Electric Choke wire grounded out!
1adam12
1adam12 is offline
PostPosted: Fri Apr 09, 2021 4:28 pm    Post subject: Electric Choke wire grounded out! Reply with quote
Shocked So, any insight greatly appreciated as I am totally scratching my head!
Car was running fine...The electric choke wire connected to its' assembly, held on with the three screwed fastener on the right side of the carb vibrated off onto the alternator. The car died on the spot with of course that familiar smell of burnt insulation of the shorted wire from the coil to both the idle solenoid and electric choke.
I was close enough to home and towed it thankfully.
I refastened the the electric choke and wire, (planning to replace the burned wire, but it should work as it is not touching anything for a test) and now I have :
no ignition lights (Gen & Oil).
no headlights and no turnover.
I also have parking lights but no headlights with the switch/key on
and no fuses blown.
Radio, wipers, signals all work....
As I am turning the key back from attempting to start, I hear a clunk in the starter (solenoid).
mighty confusing.
What else could I have damaged? the coil perhaps?! ah the mystery of electrics!!
thanks!! Embarassed
Mentionable is manageable = Fred Roger
Joe 20
Joe 20 is offline
PostPosted: Fri Apr 09, 2021 7:20 pm    Post subject: Re: Electric Choke wire grounded out! Reply with quote
Well, start with a wiring diagram in the Technical section of this site. Go from there. I don't think I'd expect a "fried" wire to work for any test. Good luck...
"Someday the world is gonna be populated by nothing but Volkswagens'" Corporal Klairvoy
Wildthings
Wildthings is offline
PostPosted: Sun Apr 11, 2021 10:01 pm    Post subject: Re: Electric Choke wire grounded out! Reply with quote
Yous shorted out the unfused #15 ignition circuit and since the wires to the choke coil are pretty small they would have acted as a current limiting device preventing the main #15 wire and ignition switch from going into an instant melt down, instead the heat in the switch built up over several minutes deforming the plastic in the switch. A new switch should solve your problems.
