Gas pedal linkage - parts and installation
Page: 1, 2, 3, 4, 5, 6  Next
don.ville
Samba YardMan
don.ville is offline
PostPosted: Tue May 20, 2008 5:06 pm    Post subject: Gas pedal linkage - parts and installation Reply with quote
What is the correct way to connect these two pieces?
Should I open the eye?
I looked at Hazetguy's photos, and he used a nut/bolt combo, but his accelerator cable did not look like mine, his had a flat end at the front.
His photos
http://www.thesamba.com/vw/forum/album_search.php?search_keywords=Bus+Accelerator+Pedal+Pivot
(Those holes are pretty close to the edge eh?)
04 Jetta TDI Page
29 Ford Model A Rat Rod
2015 Audi A8L TDI Quattro
View user's profile Send private message Facebook Twitter Gallery Classifieds Feedback
Clara Premium Member
Clara is offline
PostPosted: Tue May 20, 2008 6:20 pm    Post subject: Reply with quote
What does the parts list show?
http://oacdp.freeweb7.com/5867part/367.png
see parts in the diagram 81,82,83
clevis pin, washer, and cotter pin.
PostPosted: Tue May 20, 2008 8:22 pm    Post subject: Reply with quote
One solution:
PostPosted: Tue May 20, 2008 8:23 pm    Post subject: Reply with quote
My '61 has a cross pin there instead of the hook going through the L-bracket.
PostPosted: Tue May 20, 2008 8:26 pm    Post subject: Reply with quote
I think 81/82/83 are for the center pivot point?
Clara is offline
PostPosted: Tue May 20, 2008 9:50 pm    Post subject: Reply with quote
er... ya. Embarassed
It's been a long time since I've changed an accelerator cable.
(Watch out, now three will break in a week)
BarryL Premium Member
BarryL is offline
PostPosted: Wed May 21, 2008 8:04 am    Post subject: Reply with quote
That link never works for me...I wonder why? Hmmm....here's another way from a '67. I guess you older bus guys don't put it inside or they only stay on the outside of the little flap. I always add a washer to the pedal link 'cuz that little crush always wears away anyway.
62Baido
62Baido is offline
PostPosted: Wed May 21, 2008 8:23 am    Post subject: Reply with quote
My bus used to be setup like this until the bracket broke off!
Now it's all better of course! I set it up like my 67.
My 67 was setup like the one EverettB posted.
1962 Kombi Bus - My rolling project!
http://www.norcalaircooledgroup.org/
BarryL is offline
PostPosted: Wed May 21, 2008 10:19 am    Post subject: Reply with quote
You shouldn't have to open the eye unless it's been smashed shut. It's a tight fit and you must put it on the ell bracket before installing the bracket. The outermost hole is lower "geared" than the closer hole for foot-to-gofastness.
don.ville
Samba YardMan
PostPosted: Wed May 21, 2008 11:00 am    Post subject: Reply with quote
Thanks for the responses.
BarryL, doesn't your mounting method limit "pedal to the floor" travel? (Pedal to the metal) so to speak.
04 Jetta TDI Page
don.ville
Samba YardMan
PostPosted: Wed May 21, 2008 12:54 pm    Post subject: Reply with quote
Barry, I think why Clara's website don't work for you is because it has bandwith limitations being a free hosting site.
As soon as a post is made on the samba linking to the freeweb site, lots of people go looking at it, (probably big pictures) exceeding the bandwith limitations, then the site temporarily shuts off that page.
04 Jetta TDI Page
PostPosted: Wed May 21, 2008 4:25 pm    Post subject: Reply with quote
Every Bus I have ever seen had the L-bracket on the outside of the U-shaped bracket on the frame. '67 could be different though, I never looked at a '67.
BarryL is offline
PostPosted: Thu May 22, 2008 9:48 am    Post subject: Reply with quote
You got me worried so I went and looked and tried the gas pedal to see if it hits. Panic: no travel! Then I remembered the engine is removed temporarily so the pedal is already sitting on the metal and hence the picture like that. I've already given myself the Waldo Award so no making fun of me.
Ian
Ian is offline
PostPosted: Thu May 22, 2008 9:52 am    Post subject: Reply with quote
I had mine setup like BarryL and then the J-shaped metal hanger that is welded on to the body broke! It was hooked up this way since before I owned it. It is still working but it is weaksauce.
I'm going to fix the hanger and put the L-shaped bracket on the outside like EverettB posted, my Truck and the others I've looked at recently have it on the outside.
My Kombi is a late 66.
All your Buses are belong to us.
Love and good roads!
IN LOVING MEMORY OF ROB CRESS 1968-2012
View user's profile Send private message AIM Address Facebook Instagram Gallery Classifieds Feedback
chrisflstf
chrisflstf is offline
PostPosted: Fri May 23, 2008 9:29 am    Post subject: Reply with quote
My Factory Service manual shows the L-shaped bracket in the middle of the J-bracket, not on the outside as Ev has shown. Why the difference?
PostPosted: Fri May 23, 2008 10:17 am    Post subject: Reply with quote
I always wondered that too. I know on one of my Buses I tried that and the U-shaped piece that connects to the pedal was totally crooked so it felt wrong.
BarryL is offline
PostPosted: Fri Aug 01, 2008 11:07 am    Post subject: Reply with quote
Ok. Now I'm concerned. Is there a change in years when this got moved to the outside? The '67 Westy has that crookedness being mounted on the inside and I want to move it back before I put the pan back on. Was there a gas pedal link that was "s" shaped? Sheesh, before hitting "submit" I went and looked at my unrestored one-owner (before me) '67 Kombi and it has it on the outside. If nobody replies then I'm moving the Westy's to the outside. The Bentley shows it on the inside.
mattoreg
mattoreg is offline
PostPosted: Fri Aug 01, 2008 11:40 am    Post subject: Reply with quote
What purpose does the coiled wire (spring?) serve?
62 Turkis DC
Aaron
Samba Luddite
Aaron is offline
PostPosted: Fri Aug 01, 2008 12:18 pm    Post subject: Reply with quote
Holds it on, there's a notch the closed end of the spring locks in.
Ragman
The Sambinator
Ragman is offline
PostPosted: Fri Aug 01, 2008 1:18 pm    Post subject: Reply with quote
I think that says it all right there....unless someone can reason otherwise.
Page 1 of 6
