aa390392 Samba Member
Posted: Fri Apr 09, 2021 6:40 pm Post subject: Dies when coming to a stop....carb issue |
I know 36hp but DP stuff i got nothing..Lind or Eric&Barb? Knowledge
Eng. Is DP 1600 ..rebuilt to 1776..it runs great, it starts right up, but when I take it a spin, and let up off gas pedal, it dies... enclosed is pic of carb, anybody see externally what it might be or why... will supply more pics if necessary. thanks..
Tomas _________________ .
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9966 Location: Huntington Beach, CA
Posted: Fri Apr 09, 2021 10:27 pm Post subject: Re: Dies when coming to a stop....carb issue |
Usually the carb is loose on the intake manifold. Vacuum leak.
Or the boots have cracks that open up with the engine temp change. Vacuum leak.
End casting are loose or have sucked part of a gasket. Vacuum leak.
I would go through the basic carb settings, along with a full tune up. The issue most likely be found during the tune up or a pathway will become ever present.
Start with a tune up and setting basics. If the basic settings cannot be used, you need to chase, why that is.
Good luck! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Posted: Mon Apr 12, 2021 8:00 am Post subject: Re: Dies when coming to a stop....carb issue |
Ok, I said I have limited knowlwdge with 36 carbs.
But Dual ports are whole new beat to me.
I get carb may be loose on manifold.
But boots? What are boots?
No idea what "end castings" are? Nor what gaskets your refering to.
Basic carb setting? Hell I dont even know what carb this is?
Chase what?
In my book learning, carburetor in latin means do not touch...
Someone please be a bit more explicit...
Thanks
55 ragtop
56 delux sedan
56 Kabriolet |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34009 Location: Conejo Valley, CA
Posted: Mon Apr 12, 2021 9:08 am Post subject: Re: Dies when coming to a stop....carb issue |
You said you have a DP 1600 motor. On that motor, the intake manifold is in three pieces: a center section, and two end castings the bolt to the heads. These two castings are joined to the center section with rubber boots and clamps.
Posted: Mon Apr 12, 2021 9:15 am Post subject: Re: Dies when coming to a stop....carb issue |
Thanks for clarifying, _________________ .
55 ragtop
56 delux sedan
56 Kabriolet |
KTPhil Samba Member
Posted: Mon Apr 12, 2021 9:24 am Post subject: Re: Dies when coming to a stop....carb issue |
VW_Jimbo wrote: |
Start with a tune up and setting basics. If the basic settings cannot be used, you need to chase, why that is. |
X2. I repeat this advice often, but it's valid. A tune-up will often reveal what is broken, misadjusted, worn out... and if not, you have eliminated the easy/free stuff before you contemplate replacing expensive components. |
