carguytroy Samba Member
Posted: Sat Apr 10, 2021 7:45 pm Post subject: 73 Bus CV Joint Bearing size |
I did a search on here and I couldn’t exactly find the answer to my question so here goes. My son took apart the CV joints on his 73 Bus to replace the boots, clean and repack the joints. He didn’t pay attention to which end was which and I wasn’t watching. I’m seeing that the joints have two different bearing sizes. Two large bearing and two small bearing. Is the larger bearing joint the inner and the small the outer? Are they supposed to be the same joint and these were replaced with the wrong parts? In the threads I read there was no mention of two different size joints. The axles were attached to a trans we bought separate from the bus as it didn’t have one. It is the correct transmission for the year of the bus. I’m wondering if it was in a buggy and they just used different joints or what. Thanks for the help. |
Posted: Sat Apr 10, 2021 8:01 pm Post subject: Re: 73 Bus CV Joint Bearing size |
All four original joints were identical. |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3899 Location: Seattle, WA
Posted: Sat Apr 10, 2021 11:01 pm Post subject: Re: 73 Bus CV Joint Bearing size |
You're referring to ball bearing diameter differences?
Early (68-70) CVJ balls were .687" diam. Late (71 on) were .750".
Other vehicle types may have had their own sizes.
As long as no mix-'n-match of parts happens, the different bus CVJ's
should be completely interchangeable. _________________ '67 bug: seized by the authorities
Posted: Sun Apr 11, 2021 6:48 am Post subject: Re: 73 Bus CV Joint Bearing size |
If they were identical originally that’s what I’ll put it back to. Where’s the best place to buy them in your opinions and what’s the best part to get? |
Posted: Sun Apr 11, 2021 7:41 am Post subject: Re: 73 Bus CV Joint Bearing size |
carguytroy wrote: |
I would just tend to run them as is if the pitting of the races isn't excessive, maybe match them so one axle has the small balls and the other joint has the large balls. If you are set on replacing them, Lobros is the way to go for the CV bearings themselves and do some reading on the best boots. |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Mon Apr 12, 2021 9:12 pm Post subject: Re: 73 Bus CV Joint Bearing size |
Lobro
Empi _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
74 Thing Samba Member
