Whaanga Samba Member
Joined: May 07, 2016 Posts: 627 Location: Rochester, NY
Posted: Sat May 01, 2021 1:22 pm Post subject: Re: Engine stall, no start, start, losing power, Single Carb Jetting |
Ok - I’m still not making any progress. I removed the fuel line from the carb and did as Abscate suggested and checked the flow. Steve, you suggested I should see at least 200 ml in one minute but I saw 200 ml in about 15 seconds.
After that I opened the carb again and put all the original jets back in place. The engine runs fine at low RPM’s but bogs or shuts down when I ask for more fuel. I adjusted the mixture screw and saw very little if any difference in the way the engine ran. I really hate the single carb and have a set of Solex duals for eventual install but they’re not ready.
In my five years of bus ownership, this is the first time the bus has been stranded in the garage.
Any thoughts about what my next steps should be?
Thank You. _________________ Late 1973 Bay w/a transplanted 914 Engine
Abscate Samba Member
Joined: October 05, 2014 Posts: 22665 Location: NYC/Upstate/ROW
Posted: Sat May 01, 2021 1:31 pm Post subject: Re: Engine stall, no start, start, losing power, Single Carb Jetting |
Go back and triple check your plug wire order after that work, and that your vacuum advance is functioning.
After that, you will have to tear into the carb and find theplugging....ugh _________________ .ssS! |
HoboBus Samba Member
Joined: December 29, 2016 Posts: 347 Location: Massachusetts
Posted: Sat May 01, 2021 3:22 pm Post subject: Re: Engine stall, no start, start, losing power, Single Carb Jetting |
Sounds like it might not be carb or fuel related. You've changed and replaced lots of things, and it's still the same.
I'd move onto distributor. Mechanical advance, points, etc. Runs at low rpm but not high rpm....
Good luck.
.. _________________ Salt air it ain't thin, it'll stick right to your skin,
it'll make you feel fine. Makes you feel fine.
And I wanna be there. -- Jimmy Buffett
Just a beach-oriented camping Hobo with a bus. |
Posted: Mon May 03, 2021 6:33 am Post subject: Re: Engine stall, no start, start, losing power, Single Carb Jetting |
OK - Here's what I've done so far:
1) checked/cleaned the screen in the tank
2) replaced the fuel filter
3) pulled the spark plugs and cleaned them
After these two steps, the engine would run at high RPM for about 2 minutes the it would buck and bog
4) changed the secondary and primary jets
5) replaced the needle valve
After this, the engine could not run at high RPMs
6) swapped out the new jets with the originals
And still, the engine was not able to run at high RPMs
I'm still working to understand diagnosis principles - I can see how the fuel system can get dirty and needs to be cleaned. But how can the timing elements change? And how do I evaluate the various components? Do I pull the dizzy and check the points (gap, cleaning?) Rotor? Cap? How do I check the timing when I can't get it to high RPMs? I know I've thrown a few parts at this, but am trying to learn to diagnose instead of swapping parts.
Thanks _________________ Late 1973 Bay w/a transplanted 914 Engine |
Posted: Fri May 14, 2021 7:50 pm Post subject: Re: Engine stall, no start, start, losing power, Single Carb Jetting |
After a couple of weeks, I was able to replace the fuel pump. Aeromech, I took your advice and installed the Carter inline pump connected to the relay switch you recommended.
I put the new pump where the old one was (near the tranny nose)
I'm very glad to have it wired properly no and no longer have the pump connected directly to the coil. I'm glad to say that it fired right up and worked properly. However, I found it very frustrating that the same condition still exists and I am not able to get the engine to run at hight RPM's. The engine continues to run smoothy at idle but when I open the throttle, there is no power.
Is there a possibility this might be a vacuum issue? Recently, I've noticed an unusual behavior occurring with the brake pedal - it makes a popping-type sound when the brake is applied and the engine is running. The pedal tends to push back up in small 'notches' that correspond with each pop. I have a stock servo that was rebuilt by a reputable shop last year.
I've had my bus for five years and this the first time it has been sidelined. What other factors should I consider?
Thank You. _________________ Late 1973 Bay w/a transplanted 914 Engine |
