Royce123 Samba Member
Posted: Fri Apr 09, 2021 3:50 pm Post subject: VW 77 type 2 bay shift rod |
I am replacing the bushings and boots on shift rod while transmission is removed on VW type 2 bay. I have the bushings (3) fasten along the shift rod, but where do I fasten the boots and how do they stay in place? |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16961 Location: San Diego, California
Posted: Fri Apr 09, 2021 6:03 pm Post subject: Re: VW 77 type 2 bay shift rod |
Let’s see, you install the aft boot and then slide the rod through the tube. Then install the forward boot. The circumference of the tube holds the boots in place. A person could use rtv to help hold them and silicone grease on the rod so they slide _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
Posted: Sat Apr 10, 2021 6:32 am Post subject: Re: VW 77 type 2 bay shift rod |
if you bought a bushing kit, possible that not every bushing in the kit is used. some kits are made for both early and late and have parts for both in them. |
