Weber Windows
Clatter
Clatter is offline
PostPosted: Sat Apr 10, 2021 3:34 pm    Post subject: Weber Windows Reply with quote
Searching for info on this, it looks like nobody is selling pre-made Weber Windows for Beetles these days?
Anybody have a favorite place to get them?
Thanks
Bus Motor Build
What’s That Noise?!?
APPLEGREENVW
APPLEGREENVW is offline
PostPosted: Sat Apr 10, 2021 3:42 pm    Post subject: Re: Weber Windows Reply with quote
Do you mean this?
https://www.thesamba.com/vw/classifieds/detail.php?id=963000
Parts for sale https://www.thesamba.com/vw/classifieds/search.php?username=APPLEGREENVW
02/76 Beetle sedan
67rustavenger Premium Member
67rustavenger is offline
PostPosted: Sat Apr 10, 2021 4:37 pm    Post subject: Re: Weber Windows Reply with quote
HiPacs too. If you're interested,
https://www.hookyspanelshop.com/product/hipacs-high-performance-access-covers/
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
Don Jones
Don Jones is offline
PostPosted: Sat Apr 10, 2021 5:11 pm    Post subject: Re: Weber Windows Reply with quote
I bought mine from: https://www.thesamba.com/vw/classifieds/detail.php?id=963000 (Danny Gabbard).
Really well made and worth cost.
Used a dremel to cut the access holes. Bought the bits (from Amazon) to install the aircraft rivets.
Rome
Rome is offline
PostPosted: Sat Apr 10, 2021 5:15 pm    Post subject: Re: Weber Windows Reply with quote
In the years before I discovered theSamba, I remember somebody on either the Cal-Look Forum or the Shop Talk Forum making a very clever suggestion to use the fuel filler flap from a Bay-window Bus. It;s nearly square shaped, is spring-loaded so that you don't need to undo any fasteners, and large enough to get your hand through it if you need to get to the IDF idle jets or the spark plugs. You'd need to cut the flap out with a large enough section from the quarter panel- say a 1" lip- to position it in the wheelwell and try it with the flap going up, or going frontwards. Have the rear fender installed at least hand-tight to see that the swing of the flap still clears the fender. If you weld the piece in, you can trim down that 1" lip to maybe 1/2" all around.
dirtkeeper
dirtkeeper is offline
PostPosted: Sun Apr 11, 2021 8:36 am    Post subject: Re: Weber Windows Reply with quote
Every time I hear about these I think “ really? You have to take off and then reinstall 8 small screws that probably have road dirt to clean some idle jets or make an adjustment, on Two sides??, Nothing convenient about that “
I made swinging doors with a wing nut to hold closed and I like the bus fuel door suggestion although that not what I did. I will have both my idle jets cleaned out and be back on the road while your still dropping removed screws from the first window .into the dirt.
jeff68
jeff68 is offline
PostPosted: Mon Apr 12, 2021 5:48 am    Post subject: Re: Weber Windows Reply with quote
I installed the "Gab Fab" (Danny Gabbard) weber windows on my '68 Bug. THis is a very high quality and complete kit and they fit very well! If you're going to fit windows to your car I would recommend these for sure. Access to my carbs (48 IDA's) and spark plugs is much better with these.
Dan Ruddock
Dan Ruddock is offline
PostPosted: Mon Apr 12, 2021 8:28 am    Post subject: Re: Weber Windows Reply with quote
One my current build I am just modding the manifolds to reverse the IDF's to face the jets and mixture screws inward, done.
