toxicavenger70 Samba Member
Posted: Mon Apr 12, 2021 1:45 pm Post subject: Conversion to a electric fuel gauge and sender? |
I have a 65' that I just installed a 68' speedo/fuel gauge into. I have everything hooked up, the sender (tube style/electric) grounded. It is working. The issue is the gauge only reads half fuel. When I unhook the gauge then ground it, the gauge does read full. When I unhook it moves to empty.
I have done some reading and multiple places list a few different sizes (I wasn't aware of that beforehand). I currently have a 7 1/2 version installed in my car. I have seen a 280mm version and a 310mm.
Any idea what size would be needed in a stock 65' tank?
Thanks ahead of time. |
AirHead1966 Samba Member
Joined: October 17, 2019 Posts: 568 Location: Triad Area NC
Posted: Mon Apr 12, 2021 2:48 pm Post subject: Re: Conversion to a electric fuel gauge and sender? |
I am sure there are other ways to do it, but I would do it electronically.
Get a potentiometer (3Watt should be fine).
Cut the wire from the sender and attach it to the Vcc or input of the pot. Connect the other end of the cut wire (that goes to the gauge) to the output of the pot. Ground the ground terminal of the pot.
Fill the tank and slowly adjust the pot until it reads full. |
Joined: August 31, 2013 Posts: 12858 Location: North Carolina
Posted: Tue Apr 13, 2021 1:30 am Post subject: Re: Conversion to a electric fuel gauge and sender? |
Is the sender new or an old one?
If new, there has been issues with aftermarket senders not having the same resistance as factory senders.
If the sender is an old unit, it may need to be repaired, here’s a great how-to from the bay window forums...
https://www.thesamba.com/vw/forum/viewtopic.php?p=7706426#7706426 _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Tue Apr 13, 2021 7:14 am Post subject: Re: Conversion to a electric fuel gauge and sender? |
TDCTDI wrote: |
https://www.thesamba.com/vw/forum/viewtopic.php?p=7706426#7706426 |
It is a new sender. I will test it out today and see what happens.
Thanks |
Posted: Tue Apr 13, 2021 7:39 am Post subject: Re: Conversion to a electric fuel gauge and sender? |
AirHead1966 wrote: |
Great idea. Thanks for the suggestion. |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11056 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Tue Apr 13, 2021 12:45 pm Post subject: Re: Conversion to a electric fuel gauge and sender? |
Take the sender out of the tank...
Use a jumper circuit from the sender mount base to the car ground.. being sure to leave the sender circuit to the gauge attached.
Test the range of gauge readings by sweeping the float arm...
If the gauge reads empty when the float is down and full when the float is up.. the issue is with the tank ground or float arm movement or position in the tank. If the gauge doesn't match float travel.. there is a mismatch between gauge and sender..
The sending unit MUST BE grounded properly. It may be necessary to route an extra ground to the sender base with an eyelet under a sender screw. It is real important to not use the screw insulator on that grounding screw as well.
. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
HBRag Samba Member
Joined: April 29, 2005 Posts: 735 Location: Huntington Beach, CA
Posted: Tue Apr 13, 2021 9:26 pm Post subject: Re: Conversion to a electric fuel gauge and sender? |
VDO stand is 10-180 Ohm range. There are a bunch of different standards, so the gauge and sender have to match. Are you sure the sender range is correct, and not a GM or Ford standard which may end at 90 Ohms? |
Posted: Thu Apr 15, 2021 10:02 am Post subject: Re: Conversion to a electric fuel gauge and sender? |
VOLKSWAGNUT wrote: |
Great info. Funny thing is I took out the new tube style sender to compare it to the original float version and it is the correct size (7 1/2 length) as the stock one. When I installed it back in tank it was reading correctly at a full tank. I will run it for a few days and see how it does. If it does act up I will come back and do this test you have recommended.
I have an extra ground already ran from the tank mounting bolt. At that time I removed the bolt insulator like you are recommending to ensure I had a good ground. I then tested it to make sure it was a good ground.
Thanks for the info. |
Posted: Thu Apr 15, 2021 10:07 am Post subject: Re: Conversion to a electric fuel gauge and sender? |
HBRag wrote: |
Honestly I am not sure what range this sender is. It is for a Ghia tank, I believe a 67-73 model. It is part number 271919051B. I was trying this style out to stop the floating issue I was having with my previous setup. |
