Red light while revving low (sorry, no creative title this time)
8bit Innovations
8bit Innovations is offline
PostPosted: Sat Apr 10, 2021 9:30 am    Post subject: Red light while revving low (sorry, no creative title this time) Reply with quote
My 67 bug has been having this problem for about two weeks and it’s driving me nuts! When the engine is idling, half of the time the generator light comes on. However, I start driving and the light goes away quickly. Just a light is not frustrating though, what is frustrating is that every time the light comes on, I hear an ever so slight rattle underneath the rear seat, which goes away when the light goes off. A mechanic concluded that the generator is not working properly, since the red light issue seems to get worse when the headlights are on (happened to me before it got worse). However, I’m not sure of the generator is completely at fault, because since seeing my 67 bug the mechanic wanted to make sure we keep it factory correct and remarked that the generator we have is not the correct one, although I still wanted the car to have the correct push terminal generator. Anyway, the main question: Is my generator really at fault or there may be something else at fault?
P.S: I replaced my normal size battery with a smaller sized new battery, which seems to kinda have helped in the problem, but not by much.
-8Bit
67 Bug Puerto Rico spec Deluxe sedan Fontana Grey (Acquired from original owner’s family)
rcroane Premium Member
rcroane is offline
PostPosted: Sat Apr 10, 2021 10:06 am    Post subject: Re: Red light while revving low (sorry, no creative title this time) Reply with quote
Battery cables all nice and tight? Just wondering if the light and the rattle under the seat are related to the new battery installation.
'65 Sunroof Bug
Zundfolge1432 Premium Member
Zundfolge1432 is offline
PostPosted: Sat Apr 10, 2021 10:07 am    Post subject: Re: Red light while revving low (sorry, no creative title this time) Reply with quote
Not a problem now. When light comes on and stays on you’ll have a problem.
iowegian Premium Member
Samba Curmudgeon
iowegian is offline
PostPosted: Sat Apr 10, 2021 11:20 am    Post subject: Re: Red light while revving low (sorry, no creative title this time) Reply with quote
If I am not mistaken the '67 Beetle voltage regulator is located under the rear seat, so--------------
8bit Innovations
PostPosted: Sat Apr 10, 2021 11:34 am    Post subject: Re: Red light while revving low (sorry, no creative title this time) Reply with quote
Addressing the recent replies:
1. The battery cables were tightened even better than what they were before. The rattle comes just from the left side of the rear seat. Thanks for the suggestion though!
2. Thanks for the reply too! At least now I know the car is drivable!
3. The regulator. That’s what the mechanic and I initially suspected. However, the other problems he mentioned include, lights dimming while idling, and needing to rev the engine a bit when arriving from a drive with the lights on. All of those problems had been occurring for some time before the light came on even when driving with the lights off. Is the regulator rattle associated with the generator failing though, or is that an excuse made by the mechanic to replace the generator??
-8Bit
mukluk
mukluk is offline
PostPosted: Sat Apr 10, 2021 12:36 pm    Post subject: Re: Red light while revving low (sorry, no creative title this time) Reply with quote
8bit Innovations wrote:
... The rattle comes just from the left side of the rear seat.
That's where the voltage regulator is located. If you still have an original mechanical style regulator, then the rattle you're hearing is the cut in coil/contacts quickly opening and closing. Given your problem description, I would suggest cleaning and tightening up all the wire connections at the voltage regulator, and if that doesn't clear up the issue, then grab a voltmeter and start checking your generator output, battery voltage state, and look for voltage drops in the charging system. Sometimes the problem you have can also be due to the idle speed set too low, so that's one more item you may want to visit.
67rustavenger Premium Member
67rustavenger is offline
PostPosted: Sat Apr 10, 2021 12:37 pm    Post subject: Re: Red light while revving low (sorry, no creative title this time) Reply with quote
The rattle under the back seat. Is likely the VR points clicking closed and open at a very high rate.
You can change the VR to a solid state unit from Bosch. Or live with the OG one that you currently are running. I have a SS VR in my 67 and it works flawlessly.
The dash gen light glowing at stop lights is just the nature of the electrical system. The lights dimming when idling is a result of the gen. not charging at idle. Once the engine is revved. The gen. light goes out and the gen is charging the battery.
An alt. charges continuously. From idle to full driving RPM. But an alt. is not stock on a 67.
If this is the Savannah Beige car in your gallery. I'm super jealous. It's a beautiful car indeed.
If you are living in PR. I'm jealous too. I miss the island. I worked there in 2001 for a year and really enjoyed the life style, culture, and the roadside Kiosks that offered some of the most delicious foods any person can ever eat.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
viiking
viiking is offline
PostPosted: Sat Apr 10, 2021 3:37 pm    Post subject: Re: Red light while revving low (sorry, no creative title this time) Reply with quote
Definitely the VR under the back seat, chattering as the points open and close.
Note: Generators do little to NO charging below 1000rpm engine speed. The rated output of the 12V generator is about 360W @ 12V at 2000 generator RPM which is twice the engine speed. So if your engine is idling typically below 1000 rpm not much juice is being provided.
Eric&Barb
Eric&Barb is offline
PostPosted: Sat Apr 10, 2021 7:26 pm    Post subject: Re: Red light while revving low (sorry, no creative title this time) Reply with quote
It could also be you have an earlier crankshaft pulley that is too small.
In Stereo, Where Available!
8bit Innovations
PostPosted: Sat Apr 10, 2021 10:21 pm    Post subject: Re: Red light while revving low (sorry, no creative title this time) Reply with quote
Thanks for the quick responses to everyone! I’ll give you an update when I work on the car.
