Jubbly Bug Samba Member
Joined: September 21, 2008 Posts: 79 Location: Skelton North England
Posted: Tue Apr 13, 2021 1:52 pm Post subject: 1.6TD head gasket question |
Hello all
. I'm embarking on a diesel conversion on my vanagon (t25 ) in the UK .
I'm rebuilding a 1.6td that I got as a partly stripped engine and have noticed there are no dowels in the cylinder block to locate the gasket and head in place?
Is this normal or are they missing ?
I replaced the head gasket on my Skoda 1.9tdi a couple of years ago and that had dowels .
Thank you for your time reading this
Jim _________________ 1971 Baja beetle
1987 T25/vanagon |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4798 Location: Bemidji, MN
Posted: Tue Apr 13, 2021 1:59 pm Post subject: Re: 1.6td head gasket question . |
if i recall, there are no dowels... you place the gasket and head down and wiggle things around until all the head bolts go in.
if you want to ease your life, get a set of the very expensive ARP head studs. they eliminate the "death snap" horrible sound when torquing down and seem to have a very good track record of fixing the leaking head gasket issues on the 1.6. _________________ -dan
www.thefixitworkshop.com |
vwhammer Samba Member
Joined: May 20, 2006 Posts: 998 Location: Boulder CO.
?Waldo? Samba Member
Posted: Tue Apr 13, 2021 3:13 pm Post subject: Re: 1.6td head gasket question . |
X3, no dowels on the 1.6TD.
For aligning the block, head, and gasket I have a couple used head bolts (they are single use) that I cut the heads off of and cut slots in the top instead. I thread them in finger tight into two opposite corners. Then place the head gasket on, then carefully place the head over the protruding bolts. After getting the other new bolts threaded in finger tight, I remove those alignment bolts with a flat head screwdriver.
Does your engine have hydraulic or solid lifters? If hydraulic, then use the AAZ gasket. |
RolandD Samba Member
Joined: January 15, 2017 Posts: 247 Location: Menomonee Falls, Wis
Posted: Tue Apr 13, 2021 4:49 pm Post subject: Re: 1.6td head gasket question . |
I concur with Waldo on the use of old cut down bolts as guide pins.
Roland |
Posted: Wed Apr 14, 2021 12:02 pm Post subject: Re: 1.6td head gasket question . |
Great stuff thank you all for the info ,I thought it unusual not to have the dowels ,most cars ive delt with have had them .
Thanks again Jim
Ps Waldo its a solid lifter motor . Any advice on using spray hylomar or similar on the gasket or just as is? Ive never used it on a head gasket before . _________________ 1971 Baja beetle
1987 T25/vanagon |
Posted: Wed Apr 14, 2021 2:52 pm Post subject: Re: 1.6td head gasket question . |
I use a very light coat of hylomar spray on both sides of the gasket, on the block, and on the head. It does a great job of preventing the pesky weeping oil leaks at the head to block drains and the pressurized oil connection to the head between cyl 3+4. Despite the manual saying to assemble dry, the factory used hylomar or something like it on the head gaskets for assembly. |
Posted: Fri Apr 16, 2021 1:42 pm Post subject: Re: 1.6td head gasket question . |
Ok great stuff Il be ordering some for the job.
Thanks again jim _________________ 1971 Baja beetle
1987 T25/vanagon |
Posted: Sat Apr 17, 2021 8:39 am Post subject: Re: 1.6td head gasket question . |
Ok so another question
ive got a solid lifter td . On selecting the head gasket it gos on the amount of piston protrusion. Now if I'm going to up the fueling and boost and push the little 1.6 would the thicker gasket be the best choice to aid the tune?
1987 T25/vanagon |
Posted: Sat Apr 17, 2021 9:44 am Post subject: Re: 1.6td head gasket question . |
IMO, no. Go with the correct gasket. Going with a thicker than spec gasket will lower compression which might be desirable for higher boost, but it can make cold starts worse. Other factors against a thicker than stock gasket are that it will reduce 'squish' which is important for appropriate turbulence and fuel/air mixing/burn, and will also reduce 'quench' which is the transfer of heat from the piston crown to the head (which is water cooled).
Make sure to clean all the carbon off the piston tops and clean the head gasket surface of the block meticulously. The carbon on the piston top is enough to skew the measurement from the thinnest to thickest gasket. |
Posted: Sun Apr 18, 2021 4:54 am Post subject: Re: 1.6TD head gasket question |
Great stuff thanks again . Just trying ideas before I start on the engine reassembly. Will be measuring the protrusion and getting the gasket accordingly.
1987 T25/vanagon |
