theguyryry Samba Member
Joined: March 31, 2021 Posts: 100 Location: Portland, OR
Posted: Mon Apr 12, 2021 7:15 am Post subject: Type IV Manual |
Does anyone have recommendations on books, manuals, or other reading specifically for a type 4 engine? |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51155 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Apr 12, 2021 8:03 am Post subject: Re: Type IV Manual |
_________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Abscate Samba Member
Posted: Mon Apr 12, 2021 8:05 am Post subject: Re: Type IV Manual |
theguyryry wrote: |
Tom Wilson ISBN 978-0-89586-225-9
Ray Greenwood posts bookmark
Microscope to read his secret instructions in the ellipses
You have access to all that is known about the Type 4 motor, and more. _________________ .ssS! |
Posted: Mon Apr 12, 2021 8:40 am Post subject: Re: Type IV Manual |
Sweet! I saw both of those on Amazon... I'll get those ordered. Any recommendations for a basic toolkit? |
crownline Samba Member
Joined: September 10, 2010 Posts: 593 Location: Northwoods of WI
Posted: Mon Apr 12, 2021 9:04 am Post subject: Re: Type IV Manual |
At least 4 10mm sockets and wrenches. Just a good metric tool set. Feeler gauges bandaid for knuckles. Beer. Dictionary so you can look up the definition of new cuss words you will using. Did I mention Beer? _________________ 1972 Bus 1700 cc Single Carb. But not a progressive.
Barelymuvin
Wish I still had the ones I got rid of.
"It"s got some dings and dents and neither of us is going to SEMA."(Update, I went to SEMA in 2019 but the Bus stayed home)
[url=http://www.vw-mplate.com/mplate-8446.png]Click to view image[/URL] |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2745 Location: Hamble, Hampshire, UK
Posted: Mon Apr 12, 2021 1:01 pm Post subject: Re: Type IV Manual |
For some reason I have 4 hammers in the tool kit I take with me in my bus from half pound to 2lb heads, one nylon headed.
Metric socket set 1/2" drive, set of metric combination spanners.
1/2" drive hex driver set for door hinges, sliding door bottom roller..
Cross head and flat blade screwdrivers. Adjustable spanners, 6" and 12" handle.
Vice grips.
Side cutters, pliers. Feeler gauge set.
12 volt test light at least, digital multimeter.
A jack for tyre changes.
(In fact I carry all tools needed to remove and replace the engine except for some way of lowering the engine . About 50% of the space under the rear seat is tools ) _________________ Ancient vehicles and vessels
raygreenwood Samba Member
Posted: Mon Apr 12, 2021 1:08 pm Post subject: Re: Type IV Manual |
Abscate wrote: |
theguyryry wrote: |
You have access to all that is known about the Type 4 motor, and more. |
....I have some good recommendations for affordable microscopes if you need one!
Ray |
timvw7476 Samba Member
Posted: Mon Apr 12, 2021 2:53 pm Post subject: Re: Type IV Manual |
theguyryry wrote: |
Powercraft sparkplug socket, it's magnetic.
Also a magnetic tool, to fish all the old sparkplugs out of the engine tin work .
Magnetic retrievers are important. When it comes to Type IV.
You'll understand after the first three minute encounter. |
Posted: Mon Apr 12, 2021 3:38 pm Post subject: Re: Type IV Manual |
Here is a list of tools and supplies I had with me on a three month trip to Mexico a decade plus back. I had to do an engine pull during the trip when an oil galley plug blew and the only tool I had to borrow was a torque wrench for the flywheel bolts. All the tools and some of the supplies fit into a smallish (1 cu. ft.) tool box.
Tube high temperature silicone
JB Weld
Tube anti-seize
Tube Loctite
Roll plastic electrical tape
Remnant of a roll of rubber electrical tape
Tube Vasoline
Bottle dry gas
Bottle FI cleaner
Can BP Blaster
1/2" Tape measure
Jumper cables
Brake fluid
Motor oil
1/2 drive sockets 15mm-22mm
1/2 breaker bar and extensions
3/8 socket set regular and deep
3/8 spark plug socket
3/8 ratchet and breaker bar, plus extensions
Metric allen wrench set
17mm tool for tranny fill and drain
Feeler guage and spark plug wire gauge set
12 point adapter for CV joint bolts, long
Hex adapter for CV joint bolts, long
Screwdrivers:
3/8 flat, long
#3 phillips
Replaceable tip #1, #2, 3/16, 5/16
Replaceable tip, jewelers
Radiator hose tool
Small rattail file
Half round file
Crescent wrenches, 4", 6", 12"
10 x 11mm tubing wrench for brake lines
8mm - 22 mm combination wrench set
6mm - 19 mm box end set
3/8 - 5/8 English combination set
VOM meter
Wiring multi-tool with misc asst of wire terminals
Diagonal cutters
Snap ring pliers, two styles
Channel-locks 10"
2# ball peen hammer
Vise Grips, large and small
Battery drill, with bits 1/16 - 1/4"
Ground cloth
Grease gun
Needle adapter
Spare parts:
Alternator belt
Fuel Filters, two |
my59 Samba Member
Joined: August 13, 2003 Posts: 3793 Location: connecting the dots
Posted: Mon Apr 12, 2021 3:41 pm Post subject: Re: Type IV Manual |
When I redid the bus engine, I went through the Wilson book and underlined the type 4 specifics to make sure I could double check what I was doing accurately. _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget. |
Posted: Mon Apr 12, 2021 3:47 pm Post subject: Re: Type IV Manual |
I can't find it right now, but there's a thread on the errors in the Bentley as well as one on Wilson's. Many don't matter much, but some, like that overtorque on the rocker stands in Wilson's will change your weekend. His distributor drive instructions are a big challenging as well. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
