uk 6t6 Samba Member
Joined: December 04, 2008 Posts: 22 Location: Herts county UK
Posted: Wed Apr 14, 2021 8:54 am Post subject: How is an early oval fuel cap assembled? (100mm) |
hey there folks, random question to the knowledgeable out there...
anyone know how a 100mm fuel cap is put together? is it a press fit or are there any crimps / rivets / spotwelds that arent obvious on first inspection?
anyone ever taken one apart and managed to put it back together without butchering it?
pic for ref
reason i'm asking is i've had one chrome plated and it seems to have trapped some rather nasty fluids between the different layers of metal that is now seeping out / eating its way through the metal...
so was thinking of trying to split open one, chrome the outer shell and then reassemble...
anyone managed to split one??? _________________ Long time lurker...
(o\ ! /o) 54 58 61 66 (o\ ! /o)
"Its like jazz... either you get it or you don't... " |
nshaddox Samba Member
Joined: January 18, 2005 Posts: 612 Location: Hammatramma, MI
Posted: Wed Apr 14, 2021 11:49 am Post subject: Re: How is an early oval fuel cap assembled? (100mm) |
I tried making a less junky 80mm cap from one that was pretty beat up by separating the halves. I used a tiny screw driver to pry the outer layer out enough so it would come apart. As far as I can tell, it looks like assembly was sort of a mix between a swaging operation from the inside and a bottle capping operation from the outside. Unfortunately the cap I experimented with I never got to crimp back on tight enough so the layers kind of spin. I’d recommend not trying to disassemble. I thought about trying to make some 3D printed tooling to re crimp the halves but way to busy right now. |
Dan22 Samba Member
Joined: August 30, 2019 Posts: 469 Location: Battle Ground, WA
Posted: Wed Apr 14, 2021 7:07 pm Post subject: Re: How is an early oval fuel cap assembled? (100mm) |
There is a recent thread which has very good detail about what is inside the 100mm fuel cap. A quick search should find it. _________________ 1-0900722 die langsame grüne Schildkröte
https://www.thesamba.com/vw/forum/viewtopic.php?t=765074 |
Dan22 Samba Member
uk 6t6 Samba Member
Posted: Thu Apr 15, 2021 2:56 am Post subject: Re: How is an early oval fuel cap assembled? (100mm) |
Ah great thanks must have missed that, blimey there's a lot inside there no wonder there's space for the liquid to get trapped... _________________ Long time lurker...
