Westy luggage rack bolts?
Fiddlestyx
Fiddlestyx is offline
PostPosted: Sun Apr 11, 2021 3:11 pm    Post subject: Westy luggage rack bolts? Reply with quote
I am wondering if anyone knows where I can get original replacement bolts for the Westy luggage rack as I broke one while removing my rack to replace the seal or if anyone knows the size of them. I think they are M8x1.25 with a 16mm shank and 16mm head, but I'm not sure. Plus, I haven't been able to find that size anywhere.
I ordered the stainless steel bolts that the vendors sell but the head on the bolt is 14mm whereas mine are 16mm. I paid a premium for bolts that aren't even the correct size. This wouldn't be a problem if I were restoring the luggage rack, but I'm not and you can tell where the old bolts worn down the fiberglass if I use the new stainless bolts.
Thanks
1983 Vanagon Westfalia Air-cooled
1973 Super Beetle
djkeev
djkeev is offline
PostPosted: Sun Apr 11, 2021 4:18 pm    Post subject: Re: Westy luggage rack bolts? Reply with quote
I'm pretty good at finding stuff, odds are high you won't find the 16 mm heads in stainless steel.
https://www.thesamba.com/vw/forum/viewtopic.php?t=...p;start=20
Dave
Ghia
Vanagon
Beetle
dgbeatty
dgbeatty is offline
PostPosted: Sun Apr 11, 2021 6:22 pm    Post subject: Re: Westy luggage rack bolts? Reply with quote
The part number is 255070908. Buslab has them in stock. https://www.buslab.com/product-p/255070908f.htm
Schau in das Buch
djkeev
djkeev is offline
PostPosted: Sun Apr 11, 2021 8:17 pm    Post subject: Re: Westy luggage rack bolts? Reply with quote
Not in stainless steel, only painted.
Good find though!
Dave
Ghia
Vanagon
Beetle
Fiddlestyx
PostPosted: Mon Apr 12, 2021 6:21 am    Post subject: Re: Westy luggage rack bolts? Reply with quote
Thank you so much!
Good find though!
Dave
I'll be removing the paint and plating them. Thanks!
1973 Super Beetle
Sodo
Sodo is offline
PostPosted: Mon Apr 12, 2021 6:57 am    Post subject: Re: Westy luggage rack bolts? Reply with quote
Oh fun! Nickel plating?
....KTMs, GasGas, SPOT mtb
ZsZ
ZsZ is offline
PostPosted: Mon Apr 12, 2021 7:12 am    Post subject: Re: Westy luggage rack bolts? Reply with quote
not original, but BW has both Stainless, and painted:
https://www.brickwerks.co.uk/pop-top-roof-screw-t3-westfalia-stainless.html
https://www.brickwerks.co.uk/pop-top-roof-screw-t3-westfalia-painted.html
originals are M6, but have tapered threaded section as they are either self tapping or just tapered for aid installation
Zoltan
1.9 MTdi 2wd Multivan (ex Caravelle)
Van since 2006, engine since 2008
Fiddlestyx
PostPosted: Mon Apr 12, 2021 8:27 am    Post subject: Re: Westy luggage rack bolts? Reply with quote
I can plate in zinc, nickel and copper. Will do the bolt heads in zinc and nickel.
1973 Super Beetle
kevinm
kevinm is offline
PostPosted: Mon Apr 12, 2021 12:50 pm    Post subject: Re: Westy luggage rack bolts? Reply with quote
Here's an M6 x 20, in stainless, with a 19.2 mm head:
https://www.mcmaster.com/90015A531/
Also this M6 x 16 with a 17 mm head, but note the different drive style (head shape)...maybe that would make your luggage rack more theft proof?
https://www.mcmaster.com/97133A310/
Other "wide-head" options that might work here:
https://www.mcmaster.com/https%3A%2F%2Fwwwmcmaster...d-size~m6/
djkeev
djkeev is offline
PostPosted: Mon Apr 12, 2021 1:13 pm    Post subject: Re: Westy luggage rack bolts? Reply with quote
Good find!
Pride cometh before the fall.........
I guess I'm not such a good finder!
Dave
Ghia
Vanagon
Beetle
vanagonjr
vanagonjr is offline
PostPosted: Tue Apr 13, 2021 4:51 pm    Post subject: Re: Westy luggage rack bolts? Reply with quote
If I pursued having stainless ones made with the correct head diameter, do you think anyone would be interested?
skills@eurocarsplus
Samba Peckerhead
PostPosted: Tue Apr 13, 2021 7:25 pm    Post subject: Re: Westy luggage rack bolts? Reply with quote
no need Cool
Dave
pop quiz suckkka Very Happy
https://www.belmetric.com/6mm-slotted-truss-c-563_...13259.html
that's where i got mine
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
vanagonjr
PostPosted: Wed Apr 14, 2021 7:35 am    Post subject: Re: Westy luggage rack bolts? Reply with quote
skills@eurocarsplus wrote:
no need Cool
Dave
Closest so far with a 15mm head. 👍
So only 1mm (0.040”) small.
wbailey2112
wbailey2112 is offline
PostPosted: Wed Apr 14, 2021 7:56 am    Post subject: Re: Westy luggage rack bolts? Reply with quote
I replaced all of the rusty bolts on the luggage rack and the pop top with stainless steel "cheese head" bolts with stainless flat and lock washers and nuts that I purchased from my local full service hardware store.
Are they factory spec? No but I saw no point in living with the nasty rusty original fasteners until I could find an exact replacement (which may not exist).
'74 Thing
'83 Westfalia
Andymon
Andymon is offline
PostPosted: Wed Apr 14, 2021 9:18 am    Post subject: Re: Westy luggage rack bolts? Reply with quote
From buslab's description: This pastel white screw, part number 255 070 908F, has multiple applications. We also carry a stainless steel version of this screw.
Good find though!
Dave
"Blanch" '85 Westy
"Too many freaks and not enough circuses".
