maggiolo72 Samba Member
Joined: April 24, 2013 Posts: 332 Location: Basel (CH)
Posted: Wed Apr 14, 2021 5:40 am Post subject: Motor hood alignement |
Hi there ,
finally after is coming togheter, I have made the rear hood but there is difference between left and right
The whole distance looks good for me...
It's the 4 bolts on the hood or the 2 hangers ?
Procedures ?
raydog Samba Member
Joined: February 09, 2006 Posts: 1163 Location: Cape Cod
Posted: Wed Apr 14, 2021 6:04 am Post subject: Re: Motor hood alignement |
I would start with the three bolts under the cowling that holds the bracket, slide the left hinge bracket toward the rear slightly. Then you may have to adjust the hood bracket to hinge screws after, and bring the hood down a smidge. Also put some painter's tape along the edge so you don't scratch anything. I think the right side looks good. _________________ Come on, It's not rocket science. KISS |
Matt Wilson Samba Member
Joined: November 14, 2005 Posts: 2408 Location: Colorado
Posted: Wed Apr 14, 2021 9:56 am Post subject: Re: Motor hood alignement |
Make small adjustments. When all else fails, and you are really close, I've had luck with taking a #2 Philips screwdriver and sticking it into the hinge bracket hole and making small bend tweaks to open or close a gap. _________________ 1972 Standard Beetle
1969 Baja Beetle |
Maddel Samba Member
Posted: Wed Apr 14, 2021 11:07 am Post subject: Re: Motor hood alignement |
Off topic...
That paint job turned out super nice! I like the colour too.
Be sure to post a few glamour shots once everything is back together.
Even more off topic...
A few years ago I spent some time in beautiful Basel and enjoyed the Tattoo.
The guesthouse was situated by the river Rhein just vis-à-vis the caserne. Too cool! |
Posted: Wed Apr 14, 2021 12:36 pm Post subject: Re: Motor hood alignement |
Thank you so much, I will post more pictures after all is finish.
I live in Basel since 8 years, love this city, the Tatoo is just awesome |
raydog Samba Member
Posted: Wed Apr 14, 2021 2:14 pm Post subject: Re: Motor hood alignement |
Yes that is a beautiful paint job. That's why I mentioned using the painter's tape. _________________ Come on, It's not rocket science. KISS |
Zundfolge1432 Samba Member
Posted: Wed Apr 14, 2021 3:04 pm Post subject: Re: Motor hood alignement |
You can actually make fine adjustments using your bare hands. The bolts allow you to set the gap and the level between body and hood. Try it . The brackets can also be bent for further adjustment.
Now obviously it would be ideal to fine tune all this before any paint is applied. |
