ELFRIED Samba Member
Posted: Thu Apr 15, 2021 4:35 am Post subject: Brake switches |
I try to keep my 63 ghia as stock as possible but concerning the brakes i mounted a double circuit brake system and a cilinder I had still lying around.
Everything is mounted but one of the 3 sprong electrical connections of one of the brake switches broke off.
As I don't have a warning light anyway I 'd like to use only the good switch and wire it as a 2 sprong. .I'd like to leave the faulty one unconnected.
Will this work? |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3804 Location: Georgia
Posted: Thu Apr 15, 2021 5:49 am Post subject: Re: Brake switches |
Yes.
The stock dual circuit harness is simply parallel wired so you should have no issue. _________________ Volkswagen!
(Compression 8.7:1) |
Posted: Thu Apr 15, 2021 6:14 am Post subject: Re: Brake switches |
Great ,thanks Jeffrey |
Era Vulgaris Samba Member
Joined: August 22, 2012 Posts: 1662 Location: Raleigh, NC
Posted: Thu Apr 15, 2021 7:39 am Post subject: Re: Brake switches |
You can also use the 2-prong switches on the dual circuit master cylinder. That's what was done in '67, the first year for the dual circuit before a warning light was added. The parallel redundancy in the wiring is just for safety in case one of the switches stops working, which can happen especially if you're using the non-german cheapo ones.
FWIW, when I start assembling my car (if I ever get it back from the paint and body shop!), I'll be using this so that the brake lights come on immediately. https://www.thesamba.com/vw/classifieds/detail.php?id=2140061
Even with the German hydraulic switches, there needs to be more pedal movement than you sometimes actually use in some light braking situations for the brake lights to come on. _________________ Currently own:
66 Karmann Ghia, L390 Gulf Blue, under construction, here: www.thesamba.com/vw/forum/viewtopic.php?t=760505&highlight=
99 Mazda MX-5 10AE, Sapphire Blue Mica, 6 speed, LSD
Previously owned:
98 Porsche Boxster, silver, 2.5L -- 67 Karmann Ghia, Black, 1500sp -- 98 BMW Z3, Atlanta Blue Metallic, 2.8L I6 -- 75 Porsche 914, Laguna Blue, 2270cc -- 72 Porsche 914, Signal Orange, 1.7 FI -- 74 Karmann Ghia, Black, 1600dp -- 74 Triumph TR6 with O.D., sapphire blue |
Vladiiiii Samba Member
Joined: February 24, 2019 Posts: 518 Location: Munich, Germany
Posted: Thu Apr 15, 2021 10:45 am Post subject: Re: Brake switches |
I did this myself, and have to say it works perfectly. The slightest touch of the pedal, you get a very small click as a feedback, and the brake lights are instantly on _________________ Vlad's 72 Ghia (Once in a Lifetime Restoration topic)
https://www.thesamba.com/vw/forum/viewtopic.php?p=9237746#9237746 |
Posted: Thu Apr 15, 2021 11:42 am Post subject: Re: Brake switches |
Ok ,good to know ,just in case... |
