oasis Samba Member
Posted: Sun Apr 11, 2021 1:34 pm Post subject: stock speakers |
I have decided I want my single cab to have a radio and, therefore, speakers. I have ordered new door cards that already have speaker holes near the manual window crank. So, now what?
Searching speakers led me to 34 pages of threads, and most dealt with modifications -- getting 6x9's in there, denting grills, etc. Other threads had the speakers mounted in a lower position on the doors.
One choice is to find used stock speakers. I may go that route.
What about this choice? https://www.hifisoundconnection.com/Fits-Volkswage...EPLACE2344
The thing that spooks me out of the gate is it states 1908-85 Vanagon's. Was there something about 1986-91 models that were different in this regard?
I'm open to other suggestions. I'm not looking to be an audiophile's envy. I just want to be able to listen to some nice tunes on the radio, from a CD, etc. _________________ Now: 2003 New Beetle Turbo S / 1990 Single Cab Transporter / 2014 Tiguan R-Line 4motion / 2013 Tiguan S / 2002 Golf GLS TDI
Past: 1974 Thing Acapulco / 2009 Eos Komfort / 1997 Jetta GT / 2002 Cabrio GLX / 2002 Passat GLS / 1971 Super Beetle / 1993 EuroVan MV Westfalia / 1981 Pickup LX / 1985 Vanagon / 1986 Jetta GLI |
16CVs Samba Member
Joined: February 22, 2004 Posts: 4026 Location: Redwood City, California
Posted: Sun Apr 11, 2021 2:51 pm Post subject: Re: stock speakers |
I just made a mount and mounted the speakers to the door and put a slim open mesh grill on the panel. That way you have no interference with the window crank or dash. You should put a protector on the back of the speaker as there is more water back under the vent glass then you would think.
Speaker used to come with Plastic shields put it is easy enough to fashion something up. _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32634 Location: Reading Pennsylvania
erste Samba Member
Joined: March 29, 2013 Posts: 1110 Location: San Francisco
Posted: Sun Apr 11, 2021 3:14 pm Post subject: Re: stock speakers |
Don’t get stock speakers.
Like 16CVs said, you can mount them straight to the door. Fitting 6.5” is easy with a little bit of trimming to the speaker and a few new holes drilled in the door. I mounted 6.5”s in the upper location behind the stock speaker grilles. And used speaker baffles to protect against water, but cut the bottom out so the speakers can breathe.
https://www.thesamba.com/vw/forum/viewtopic.php?t=665074
https://www.thesamba.com/vw/forum/viewtopic.php?t=706124
https://www.thesamba.com/vw/forum/viewtopic.php?t=...p;start=80
With a 6.5 coaxial you might need to trim more of the grille, but most speakers should still fit.
Two 4” speakers in a sinka will leave a lot to be desired unless you just listen to talk radio.
edit to add another link with GalaxyVortex’s install pics
Jeffrey Lee Samba Member
Joined: February 04, 2014 Posts: 1488 Location: Wisconsin
oasis Samba Member
Posted: Sun Apr 11, 2021 9:45 pm Post subject: Re: stock speakers |
Thanks to all who answered. I will check out the links later to see if there's anything there for me.
Except for a trip to Maine I have planned in a couple of weeks, most of my Sinka driving will be local. I'm more interested in keeping things stock (or stock looking) than having anything super impressive. I will be listening to 2-3 local stations, 10-15 SiriusXM stations, and some CDs. The head unit is only listed at 50 watts per channel. I do want to listen and occasionally get loud distortion-free, but not much more than that.
I will consider all options, however.
djkeev wrote: |
I simply ordered some 3 1/2” speakers and simple mesh wire speaker covers.
Just make sure that the speakers you order don't have a pronounced center cone.
They sit as flush as stock and don't require a fancy window crank handle.
djkeev wrote: |
I put new speakers in the stock speaker grill on my 86, not a task I wish to repeat and the sound results weren't that good.
So, you didn't like the Kicker DSC350 speakers? _________________ Now: 2003 New Beetle Turbo S / 1990 Single Cab Transporter / 2014 Tiguan R-Line 4motion / 2013 Tiguan S / 2002 Golf GLS TDI
oasis Samba Member
Posted: Sun Apr 11, 2021 10:09 pm Post subject: Re: stock speakers |
What about these?
https://www.amazon.com/Rockford-Fosgate-T142-Coaxi...en+Vanagon
They seem to have a good range of sound and can easily handle what the head unit puts out. They have a mounting depth of 1.79" and Amazon says they fit a 1990 Vanagon.
They don't come with grills. Would a stock Vanagon grill work? _________________ Now: 2003 New Beetle Turbo S / 1990 Single Cab Transporter / 2014 Tiguan R-Line 4motion / 2013 Tiguan S / 2002 Golf GLS TDI
Jim Bear Samba Member
Joined: March 25, 2006 Posts: 670 Location: Watkinsville, GA
Posted: Mon Apr 12, 2021 6:32 am Post subject: Re: stock speakers |
Do you think the above mentioned Kickers would fit an '85? _________________ "You're either on the bus, or you're off the bus." ~kk
'85 Vanagon Westy - George In the Stable 2020-?/'74 Weekender - Ophelia In the Stable 2007- ?/'69 Beetle Convertible - SOLD 2017-2020/'67 Beetle - September SOLD 2013-2016 /'67 SO42 Westy - Sage SOLD 1996-2001 /'69 Transporter - Baby Blue SOLD 1995-1995/'72 Westy - Nelly - SOLD 1990-1995--STOP FRACKING |
termuehlen Samba Member
Joined: May 02, 2012 Posts: 994 Location: Redwood City
Posted: Mon Apr 12, 2021 12:39 pm Post subject: Re: stock speakers |
oasis wrote: |
I'm open to other suggestions. I'm not looking to be an audiophile's envy. I just want to be able to listen to some nice tunes on the radio, from a CD, etc. |
Older model Westys had speakers with a "flange mount". They looked like this:
The housing was threaded and a retaining ring screwed on from the back to hold them in place. They did not have any mounting holes. Like others here, I purchased late model Westy speakers, cut the front off and mounted updated speakers behind the modified grill. They are attached with screws fastened through sheet metal clip nuts attached to the door cards. Sound quality is OK. It depends on your personal sound quality standards. _________________ 1988 Westfalia automatic Subaru OBD1
1986 syncro tintop wbx |
oasis Samba Member
Posted: Mon Apr 12, 2021 6:24 pm Post subject: Re: stock speakers |
djkeev wrote: |
I'm sorry, two different Vans.