my59 Samba Member
Posted: Mon Apr 12, 2021 4:05 pm Post subject: Re: Type IV Manual |
busdaddy wrote: |
I can't find it right now, but there's a thread on the errors in the Bentley as well as one on Wilson's. Many don't matter much, but some, like that overtorque on the rocker stands in Wilson's will change your weekend. His distributor drive instructions are a big challenging as well. |
Thats what notes in the margins are all about! Things like adding in the torque values where you need them so you aren't flipping pages around smearing greasy crap on the manual or typing on the phone looking for info while wedged underneath the bus with the manual propped open next to you lying on an unheated barn floor in the dead of winter with that inner voice saying WTF were you thinking? _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Posted: Tue Apr 13, 2021 2:12 pm Post subject: Re: Type IV Manual |
I went ahead and ordered the following:
- How to Rebuild Your Volkswagen air-Cooled Engine (All models, 1961 and up)
- How to Keep Your Volkswagen Alive: A Manual of Step-by-Step Procedures for the Compleat Idiot
The bus I'm going to look at next comes with the Bentley manual, so I'm going to hold off on that one for now. I was looking for online reading to keep me busy while I wait for those to ship, and stumbled across ratwell's website again ( https://www.ratwell.com/technical/FAQ/FAQContent.html ). This should keep me busy for awhile. |
Posted: Tue Apr 13, 2021 2:47 pm Post subject: Re: Type IV Manual |
That'll do fine, consider the idiot book as a last resort if nothing makes sense in any of the other books, it's fun and entertaining, and good for a noob to get their head around basic procedures, but it's written at a time when junkyards were full of good German parts and it wasn't a big deal if you broke something. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Zeta Samba Member
Posted: Tue Apr 13, 2021 3:24 pm Post subject: Re: Type IV Manual |
my59 wrote: |
When I redid the bus engine, I went through the Wilson book and underlined the type 4 specifics to make sure I could double check what I was doing accurately. |
Great idea!
Thank you. _________________ -----------
1974 Westy
1800 cc Type4 Engine
Single Weber Carb |
Zeta Samba Member
Posted: Tue Apr 13, 2021 3:36 pm Post subject: Re: Type IV Manual |
busdaddy wrote: |
That'll do fine, consider the idiot book as a last resort if nothing makes sense in any of the other books, it's fun and entertaining, and good for a noob to get their head around basic procedures, but it's written at a time when junkyards were full of good German parts and it wasn't a big deal if you broke something. |
I am certainly a noob, and yes, this book allows me to grab the concepts and overall layout of the game plan. As a noob, this book has helped me greatly, and yes, it is a good read too. I do have the Bently as well which is used after reviewing overall plan from Muir's book.
Based on this thread, I purchased Wilson's book even if I am not doing an overhaul when I drop my engine. I am not knowledgeable enough to embark on this task. But, I realized these reading materials will require several reads.
The same happened when I started reading the Itinerant's thread on converting back to Solex (The Goose:... https://itinerant-air-cooled.com/viewtopic.php?t=13619 )
At first, wow I was lost and multiple times I thought "this is out of my league" but by page 4, I was able to follow a few things, and by the end I certainly knew more than at the beginning.
These forums are invaluable! Thank you Samba (and contributors)! _________________ -----------
1974 Westy
Single Weber Carb |
mfemenel Samba Member
Joined: August 03, 2014 Posts: 273 Location: Matthews, NC
Posted: Mon May 03, 2021 1:43 am Post subject: Re: Type IV Manual |
I just realized a weakness in my tool kit this weekend. On my 79 westy, it's a 6 mm allen head to get the alternator loose. Throw one of those in your bus along with a long sturdy screw driver, or pry bar. I had a piece of scrap angle iron that worked. If your belt goes you're not changing it on the side of the road if you can't get the altnernator bolt backed off. _________________ '79 Westy FI/AC/Auto
'78 Tin Top FI/Manual
'71 Ghia Coupe Project - FOR SALE! |
Takamotti Samba Member
Posted: Mon May 03, 2021 4:09 am Post subject: Re: Type IV Manual |
or you can get it online straight from VW... Most type 4 related manuals are in German but at a quick glance it seems at least 2.0 L-Jetronic manual is available in English
https://erwin.volkswagen.de/erwin/showHome.do |
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
Posted: Mon May 03, 2021 5:06 am Post subject: Re: Type IV Manual |
funny not/funny, but an actual owners manual for the year of vehicle you are interested in. Besides the engine, lots of little tidbits of knowledge. You see it on the samba quite frequently. "the answer is in your manual!"
i dont even think you have to buy one. they may be in the tech section . |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Fri May 07, 2021 7:25 am Post subject: Re: Type IV Manual |
I have found on several occasions the 1980-1982 years covered in the Vanagon Bentley manual to have updated and important information regarding the air-cooled Type 4 engine. |
