jlinares Samba Member
Joined: June 30, 2018 Posts: 71 Location: Distrito Capital de Bogotá
Posted: Sun Apr 11, 2021 10:35 am Post subject: Carburetor gas leak |
Hello, found a fuel leak right here in my carburetor. Thinking I can fix it by hammering the tube a little bit, what do you think I may do to fix this? |
Posted: Sun Apr 11, 2021 10:53 am Post subject: Re: Carburetor gas leak |
Or maybe seal with some epoxy? |
Dan22 Samba Member
Joined: August 30, 2019 Posts: 470 Location: Battle Ground, WA
Posted: Sun Apr 11, 2021 10:54 am Post subject: Re: Carburetor gas leak |
Very dangerous fire hazard there. Perhaps epoxy it in and safety wire the hose after installation so that pipe cannot just pop out.
I would get a replacement carb top if it were me. Not worth torching your ride! _________________ 1-0900722 die langsame grüne Schildkröte
https://www.thesamba.com/vw/forum/viewtopic.php?t=765074 |
rcroane Samba Member
Joined: January 03, 2013 Posts: 2000 Location: Springfield, Virginia
Posted: Sun Apr 11, 2021 11:06 am Post subject: Re: Carburetor gas leak |
Not sure if you want to try it yourself, but I had my carb rebuilt by Volksbitz and got the optional screw in barbed input fitting. _________________ '65 Sunroof Bug |
AirHead1966 Samba Member
Joined: October 17, 2019 Posts: 568 Location: Triad Area NC
Posted: Sun Apr 11, 2021 11:37 am Post subject: Re: Carburetor gas leak |
Since you have it out, just tap it and put in a brass screw-in fitting with a barbed hose end. Use a clamp on the hose and safety wire it. |
Geier Samba Member
Joined: December 20, 2005 Posts: 187 Location: San Jose Ca.
Posted: Sun Apr 11, 2021 3:05 pm Post subject: Re: Carburetor gas leak |
OMG I would really get busy with this. That little bit of brass tube is giving all the warning you need that it needs to be fixed. This is an absolute fire hazard! I would get a carb top from an old carb that has no leak or get to Tim at Volksbitz to get a threaded inlet. Get some peace of mind. |
gt1953 Samba Member
Posted: Sun Apr 11, 2021 3:08 pm Post subject: Re: Carburetor gas leak |
Remove the brass off the carb, then with a small file, file a cross hatch pattern on it, mix up some epoxy, JB weld, apply the epoxy on the out side over the cross hatch pattern, install it back on carb top let it dry, problem solved. Reassemble the carb adjust as needed. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34012 Location: Conejo Valley, CA
Posted: Sun Apr 11, 2021 3:13 pm Post subject: Re: Carburetor gas leak |
gt1953 wrote: |
Remove the brass off the carb, then with a small file, file a cross hatch pattern on it, mix up some epoxy, JB weld, apply the epoxy on the out side over the cross hatch pattern, install it back on carb top let it dry, problem solved. Reassemble the carb adjust as needed. |
i did a similar operation... I rolled the fitting between two very coarse files with a lot of pressure. This dimpled it without removing any material, letting it fit tightly. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31374 Location: Hot Arizona
Posted: Sun Apr 11, 2021 4:03 pm Post subject: Re: Carburetor gas leak |
And safety-wire the hose clamp to the carburetor body so it cannot move "away".
Not my photo, but it's a good photo
_________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
