for V8 carbs that are run around 6psi.
I’ve also never had a set of DCNF’s, but I would assume they are like most of the common Weber/Dellorto VW used, and need less than 3psi. If that’s the case, then yes, you will need a regulator. I’ve had a Red pump with a 12-804 regulator on some HPMX’s going on 9 years. Another friend has had good results with Aeromotive’s 13204 if you are thinking of using a return line. |
croSSeduP Samba Member
Joined: June 13, 2004 Posts: 1106 Location: Western Washington State
Posted: Fri Apr 09, 2021 10:34 pm Post subject: Re: Elec fuel pump/regulator woes |
rrcade wrote: |
Regulator set to 2.5-3lbs at idle is a must. This is a good one:
https://www.jegs.com/i/JEGS/555/15911/10002/-1 _________________ Please check my '67 sedan project progress!
http://www.thesamba.com/vw/forum/viewtopic.php?t=502253&highlight= |
neil68 Samba Member
Joined: March 17, 2007 Posts: 3440 Location: Calgary, Canada
Posted: Sat Apr 10, 2021 1:11 pm Post subject: Re: Elec fuel pump/regulator woes |
I had a 1-4 psi fuel pump that consistently put out higher pressure. I installed that Holley regulator (linked above) set at 3 psi and all is well. _________________ Neil.
Der Kleiner Rennwagens
68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 107 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo |
