mabbo Samba Member
Joined: October 13, 2004 Posts: 208 Location: United Kingdom
Posted: Thu Apr 15, 2021 5:01 am Post subject: Gearbox date |
Hi,
Im struggling to find out if the small nut gearbox is the original box to my Dec 60 built bus.
The code stamped on the side is 5590753.
I searched the site but cant find out how to date it.
Cheers, Neil _________________ Retro Restoration
West Midlands, UK
www.retro-resto.co.uk
See more of our work here:
www.instagram.com/retrorestoration
www.facebook.com/retrorestos |
PEPPE Samba Member
Joined: August 24, 2003 Posts: 1068 Location: Roma Italy
Posted: Thu Apr 15, 2021 8:10 am Post subject: Re: Gearbox date |
looks more a number of a slighty later beetle trans converted to type2 (reversed and longer 4th) |
BonTonRoulet Samba Member
Joined: September 29, 2020 Posts: 360 Location: Mississippi
Posted: Thu Apr 15, 2021 9:37 am Post subject: Re: Gearbox date |
....at least in the 67 transmission or gearbox that I installed in my 66, with the engine out one can see a date stamp in the bell housing, about an inch and a half above the bottom of the gearbox and in the center below the input shaft. Have you/can you look there? |
mabbo Samba Member
FarmerBill Samba Member
Joined: July 25, 2017 Posts: 766 Location: New England
Posted: Thu Apr 15, 2021 5:07 pm Post subject: Re: Gearbox date |
I think you're looking at the front axle numbers. Serial # 5590753 looks to be a 1963 box, if it was a 1960 the serial # would start with a "B".
http://oacdp.org/progref6268/h002.jpg
Looks like Feb. |
Lind Samba Member
Joined: November 06, 2000 Posts: 9915 Location: idaho
Posted: Fri Apr 16, 2021 7:56 am Post subject: Re: Gearbox date |
Just look at the date that is cast into the case. It is inside the bell housing, and reads the same as an engine casting date.
https://www.thesamba.com/vw/forum/viewtopic.php?t=430442 _________________ .
Wanted:
mabbo Samba Member
Posted: Fri Apr 16, 2021 12:26 pm Post subject: Re: Gearbox date |
Thanks for the replies. Your right... I was looking at the axle column
Bit gutted its not the OG box from the bus, but never mind. Would the internals and everything else be exactly the same as the OG box?
West Midlands, UK
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24736 Location: Olympia Wash Rinse & Repeat
Posted: Fri Apr 16, 2021 4:19 pm Post subject: Re: Gearbox date |
mabbo wrote: |
Bit gutted its not the OG box from the bus, but never mind. Would the internals and everything else be exactly the same as the OG box? |
After 60 years, you might as well have someone do a tarot reading for your transaxle.
Even if that type 1 transaxle is untouched since it left the factory, VW always made improvements. So there would have been improvements since 1960 model year.
Additionally because of the RGBs VW used a higher geared fourth gear in the bus, than what was used in the type 1s swing axles. _________________ In Stereo, Where Available! |
Posted: Fri Apr 16, 2021 5:45 pm Post subject: Re: Gearbox date |
Yep, unfortunately with old cars, unless you have a folder full of receipts from the day it was new, there’s no way of telling what’s been done to them over the years. I think your transaxle is from a 63 bus, if there is no letter (A or B) at the front of the serial # it wouldn’t be from a bug. If you look through “Progressive Refinements” you can find all the changes that were made over the years. It’s not particularly well formatted data set (types 1,2,&3 are all lumped together) but it will tell you exactly what VW changed and when. I printed out a copy and highlighted the bus rows for easier reference. |
mabbo Samba Member
Posted: Sat Apr 17, 2021 10:18 am Post subject: Re: Gearbox date |
Maybe I didnt word my last message very well but I was more concerned if the ratios would be the same and if there were any noticeable differences that may affect anything. From what I can see, the ratios are the same 59-63:
Cheers _________________ Retro Restoration
West Midlands, UK
Posted: Sat Apr 17, 2021 11:14 am Post subject: Re: Gearbox date |
mabbo wrote: |
Maybe I didnt word my last message very well but I was more concerned if the ratios would be the same and if there were any noticeable differences that may affect anything. From what I can see, the ratios are the same 59-63: |
Still has been too many decades for that to be valid. The small nut transaxle that came with our 1960 walk thru panel camper, could only do 45 MPH with gas pedal floored. Turned out it was hitting in fourth gear 3,000 RPM @ 35 MPH (56 KPH), instead of the stock 47 MPH (76 KPH)...
Known too many other bus owners that have had similar situation. _________________ In Stereo, Where Available! |
Posted: Sat Apr 17, 2021 11:55 am Post subject: Re: Gearbox date |
VW also offered at least 4 different ratios of reduction boxes over the years, maybe more, I don't know what was offered for the 181. The only way to know for sure is to verify it. If your transaxle is out of the bus it's pretty easy to figure out ratios by putting it in gear and counting revolutions. Just start with the reduction boxes and then work your way through the gears.
I remember talking to a guy once that told me about a basket case bus he bought that had mis-matched reduction boxes, he didn't notice until he got it on the road and it became obvious something was wrong. So unless it's a running driving bus, you can't even assume both sides are the same anymore. |
mr white Samba Member
Joined: October 02, 2005 Posts: 1193 Location: beautiful Oregon & Mohave County, AZ
Posted: Tue Nov 14, 2023 7:35 pm Post subject: Re: Gearbox date |
Do we have 1967 transmission serial numbers and gear ratios? |