The photo above are the ones I put into my 90 a few weeks ago. They are more than adequate. |
Ahh, '86 and '90 ... I didn't pick up on that the first read-through. Interestingly, the Kicker speakers according to Amazon doesn't fit a '90 Vanagon. Since you are using them and the mesh covers from the links you included without needing to modify the window crank, I'm not going to pay any attention to Amazon.
termuehlen wrote: |
It depends on your personal sound quality standards. |
My other cars have varying quality system and speakers. If I wanted serious listening to my tunes, I probably wouldn't even have speakers in the doors of a single cab. My headliner would probably be totally custom with personalized speakers for each person.
Thanks again, everybody. _________________ Now: 2003 New Beetle Turbo S / 1990 Single Cab Transporter / 2014 Tiguan R-Line 4motion / 2013 Tiguan S / 2002 Golf GLS TDI
khughes Samba Member
Joined: July 13, 2013 Posts: 747 Location: Phoenix AZ
Posted: Mon Apr 12, 2021 7:37 pm Post subject: Re: stock speakers |
Well, at the end of the day, virtually any new speaker will be far better than stock, but you still are very limited in sound from a 4" speaker. Just can't move enough air unfortunately. I have found those "boom mat" type speaker protectors really seem to improve the sound for cheap, as well as giving protection from water - for you folks that actually have water falling from the sky... _________________ '86 Westy FAS GenV Turbo (Marvin) |
Glenn73 Samba Member
Joined: May 30, 2011 Posts: 1190 Location: West Jordan UT
oasis Samba Member
Posted: Tue Apr 13, 2021 7:32 pm Post subject: Re: stock speakers |
khughes wrote: |
... you still are very limited in sound from a 4" speaker. Just can't move enough air unfortunately. I have found those "boom mat" type speaker protectors really seem to improve the sound for cheap, as well as giving protection from water ... |
Yeah, but options for speakers in a single cab versus a Vanagon are very limited unless I want to start down the road of major customizing. Even then, the speakers are going to be either is some stupid place or right on me. And then, I won't be piping in the volume unless I want to lose what hearing I have left.
I did make note of the boom mat mentioned earlier. Seems like a smart addition. _________________ Now: 2003 New Beetle Turbo S / 1990 Single Cab Transporter / 2014 Tiguan R-Line 4motion / 2013 Tiguan S / 2002 Golf GLS TDI
SteveMc Samba Member
Joined: December 19, 2013 Posts: 210 Location: Alberta, Canada
Posted: Wed Apr 14, 2021 9:38 pm Post subject: Re: stock speakers |
I’ve spent a lot of time pondering speakers for my single cab. Finally decided on 4” speakers in the factory location. I’m going with Focal PC100s. https://www.focal.com/sites/www.focal.fr/files/shared/catalog/document/pc100-technical-sheet.pdf
I hope to install them this weekend. Not sure how I’m going to do it yet but I’ll report back on how it goes and how they sound.
_________________ 1986 Transporter Single Cab Syncro |
erste Samba Member
Posted: Wed Apr 14, 2021 10:01 pm Post subject: Re: stock speakers |
SteveMc wrote: |
I’m going with Focal PC100s. |
Nice. Good luck with the install! Focals are really well built and the magnet on those is huge for a 4”. I’m sure they’ll sound great with a little bit of power behind them. |
oasis Samba Member
Posted: Wed Apr 14, 2021 11:17 pm Post subject: Re: stock speakers |
Overall depth is 66.4mm which is just over 2.6 inches. I'd be worried it would interfere with the window crank. Hope to see a report soon. _________________ Now: 2003 New Beetle Turbo S / 1990 Single Cab Transporter / 2014 Tiguan R-Line 4motion / 2013 Tiguan S / 2002 Golf GLS TDI
gbrandt Samba Member
Posted: Thu Apr 15, 2021 8:04 am Post subject: Re: stock speakers |
SteveMc wrote: |
. I’m going with Focal PC100s. |
As someone else mentioned, the space between the door card and the dash is very small. If you still have the original speakers, you can place the new speaker behind the card and then cut the back of the old speakers and mount them on the door card. Looks stock and won't hit the dash. This assumes that the speaker fits that way.
Gregor _________________ 'Lucky' our 1987 Red Westy, ASV 1.9 TDI ~130HP, Peloquin differential (had a GW 2.3 that we loved, but it died, we drove it hard!)
We've driven in 49 countries and 5 continents to date
Canada to Argentina and back, 2015 to 2017.
Canada to Europe and back (including Turkey, Morocco and Iceland), 2017 to 2019
Mexico 2022-2023
https://www.instagram.com/live.travel.play/
http://livetravelplay.ca |