-8Bit
lboos
lboos is offline
PostPosted: Sun Apr 11, 2021 5:05 am    Post subject: Re: Red light while revving low (sorry, no creative title this time) Reply with quote
Sounds like your idle rpm is just too low, that would cause the light to flicker at idle, also can cause noise because of a rough idle. increase your idle rpm.
I don't think you could hear the VR making any noise, esp. with the engine running, but you can hear a lot of rattling/tin if the engine is running rough, like too slow of an idle.
KTPhil Premium Member
KTPhil is offline
PostPosted: Sun Apr 11, 2021 2:27 pm    Post subject: Re: Red light while revving low (sorry, no creative title this time) Reply with quote
When the old style regulators get ready to fail, they click like that.
8bit Innovations
PostPosted: Sun Apr 11, 2021 4:37 pm    Post subject: Re: Red light while revving low (sorry, no creative title this time) Reply with quote
Adressing the most recent responses:
1. A quick check on the engine compartment and the pulley the correct one. Since it is a 67, the engine tin needs holes for the preheat, and in the one I have the pulley fits with almost no gap at all. Thanks for the suggestion anyway!
2. Today I drove the car again. The light came back on at random times. Never while driving, but at some stops it came on and at some it didn’t. Could be idle, however it may be something else combined with idle. Since the engine feels exactly the same as it felt when the light didn’t come on.
3. I suspected also that the regulator itself may be failing. However, I can’t be sure if it always rattled. In some of my older threads, I mentioned that I removed my door mechanism. What I never mentioned was that after installing the door panel, the armrest rattled a lot. Only after replacing the armrest like I planned to did I notice the VR rattle. However, before I noticed the rattle, the light were dimming everytime I drove at night. Would you suggest replacing only the generator, or the generator and regulator too?
-8Bit
Last edited by 8bit Innovations on Sun Apr 11, 2021 4:54 pm; edited 1 time in total
8bit Innovations
PostPosted: Sun Apr 11, 2021 4:53 pm    Post subject: Re: Red light while revving low (sorry, no creative title this time) Reply with quote
Reading in more detail at the responses here, some of you have said that it’s normal for regulators to make a faint clicking noise. Is there an explanation as to why do regulators make noise normally?
-8Bit
KTPhil is offline
PostPosted: Sun Apr 11, 2021 5:11 pm    Post subject: Re: Red light while revving low (sorry, no creative title this time) Reply with quote
There are internal relays that are opening and closing.
But when they sound like a machine gun something is about to fail.
https://www.thesamba.com/vw/forum/viewtopic.php?t=485607
https://www.thesamba.com/vw/forum/viewtopic.php?t=663656
modok
modok is offline
PostPosted: Sun Apr 11, 2021 5:49 pm    Post subject: Re: Red light while revving low (sorry, no creative title this time) Reply with quote
Old regulators have moving parts inside, so they probably do make a noise.
It could fail in a way where it makes more noise. Other times it quits entirely if the contacts weld solid which would be silent but deadly.
Solid state regulators do not, but they might emit a high frequency humm which none of us can hear because of age Laughing
If the generator tests good replace the regulator, or, probably just replace the regulator. It's worth the risk of having a spare if you guess wrong.
8bit Innovations
PostPosted: Sun Apr 11, 2021 5:52 pm    Post subject: Re: Red light while revving low (sorry, no creative title this time) Reply with quote
Now I understand how those old school regulators work. I remember that my mechanic talked about something inside the regulator that opened and closed rapidly. However, he never said that it was bad. Instead, he said that the noise was caused by the generator making way too little electricity. Is that true? Or do failing generator not affect regulator noise? Either way, I’ll be getting a solid state VR just in case. Might end up replacing both things out of fear of getting stranded.
-8Bit
Last edited by 8bit Innovations on Sun Apr 11, 2021 7:14 pm; edited 1 time in total
Q-Dog
Q-Dog is offline
PostPosted: Sun Apr 11, 2021 7:05 pm    Post subject: Re: Red light while revving low (sorry, no creative title this time) Reply with quote
My generator has about 300,000 miles on it. Only have replaced brushes in it 3 or 4 times that I can remember. It takes a bit if abuse to kill a generator.
But I have probably replaced 8 or so regulators with that same generator. I highly recommend the solid state regulator.
Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle
8bit Innovations
PostPosted: Sun Apr 11, 2021 7:20 pm    Post subject: Re: Red light while revving low (sorry, no creative title this time) Reply with quote
Due to collective recommendations from people here and in the jbugs webpage, I have now ordered a solid state regulator. Mine may not be dead, but I still find that since the generator will be replaced the regulator should be replaced too. Either way the generator was due to be replaced since it was not factory correct. At least my grandpa and the mechanic know of a guy that has been rebuilding generators since my grandpa owned a peugeot back in the day, and he may be able to give the new generator a rebuild, since it is a bit rusty and it may not work properly, but at least it’s the push terminal one. Thanks for the suggestions and responses to everyone! I’ll give you an update when the stuff is installed.
-8Bit
Last edited by 8bit Innovations on Sun Apr 11, 2021 8:01 pm; edited 1 time in total
KTPhil is offline
PostPosted: Sun Apr 11, 2021 7:43 pm    Post subject: Re: Red light while revving low (sorry, no creative title this time) Reply with quote
Search for "polarize generator" and consider doing that to your new gen. I've never had to, but some have needed it.
