Franklinstower Samba Member
Posted: Tue Apr 13, 2021 9:55 am Post subject: door electrical boot / bellows |
Anyone know of an alternative to this expensive little bellows for the door wiring?
https://www.gowesty.com/product/door/19045/bellows-boot-door-wiring-harness-
Thanks _________________ '89 Westy - EJ25/22 Frank 4.44 5mt
'75 Miami Blue Sunroof FI Standard Bug
Last edited by Franklinstower on Tue Apr 13, 2021 2:36 pm; edited 1 time in total |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32584 Location: Reading Pennsylvania
Posted: Tue Apr 13, 2021 11:01 am Post subject: Re: door electrical boot / bellows |
djkeev wrote: |
Bicycle inner tube.
Dave |
You can put innertubes on your vehicle, I was looking for something like an alternative boot made for door harnesses.
I can see where this is going... _________________ '89 Westy - EJ25/22 Frank 4.44 5mt
'75 Miami Blue Sunroof FI Standard Bug |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17114 Location: Retired South Florida
Posted: Tue Apr 13, 2021 11:06 am Post subject: Re: door electrical boot / bellows |
Franklinstower wrote: |
djkeev wrote: |
Bicycle inner tube.
Dave |
I can see where this is going... |
You asked for something thats an alternative to the actual replacement boots. Other than used, a rubber tube would meet that. For all the trouble to carefully remove the harness, not sure why you'd go to the headache to modify something to fit. Maybe good used in the classifieds. This is one of those parts that I'd pony up the money for. _________________ ☮️ |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6829 Location: Fort Lauderdale, Fl.
Posted: Tue Apr 13, 2021 12:52 pm Post subject: Re: door electrical boot / bellows |
Laughing at the idea of using a scuba snorkel rubber! _________________ This free advice is worth exactly what you paid for it.
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4772 Location: Bemidji, MN
Posted: Tue Apr 13, 2021 12:58 pm Post subject: Re: door electrical boot / bellows |
you're just gonna slice the thing open when your power mirror or speakers stop working. the wires always break in the tube. so might as well use something you won't cry over when you need to make the surgical incision to restore wiring happiness. _________________ -dan
www.thefixitworkshop.com |
DuncanS Samba Member
Posted: Tue Apr 13, 2021 1:04 pm Post subject: Re: door electrical boot / bellows |
Boots do not need to be sliced open to work on the wires. Remove the ends from their fixed location and pull the wires back and forth and you can usually find something wrong. Or use a bad wire as messenger to pull a new one. Lube the new wire with KY or something soapy first. They pull through really easily. |
Posted: Wed Apr 14, 2021 5:35 am Post subject: Re: door electrical boot / bellows |
Do what Dave says, although if you graft the OG ends to these bellows which could conform to the bending, they might better avoid pinching of the wires. Problem is, it has a smaller id than the OG. There may be others with would be bigger, but this was the first that popped up.
16CVs Samba Member
Joined: February 22, 2004 Posts: 4024 Location: Redwood City, California
Posted: Wed Apr 14, 2021 2:06 pm Post subject: Re: door electrical boot / bellows |
New Boots are available or I have some good used units. _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
Joined: January 01, 2007 Posts: 16863 Location: sticksville, ct.
Posted: Wed Apr 14, 2021 2:40 pm Post subject: Re: door electrical boot / bellows |
16CVs wrote: |
New Boots are available or I have some good used units. |
yea, i had no idea they were available.
blows my mind someone would futz around trying to make something when it's available.
i have a real nice pair i have no use for, and was going to list them at 50/pair but seeing new ones aren't a lot of $$ it isn't worth the time to list them _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
