Technut27 Samba Member
Posted: Mon Apr 12, 2021 7:03 pm Post subject: Upper front door hinge mount points floating? |
I have the my door hinge mirror mounts off to paint them. Is it normal for the captive mounting plate to be floating inside the body? Both sides do it to some extent but don't feel like they can get far in any direction. I put a bolt back in out of fear the could drop down inside the body and ruin my day
Broken welds?
By design for adjusting the door?
jakokombi Samba Member
Joined: August 15, 2010 Posts: 779 Location: Milwaukee
Posted: Mon Apr 12, 2021 7:06 pm Post subject: Re: Upper front door hinge mount points floating? |
"By design for adjusting the door?"
DING DING DING! You got it right. _________________ 70 Sunroof Kombi
85 Motherfukinvanagon
73 Thing
72 Baja |
Posted: Tue Apr 13, 2021 9:33 am Post subject: Re: Upper front door hinge mount points floating? |
If your door was fitting well before, then just align the hinge back up with the marks on the paint as you tighten the screws. |
Posted: Fri Apr 16, 2021 4:55 pm Post subject: Re: Upper front door hinge mount points floating? |
Is the same true for the striker plate on the opposite side? All of my doors close flush to the body except for the drivers of course. I get the first click but can't get the second. I don't want to hear a clunk on the bottom when I take the screws out
I painted everything up on my lunch breaks this week and I'm really impressed with how well the touch up paint matches. Mine is painted Rally Red and someone would have to look pretty close to see the difference if I had done better feathering the edges. |
