croSSeduP Samba Member
Joined: June 13, 2004 Posts: 1106 Location: Western Washington State
Posted: Fri Apr 09, 2021 10:09 pm Post subject: What Size Set Screw? |
Went to crank for oil pressure before firing my motor for the first time and had a HUGE oil leak. How in the world I missed this...
Oh, well. Any idea what the size of these threads are so I can get the correct set screw? Is there a "standard" set screw size among those who do case machining? Thanks! _________________ Please check my '67 sedan project progress!
http://www.thesamba.com/vw/forum/viewtopic.php?t=502253&highlight= |
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Sat Apr 10, 2021 5:32 am Post subject: Re: What Size Set Screw? |
Should be 1/16” NPT |
Brian_e Samba Member
Joined: July 28, 2009 Posts: 3293 Location: Rapid City, SD
Posted: Sat Apr 10, 2021 5:55 am Post subject: Re: What Size Set Screw? |
It should be a pipe plug, and not a set screw.
That location also had a long stepped dowel plug in the hole. Different from all the other plugs. Some say the step is to regulate the flow to the #4 bearing, some say it's more of a filter to stop big chunks from getting to the tiny oil hole in the bearing. I agree with the latter.
I never pull or replace that plug. Just clean the passage good and leave the stepped plug in place.
Go get a 1/16npt pipe plug and put it in there.
Brian _________________ www.type-emotorsports.com |
