Bug53 Samba Member
Joined: February 22, 2021 Posts: 704 Location: Pawcatuck, CT.
Posted: Thu Apr 15, 2021 12:24 am Post subject: What's everyone using for a tachometer? |
Just curious what you volksers are using for a tach.?
Looking at mounting under dash near ash tray maybe. |
Jimbug57 Samba Member
Joined: October 08, 2002 Posts: 817 Location: Mid Michigan
flat4olsen Samba Member
Joined: February 20, 2014 Posts: 342 Location: Denmark, Europe
Posted: Thu Apr 15, 2021 2:47 am Post subject: Re: What's everyone using for a tachometer? |
All my gauges are ETB Instruments _________________ Type 1 1968, Lotosweiss. 2109 oxyboxer engine
Early Bay 1970, Montana Red. Under construction |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76911 Location: Sneaking up behind you
Posted: Thu Apr 15, 2021 3:41 am Post subject: Re: What's everyone using for a tachometer? |
VDO
_________________ Glenn
Member #1009
#BlueSquare |
windfish Samba Member
Posted: Thu Apr 15, 2021 5:22 am Post subject: Re: What's everyone using for a tachometer? |
+1 VDO
cbeck Samba Member
Posted: Thu Apr 15, 2021 7:02 am Post subject: Re: What's everyone using for a tachometer? |
The 2 1/8 vdo w/igniter 11. Had to use a diode to get it to settle down and quit bouncing around. _________________ My cut in half and rebuild thread
www.thesamba.com/vw/forum/viewtopic.php?t=647779 |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31362 Location: Hot Arizona
db69 Samba Member
Posted: Thu Apr 15, 2021 7:56 am Post subject: Re: What's everyone using for a tachometer? |
If you want a cheap tach that works I’ve been using this bosch tach for about 5yrs it reads within 100 rpms of my actron tach and its only $32 at tool discounter. |
maggiolo72 Samba Member
Joined: April 24, 2013 Posts: 332 Location: Basel (CH)
Posted: Thu Apr 15, 2021 10:11 am Post subject: Re: What's everyone using for a tachometer? |
VDO 52mm unit, in the car since 1972 |
1968BUGMAN Samba Member
Joined: April 12, 2019 Posts: 246 Location: Southern California
Starbucket Samba Member
Posted: Thu Apr 15, 2021 4:10 pm Post subject: Re: What's everyone using for a tachometer? |
Your not going to rev over 5K without a lot of mods if you want the motor to last so a tach isn't needed other than show as you can feel when the car has run out of poop. |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9960 Location: Huntington Beach, CA
Posted: Thu Apr 15, 2021 5:22 pm Post subject: Re: What's everyone using for a tachometer? |
I rev past 7000 alot!!!
Here is a picture of it sitting when I was still breaking the motor in. I set the redline needle at 5000 to be safe for the first 500 on the motor. It now resides at 7000.
_________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
H2OSB Samba Member
Joined: April 14, 2013 Posts: 1291 Location: Modesto, CA
Posted: Thu Apr 15, 2021 6:46 pm Post subject: Re: What's everyone using for a tachometer? |
Anyone ever use a factory dash mounted tach? Perhaps making it into a pod style? A buddy gave me an old 914 tach to try, but its huge and would be impractical. I think the 924 tach is smaller, but have no idea if it could be made to work (just curious...I'll likely just buy a VDO Cockpit series)
H2OSB _________________ (o\_i_/o) I'm not a vegetarian because I love animals, I'm a vegetarian because I hate plants. |
mark tucker Samba Member
Posted: Thu Apr 15, 2021 8:06 pm Post subject: Re: What's everyone using for a tachometer? |
I had a prolight automeeter,I think that was the name...(aluminum) but I never got around to installing it so I just used my ears. |
54bug Samba Member
Joined: January 16, 2011 Posts: 142 Location: WashingtonDC
Posted: Fri Apr 16, 2021 7:05 am Post subject: Re: What's everyone using for a tachometer? |
Hey All
VDO gauges appear in a heard of vehicles. I elected to use 914 gauges including the tach and a speedometer with a trip OD. The Tach is the same diameter as the original VW VDO speedo. I wanted to include the aux gauge with the fuel and temp gauge, requiring a replacement panel for the dash.
Also put the Volt, oil pressure, and oil temp in the radio opening, using a VW radio trim panel to hold the gauges.
Not for everyone, but it's all matching style VDO
Scott
H2OSB Samba Member
Posted: Fri Apr 16, 2021 10:35 am Post subject: Re: What's everyone using for a tachometer? |
54bug wrote: |
Hey All
Scott
I really wish I could do this but I'm limited by the curve window Super Beetle dash. If I ever decide to use an aftermarket dash that what I'll use. Do you find you have any issues with the 914 tach? I heard, as they age they get "lazy" If you did, what method did you use to correct it, if at all?
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9760 Location: Oregon
Posted: Fri Apr 16, 2021 10:43 am Post subject: Re: What's everyone using for a tachometer? |
Mini VDO gauge set. _________________ I have learned over the years.
Buy Once, Cry Once!
kangaboy Samba Member
Joined: August 28, 2010 Posts: 1063 Location: St. Louis, Mo
Posted: Fri Apr 16, 2021 10:59 am Post subject: Re: What's everyone using for a tachometer? |
54bug wrote: |
Hey All
Scott
Starting to look like a plane cockpit there my dude. _________________ -74 Standard - "CaliBug" 2084T, MS3X w/FI and Crank Fire
-76 Westy - "Gandalf"
-18 GTI SE
skills@eurocarsplus wrote: |
that fucking thing looks like it drove through a J.C. Whitney catalogue and hit everything on the way out |
bruehoyt Samba Member
Joined: April 08, 2008 Posts: 180 Location: Columbus, OH
Posted: Thu Jul 08, 2021 9:33 pm Post subject: Re: What's everyone using for a tachometer? |
I almost went with the autometer. I like the look and the 5k range is perfect.
I ended up getting the 4k 52mm VDO because I wanted it to look stock.
My 74 Suoper has a max hp at 4000 rpm, so I decided I could live with it.
It should help me when tuning the engine since I can distinguish 8 or 900 rpm where many of the 7k plus tachs are not suitable,
I mounted it and a 52mm VDO clock in a 2 pod under the dash where my A/C controls used to be.
I'll try to remember to post a pic soon.
PS before I bought the $118 VDO, I bought a $15 POS digital one that wasn't worth a penny. _________________ Current VW's:
71 Westfalia https://www.thesamba.com/vw/forum/viewtopic.php?t=633955
74 Super Beetle Convertible Sun Bug https://www.thesamba.com/vw/forum/viewtopic.php?t=748008
Past VW's:
71 Karmann Ghia Autostick. 17-21. https://www.thesamba.com/vw/forum/viewtopic.php?t=727596
70 Karmann Ghia driven 00-03, 67 Karmann Ghia 91-97, 74 Karmann Ghia 92-94, 71 Karmann Ghia 87-92, 74 Super Beetle 86-87, 71 Karmann Ghia 85-86 (my avatar) |
