jootman Samba Member
Posted: Sun Apr 11, 2021 9:58 am Post subject: how to test the limited slip? |
Hi all
I have a 73 181 with a limited slip option.
Is there anything that needs a check or maintenance? I checked gearbox oil.
How do I test if this limited slip does its work?
I can turn the wheels in different direction. |
el_safari Samba Member
Joined: January 01, 2005 Posts: 375 Location: Nouvelle Aquitaine,France
Posted: Sun Apr 11, 2021 10:15 am Post subject: Re: how to test the limited slip? |
Back of the thing up, you turn 1 wheel and the other turn alone freely in the same direction. _________________ La terre n'est qu'un seul pays |
Posted: Sun Apr 11, 2021 10:33 am Post subject: Re: how to test the limited slip? |
will check, i think mine turns opposite direction
If it does, is there anything I need to replace? |
Posted: Sun Apr 11, 2021 10:39 am Post subject: Re: how to test the limited slip? |
Sadly you have then to open the differential to see what is damaged...
Did you put a lsd special oil in it? _________________ La terre n'est qu'un seul pays |
Posted: Sun Apr 11, 2021 11:41 am Post subject: Re: how to test the limited slip? |
I did not put new oil. I checked the level. Oil flowing out looked new
Shifts great btw, question was just out of curiosity |
RichardHead Samba Member
Joined: August 16, 2020 Posts: 9 Location: Duluth, Minnesota
Posted: Sun Apr 18, 2021 9:26 am Post subject: Re: how to test the limited slip? |
Are you sure it for sure has a limited slip diff and how do you know this? I was just watching some videos on how to know if you have a limited slip diff (unrelated to the Thing) and apparently if you jack it up and rotate a wheel and the other one turns in the same direction you do have a LSD, if it turns in the opposite direction you do not have an LSD. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76938 Location: Sneaking up behind you
Posted: Sun Apr 18, 2021 9:37 am Post subject: Re: how to test the limited slip? |
RichardHead wrote: |
I bet it has an open diff. _________________ Glenn
Member #1009
#BlueSquare |
SilverThing Samba Member
Posted: Sun Jul 04, 2021 6:25 pm Post subject: Re: how to test the limited slip? |
At some point VW put a special filler plug on limited slip equipped transmissions stating to use special oil because of the limited slip. My 1970 AL transmission doesn’t have the plug, but my 73 GB does. Known factory 181 limited slip transmissions have the following letter codes: AL, AW, and GB. The open differential codes are AK, AV, and GA. _________________ "I like how everyone likes talking about Zeke's Thing yet he's the only one that's ever seen it." - Katie
"I've seen pictures..." - Jeremy |
Posted: Mon Jul 05, 2021 6:35 am Post subject: Re: how to test the limited slip? |
I own an AW and an GB, the two have the special filler plug.
I used to have an AL with the short reduction like the vw bus till 1963.
On this one there was no hole in the gearbox for the axle of the starter, I never saw that before. All the others had a hole so you can use every starter. _________________ La terre n'est qu'un seul pays |
